Question about Garmin Nuvi 760 Handheld GPS Receiver
I forgot my 4 digit pin for garmin nuvi 765
Please tell me were I can go to unlock or what I can do to unlock my garmin nuvi 765!! thank you much!!!!!!
  • 4 more comments
  • pantojas_pet Mar 01, 2009
    The reason I paid 10.00 was to see if I could resolve the problem before resulting to that solution!! thank you!
    I knew from the beginning that I would have to send the unit garmin to get it unlocked! just trying some other solution before I come to that conclusion! Thanks.
    I still can not clear the screen! I did what page 50 says. but I still keep getting the page that has numbers to punch in the pin!!!
    Please I forgot my pin and can not reset my nuvi 765 I've done some of the suggested things from fixja but nothing has work so far!!
    I guess I going to have to send my unit to garmin because everything that I have read pertaining to this unit says that there is no way to unlock the unit because once you enter a pin you cannot unlock it! unless you send it to garmin!!
    Your right! I already spend 10.00 trying to unlock! the truth is that it has to be sent to garmin. thank you!!
  • 82 Answers
After you set the PIN, you will be asked to set the "secure" location. This can be anywhere.... your work location, home, local gas station, school, etc. In order to set the secure location, your antenna must be up and you have to have a satellite lock. If you don't have a lock, the "set" key will be grayed out until you acquire a lock.
The secure location is your "back-up key" in case you forget your PIN. If you have forget your pin, all you have to do is physically go to the secure location. Make sure your antenna is up and that you have a satellite lock. When you are in the secure location, your GPS will NOT ask you for the PIN when you turn it on. You'll then be able to reach the main menu and change the PIN and secure location to something else if you desire.
If you have forgot both the PIN and secure location you are out of luck. You'll have to send your unit back to Garmin to have it unlocked. Garmin may charge you for this service.
Posted on Mar 01, 2009
    Sergeant:
  • 219 Answers
The Garmin FAQ database mentions this:
"NOTE: If you forget your PIN and your security location, Garmin Product Support cannot unlock the GPS over the phone. You must send the device to Garmin for service."
This applies to your GPS. Therefore you will have to contact Garmin for information on sending in your GPS to get it unlocked.
Posted on Feb 28, 2009
    Novelist:
  • 125 Answers
I am sorry to say, but everyone here has said it already. There is no way to unlock it if you no longer know the pin, other than sending it to Garmin. If you legitimately own it, then this will inconvenience you at the most, and it will be done. If you don't own it, then you are not going to get what you are wanting here.Sorry to tell you this, however, if you bought it secondhand from someone who was " just selling it" for the cash, then you should have gotten the pin then. Either way, your out.
Hope this helps you.
    Sniper:
  • 113 Answers
You can do a hard reset by pressing the upper Left corner of the screen while turning the unit on. May correct your problem.
Good Luck!!!
neo
    Genius:
  • 1,011 Answers
Sir,
Click this link and refer the manual throughlyit hope it will be solved....
thanks good luck
  • 1,800 Answers
Did u try upgading firmware of ur device??
  • 59 Answers
Here is the manual that tells you how to reset it, on page 50.
http://www8.garmin.com/manuals/2721_OwnersManual.pdf
Hope this works.
    Brigadier General:
  • 8,619 Answers
For this pin you need to contact Garmin at---
Garmin Support
You can also reach them at---
US: (913) 397-8200 - Monday - Friday: 8 am - 7 pm CST
US Toll Free: 1-800-800-1020 - Monday - Friday: 8 am - 7 pm CST
Canada: 1-866-429-9296 - Monday - Friday: 8 am - 7 pm CST
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Mar 01, 2009
    See the manual and try the default code to unlock it.
    If that doesn't work then Contact GARMIN , they will ask you your Owner's card/warranty card (came with your unit and they will unlock your item.)
  • 19,396 Answers
You need to call your sim card company to unlock the pin.
  • Ginko
    Ginko Feb 28, 2009
    Follow instructions on link below:
    Lost PIN for Garmin Lock - Nuvi Series - FixYa
  • Ginko
    Ginko Feb 28, 2009
    I quote from the website above:
    "Garmin provides a feature called "Garmin Lock", which allows the GPS
    owner to assign a (4) digit numeric unlock access code or PIN to their
    GPS.
    The PIN is designed to prevent your GPS from being used by
    an un-authorized user. It was also meant to be used a a deterrent to
    thieves, making the GPS useless if stolen.
    The PIN setup can be
    accessed by pressing the "wrench" symbol on the main menu (Nuvi
    Series). Next, press the "gear" symbol and you should see a listing for
    Garmin Lock.
    When you set up the PIN, you will be asked to enter
    in a (4) digit numeric code. After you enter the 4th digit, you will be
    asked again for the code. This is to make sure that both entries match
    and that verify that the PIN that you request will be the one written
    into memory.
