FixYa.com
Tags:
Takahashi FS-78 Telescope
Takahashi FS102 focusing problem
By Odud - usenet poster
I wonder if perhaps someone can offer some assistance. I recently purchased
a used Tak FS102 and received it on Friday after sending it out for cleaning
and testing (Texas Nautical). I took it out early this morning for some
looking (the first time I've tried to use it). Unfortunately, I could not
get the image to focus. It seems as though I can't get the tube long enough
to focus anything (tried moon, Jupiter and stars). Removing the eyepiece
and holding it by hand showed that focus was possible but at least an inch
farther than the focuser will travel. The focuser does appear to be
travelling to its extreme out position. I had the same problem with the
4.8mm and 7mm Naglers. I was not using a diagonal as I don't have my 2" -
1.25" adapter as yet. I don't think it should make any difference anyway.
The visual back and all extension pieces are in place as they should be.
How could I be so far off?
Thanks in advance,
Stuart Wood
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Riddle
Riddle - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi Raf,
How is the mirror in the Lumicon EAST diagonal supported?
Is it held in place they same way as their other diagonals?
Is this mirror also from Europe the new TV diagonal?
Is Raf your first name? Do you work for Lumicon?
Rich
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Peter1
Peter1 - usenet poster
Rating: 0%, 0 votes
"Stuart and Shari Wood" <
It is absolutely normal with most APOs. To see directly you need
an extention tube. Otherwise an excellent diagonal as the
Lumicon EAST.
Raf
Solution #3
Not Rated (0)
Gary10
Gary10 - usenet poster
Rating: 0%, 0 votes
Stuart:
Do you have all the extension tubes? These get taken off all the time and are
easy to lose. If you don't have them, they are easily replaced. I find that
with the Tak 1.25" diagonal in place, I can achieve focus with any TeleVue
eyepiece with one extension tube in place, or with none at all. Two is usually
too many.
-Ed
Solution #4
Not Rated (0)
Bray
Bray - usenet poster
Rating: 0%, 0 votes
Stuart and Shari Wood wrote in message <7o25oo$
The star diagonals do take up quite a bit of the light path. Also the
Naglers
focus back farther than the Takahashi LE eyepeices. I believe they came
with three extension rings. I'm not sure if I've tried either without the
diagonal.
With the FS-78 and a 1 1/4" Lumicon mirror star diagonal I have one ring
and the 1 1/4" collet. From the focuser tube to the end (rear most) of the
collet is a little less than 3". Or, measuring from the end of the rack,
on
the bottom of the focuser. it is about 3 1/8" to the rear of the collet.
The star
diagonal is held by the collet.
Hope this helps,
Rich
Can you Help with these Telescopes problems?
Telescopes
TASCO TELESCOPE NOVICE 402X...
we put this telescope together... Answer This...
Telescopes
CEILING FAN 3SPEED 4WIRE HUDSON...
i having trouble with the... Answer This...
Telescopes
etx-105ec + autostar
I have a problem with my etx.... Answer This...
Telescopes
hunting
sighting in redfield scope Answer This...
Telescopes
Requrest for Help
Sir My son has who stays abroad... Answer This...
Repair Service
Find Telescope Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
