Question about Nikon D40 Digital Camera
Nikon D40 built-in flash...
Does the built-in flash pop up only in auto mode? I've shot several pictures in manual, but the flash doesn't pop up.
  • 423 Answers
Hi and thanks for coming to FixYa.
You can set the parameters for the manual flash in the Custom Settings Menu. Select Full to set the manual flash adjustments.
Hope this helps. Let me know if you have any questions in a comment.
Rob
Posted on Feb 27, 2009
Ive got the nikon d40. when i take photos close up they are blurred. there r 2 settings on the focus lense one is letter a one letter m. you have to move switch to indicate one or other. camara wont take...
The letters you're referencing is the M/A (manual / auto) focus switch. The lens has this switch and operates in Auto Focus mode when set to "A" and manual focus mode when set to "M".
You have to manually focus on the subject when in letter "M". If you do not, the result will be out of focus. From your description, it sounds like the camera / lens combination is attempting to focus and operate the shutter in auto, and focusing in manual; but due to some type of damage resulting from possible mishandling, exposure to dust, dirt or even moisture is interfering with the successful completion of the process.
You could isolate the problem to determine if the cause is in the lens or camera by simply attaching the lens to another compatible Nikon camera or placing a different auto-focus lens on your D40. The problem will either stay with your D40 or follow the lens when attached to a different camera. It is also *possible* that due to numerous attempts of auto-focusing with your D40 & lens combination, that both the lens *and* the camera have been damaged. If the problem is severe enough, the problem in the failed device could cause failure in the otherwise normally working device, too.
You might be best served by contacting Nikon Service & Support below:
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
You also said you lost your manual. You can download the manual for the D40 directly from Nikon in your choice of English, French or Spanish from the link below:
http://support.nikontech.com/app/answers/detail/a_id/14157/session/L3NpZC9YRTgxQVpKag%3D%3D/kw/D40%20manual/p/19%2C334/c/187/r_id/116678/sno/0
Oct 09, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 flash firing when down
Turn off the flash manually (top left button on the side of the camera body above the lens) or use the 'No Flash' Program Dial option - one click back from the green AUTO selector on your dial - the one with the lightning bolt inside a circle.
Jun 30, 2009 | Nikon D40 Digital Camera
Flash not popping up - did i push something?
Make sure you're not shooting on no-flash auto mode. Also, in P, A, and M modes you'll have to press the flash button on the side of the camera by the lens mount in order for the flash to pop up. If it's not popping on regular auto mode, make sure you don't have it disabled in the menu.
Jun 12, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Took extraordinary pictures with nikon d40 but can't edit them
You have your camera set to RAW format. It is not a compressed file, it is a full size file. Opening this in editing programs will either crash your computer or will refuse to open because of the size of the file. They are not damaged but your computer cannot handle the files. You should take them to a photo shop and have them put the files on a cd and consult your manual to change your camera to JPEG format.
Apr 30, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Mar 11, 2009 | Nikon D40x Digital Camera
Dark wiew
is it set to auto? if not i suggest you check the aperture and shutter speed setting :)
Sep 22, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 help?!
I assume the lens had the impact. The 18-55 lens has the built-in motors for auto-focus.
Try switching to manual focus (on the lens). If this works, the lens may not auto-focus anymore.
Try it and let me know.
cheers,
Sep 01, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 will not flash
The lightning bolt icon in viewfinder blinks when flash is not ready, this can happen if flash doesnt pop up all the way, or if flash strobe tube is bad.
May 16, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 - The built in flash will not ppo-up in auto mode. The only time it works is the manual modes. Are there any settings I don't know about. I'm calling it defective and will return it the store.
With the command dial set to "auto", try to take a shot in low light. The flash should pop up automatically. You can't manually pop it up with the flash button in the auto mode. If it won't pop automatically in low light, then it certainly sounds defective.
Apr 16, 2008 | Cameras
Nikon D40 Image Darkness
You probably have "bracketing" turned on. In your menu settings, search for bracketing and make sure it is off.
Feb 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Digital Camera Logo
156 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
