Question about Reddy R60A Utility Heater
How can I adjust the pump screws to get less fumes?
Model R50 It runs ok, but I get fumes off it that burns my eye's.
  • 232 Answers
Www.reddyparts.com has instructions for setting the pump pressure.
Posted on Mar 09, 2009
How to adjust fuel mixture propane rlp100 this unit burns my eyes and the fumes are bad
It sounds like it needs a service if it is giving off fumes turn off and get it serviced asap
Dec 16, 2016 | Heating & Cooling
Same senerio as earlier, with the new tbi, all new sensors, truck sits ideling black smoke!! Fumes will burn your eyes sittn in cab!!
black smoke is incomplete fuel burn in the combustion process
the burning eyes is the resultant noxious oxides that form from that incomplete combustion
causes ==
possible turbo failure (if fitted) incorrect air/fuel ratio
faulty injector tips --not atomizing properly
blocked air filter
faulty injector pump--overfueling
Sep 05, 2015 | Cars & Trucks
Smoking shop up and fumes burning eyes,smells rich ,how do i adjust?
next to pressure gauge is usually a phillips or flat head adjust it to match same psi as nameplate rating
Dec 16, 2010 | Master Heaters B200BT
Raw propane fumes and burning eyes
Ours didn,t burn liquid propane too well, so ccheck your connections on your tank for vapor or liquid.
Dec 17, 2009 | All-Pro Propane Garage Shop Heaters - All...
The heater runs rich and burns my eyes, is there an adjustment?
YES in the back of the pump assembly there are 2--screws 1--air----theother for fuel!
Dec 09, 2009 | Reddy Heater-30-55,000 BTU Variable
Handy Master Fumes so Bad your Eyes can"t take the smell
It sounds like it's not getting enough air to fuel mix, check your lines.
Jan 22, 2009 | Reddy Heater-30-55,000 BTU Variable
Master Reddy 30,000 btu heater put out nasty fumes.
Sounds like it's not getting enough air to fuel mix, check your air inlet line for breaks or just put a new one on for a couple bucks. any fuel line thats the right diameter will work, got mine from auto zone.
Jan 21, 2009 | Reddy R155D Utility Heater
Reddy R50
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 19, 2009 | Reddy Heater-30-55,000 BTU Variable
I have a reddy heater model r 50.. It ran for an hour, then shut off, I f I reset it, runs for 15 min or so shuts off... its old and borrowed, I think i might have a thermostat on it and just shuts off...
The R50 does not have a thermostat.
The 2 knobs that you mention- are they the screws in the black plastic end cover?
If so, these are the heartbeat of the fuel system and do not adjust. They adjust the air pump pressure which puts fuel in the nozzle and atomizes it. The pump pressure is critical. If the pressure is not correct the heater will shut down.
If you have adjusted the screw with a hole in it you will need to reset the pump pressure to specs. It's easy. http://reddyparts.com/photocell_test_sp.htm
Now, if you have not adjusted the pump, then you might want to check the tank for water.
Troubleshooting tips
Nov 28, 2008 | Reddy R60A Utility Heater
Reddy R60A Utility Heater Logo
386 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
