Question about All-Pro Propane Garage Shop Heaters - All Pro SPC 125 Forced Air Propane Space Heater
SPC-12 SPACE HEATER WON'T STAY LIT?
WHEN I PUSH IN THE BUTTON TO LIT THE HEATER GOES OFF AS SOON AS I LET THE BUTTON GO.
  • brian tessereau May 11, 2010
    how many btu's and what delivery of power do you have electric, gas, diesel,propane etc?
  • 193 Answers
When holding button in,you are overiding themocouple funtion. You probably need to replace the thermocouple
Posted on Sep 27, 2009
I have a spc-40 heater i can not get it to stay fired up i press the fuel button and it does lite but after 15 to 20 i release button and it goes out what do i need to do to make it work again
Ensure all your connections are tight and not leaking. I would shot off the tank using the valve on the top. Disconnect it, then re-connect it. Once connected, ensure the fan on the unit starts to turn. Then you can slowly open the valve, give it a good 4-5 turns to ensure it is open. They try the ignition sequence again.
Feb 28, 2011 | All-Pro Propane Garage Shop Heaters - All...
Heater wont stay lit when i let go of primer button after a few seconds
try holding down the button for 15 to 20 seconds and then let go ( this will let the system heat up to the proper temp ),, if it still will not stay lit then the thermal coupling is bad and needs to be replaced.
c...
Jan 24, 2011 | All-Pro SPC-85 Utility Heater
When I push my red button in it shut off the fuel and wont stay going
this is caused by a bad thermo coupling. just to make sure that it is in fact bad - hold down the button for about 20 seconds while the heater is going and if after that amount of time the unit still shuts down when you release the fuel button - then replace the thermo coupling.
c...
Jan 03, 2011 | All-Pro Propane Garage Shop Heaters - All...
SPC-40 wont stay lit
Problem is either the thermocouple or the thermoelectric valve. I have one of these as well with the same problem. On mine it is not the thermocouple. I have replaced the thermocoupler and still have the problem. A thermoelectric valve is $42.25 at http://www.masterheaters.com/propane/
Im looking for a cheaper part. Any suggestions?
Gru es 1234 @yah oo.c om
Jan 12, 2010 | All-Pro Propane Garage Shop Heaters - All...
Heater won't stay lit after releasing yellow button
you need to replace the thermocouple at the burner tip it will be a copper line with a bulb in the flame tip with a copper tube leading back to the gas valve and it senses the flame and keeps the gas valve open
Dec 24, 2009 | All-Pro Propane Garage Shop Heaters - All...
40,000 but will not stay lit
Did you clean the flame sensor probe? Take a piece of sandpaper or metal file and clean it. Try that.
Dec 05, 2009 | All-Pro Propane Garage Shop Heaters - All...
Flame goes out
the most common problem is the flame sensor located just behind the fire chamber, about two inches long in a round rubber boot with two wires. you can get one from mr. heater for about 3 bucks. the wires are a different color but all you have to do is splice them to your old wires. it doesn't matter how you connect them.
Feb 02, 2009 | Reddy Heater-30-55,000 BTU Variable
All-Pro Propane Garage Shop Heaters - All Pro SPC 125 Forced Air Propane Space Heater Logo
905 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