    Your PIN is written into non-volatile memory.....
    it's not a file that is accessible via USB communications between the
    GPS and a PC. You can't clear it by disconnecting the power or
    disconnecting the battery or letting the battery run down. There is no
    jumper or switch inside the GPS to reset it, so don't waste your time
    tearing the GPS apart.
    Now, after you set the PIN, you will be
    If you
    Note: If you do
    send the unit back to Garmin to be unlocked and you are found not to be
    the original owner of the GPS and it's determined to be stolen, Garmin
    will contact law enforcement (they're policy on this is right on their
    website under FAQ's)."
    From sharcnet
    athttp://www.fixya.com/support/r1121304-lo...
How to unlock the garmin nuvi 260w
  • 1
    Turn on your Nuvi 260W.
  • 2
    Enter the four-digit PIN you chose when you locked the device. If you have forgotten the PIN, proceed to Step 3.
  • 3
    Drive to your security location. When you reach your security location the Nuvi 260W will unlock automatically. If you forgot your security location or cannot drive there, proceed to Step 4.
  • 4
    Call Garmin to unlock your device. You need your receipt to complete the process. Call 1-800-800-1020 in the U.S., 1-866-429-9296 in Canada. See Resources for the Garmin support webpage.
  • Mar 05, 2011 | Garmin nuvi 260W GPS Receiver
    How do iunlock the security pin when if forgot my pin no.
    If you have a Garmin Lock on your nuvi, zumo or StreetPilot c500 series device and you have forgotten your 4 digit PIN number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock on your device. Returning to the Security Location will unlock your device.
    If you have forgotten your PIN and Security Location, just contact Product Support for assistance. Please note, you will need a copy of your receipt and there will be a charge to unlock the device as this issue is not covered by warranty.
    To contact Product Support in your area go to http://www.garmin.com/garmin/cms/site/us/support/supportcontact
    Feb 01, 2011 | Garmin Nuvi 660 GPS Receiver
    Forgot my pin
    If you have a Garmin Lock on your nuvi, zumo or StreetPilot c500 series and you have forgotten your 4 digit PIN number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock on your device. Returning to the Security Location will unlock your device.
    If you have forgotten your PIN and Security Location please contact Product Support for assistance. Please note we will require a copy of the receipt and there will be a charge to unlock the device as this issue is not covered by the warranty.
    Nov 15, 2010 | Garmin nuvi 205 GPS Receiver
    How to unlock gurmin
    this is the tips for you to unlock
    follow this instruction:
  • Step 1 Lock the screen by touching the "Lock" button. To unlock the screen, press the "Power" button.
  • Step 2 Lock the device by pressing the wrench icon, then "System" and "Garmin Lock."
  • Step 3 Press "OK." Then enter a four-digit PIN when prompted. Select "OK."
  • Step 4 Drive to a security location then press the "Set" button. Now each time you turn on the Nuvi, it will ask for the PIN. Enter it when prompted or drive to your security location.
  • Step 5 Send the Nuvi to Garmin to get it unlocked if you forgot both the PIN and the security location.
  • Jun 23, 2010 | Garmin Nuvi 350 Car GPS Receiver
    Forgot my garmin password so cant unlock
    Assuming the GPS is yours and you were the one who programmed it, here is your answer:
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you have a Garmin Lock on your nuvi, zumo or StreetPilot c500 series and you have forgotten your 4 digit PIN number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock on your device. Returning to the Security Location will unlock your device. (Approximately 150 feet from that location)
    If you have forgotten your PIN and Security Location please contact Product Support for assistance. Please note Garmin will require a copy of the receipt and there will be a charge to unlock the device as this issue is not covered by the warranty.
    Feb 02, 2010 | Garmin nuvi 205W GPS Receiver
    I have a garmi 260 nuvi moved and i forgot the code. how do i reset it
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you have a Garmin Lock on your nuvi, series and you have forgotten your 4 digit PIN number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock on your device. Returning to the Security Location will unlock your device. (Approximately 150 feet from that location)
    Jan 08, 2010 | Garmin nuvi 260W Car GPS Receiver
    I forgot my password
    Nov 28, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
    Forgot password cant unlock to change code.
    Oct 22, 2009 | Garmin nuvi 260W GPS Receiver
    Forgot my pin number
    im sure this is not the answer your looking for, but If you have a Garmin Lock on your nuvi, zumo or StreetPilot c5xx and you have forgotten your 4 digit PIN number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock on your device. Returning to the Security Location will unlock your device.
    Aug 07, 2009 | Garmin nuvi 205 GPS Receiver
    Help with my GPS garmin nuvi 260
    You have a problem my friend. Either remember your pin or
    Normal 0 false false false MicrosoftInternetExplorer4 If you have a Garmin Lock on your nuvi and you have forgotten your 4 digit PIN number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock on your device. Returning to the Security Location will unlock your device. (Approximately 150 feet from that location)
    Oct 24, 2008 | Garmin StreetPilot c550 GPS Receiver
    Garmin Nuvi 760 Handheld GPS Receiver Logo
    2,205 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
