I have a avr-5808CI, when I hook up my bluray player with hdmi cable the blu-ray says 7.1dts hd and my system only outputs 5.1 dolby. I know you need 7.1 analoge out but is my system so obsolete. Is there no upgrade my amp has 10 channels built in Thanks
    Master:
  • 708 Answers
Hdmi splitter and hdmi switcher are different,i bought a hdmi splitter and it works perfect,see details: Amazon com MALLCROWN 3D 1080P 4 Pport Hdmi Splitter with ac power adapter... Amazon com MALLCROWN 3D 1080P 4 Pport Hdmi Splitter with ac power adapter...
Posted on Nov 21, 2016
    Problem Solver:
  • 12 Answers
No way to upgrade your pre-amp, but you can just use some simple little RCA Y-Splitters on the rear outputs to essentially give you 4 rear outputs to your amp like with 7.1.
however, true 7.1 each signal is unique.
at some point when it comes time to upgrade, check out Outlaw Audio. They make killer stuff at factory direct prices.
http://www.outlawaudio.com/products/990.html
Posted on Mar 01, 2009
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
Can I hook my cable box into my Sharp Blu ray player
Curious why you would want to do this since both cable box and BluRay generate output signals. I doubt a single line pass-through would work since the last device on the link would override the signal with its own content when turned on.
If your TV or media system accepts multiple inputs, I would route each device to a separate input on the TV/MS and switch between them with a remote. I run HDMI lines out from both my cable box and BluRay box directly into the TV as two different lines and it works fine.
Jun 29, 2012 | Panasonic DMP-BD77 Blu-ray Disc Player -...
I have a denon avr 1610 and it is connected to a sony blu ray S370. when i play a blu ray the HD sound i.e DTS HD-MA and Dolby True HD does not give proper sound and when turn on the full volume the there...
Make sure you have connected the blu ray players HDMI out to the Denon's HDMI in. HD sound is passed only through the HDMI port. And in the BD370's sound menu disable downsampling ( i.e enable uncompressed PCM audio for HDMI ).
Jun 23, 2011 | Audio Players & Recorders
I wanted to know if there is a way to hook up the sound from a Panasonic DMP-BD655P-K Blu-Ray player to my existing Yamaha DVX C310SW home theater system. I know I can hook the Blu Ray directly to the TV...
Yes this can be done. You have several options for audio hookup. Stereo 2-channel (white and red) RCA cables, digital audio (optical or coaxial) or HDMI. Your home theater must have the inputs available such as optical, coaxial etc. Typically the stereo 2-channel RCA is the simple way. Just connect from the Bluray audio outputs to the Home theater inputs (white and red) for stereo sound. Select the input on the home theater. For Dolby Digital 5.1 use optical digital audio cable (black port) or coaxial (orange RCA port) from Bluray to similar home theater input.
Mar 06, 2011 | Yamaha Audio Players & Recorders
I have hooked up my br to an onkyo home theater through hdmi. i now get an unusable signal on my flat screen. This also happens when I hook it up directly to the tv. What can I do to get this to work
hi,
The Blu-ray player outputs full HD VIDEO (1080p) through HDMI, if your tv is not a full HD one then you can't see the video. Do one thing connect the Blu-ray player to any full HD tv and go to it video setting. Down scale the video to 1080i. All HD ready tvs supports only resolution up to 1080i. only full HD tvs supports 1080p. Down scale the video to 1080i surely you will get video. Also check the version of HDMI cable you have used. It should be 1.2 or above.
ok
Feb 15, 2011 | Sony BDPS570 Bluray 3D Player
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
My new BluRay player has HDMI output for both sound and video. My Receiver, however, does not have the HDMI inputs. Can I use HDMI direct to TV, and use Optical connection to receiver for audio? Sony...
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
Oct 09, 2009 | Sony BDP-S300 Blu-Ray Disc Player
HDMI problem
u must go to the inputs and tell it you have an hdmi on the yamaha
Feb 03, 2009 | Yamaha RX-V663 Receiver
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
100 people viewed this question
 Grubhead
Grubhead
