Question about Whirlpool Duet GHW9150P Front Load Washer
Someone put washing powder in machine
There is water leaking from under or behind machine when we start a load. Please help!!!!
  • www_janna_ma Feb 27, 2009
    please tell me what i can do?
    Scholar:
  • 106 Answers
First unplug the machine; open up behind to see if any of the hoses have come loose, tighten. Another place to look is the top of the machine where the water comes in, you hv to open the top to see if some hose there has come loose. Refit carefully. It is even possible that it leaks from where your filter is. Three places to check in all.
Posted on Feb 28, 2009
I bought the Samsung 8 kg Top Loader (Model: WA80V3WIP) a few weeks ago. I only use cold water and bought the yellow packet of Sunlight washing powder, which specifically says on the packet that it works...
As with any top-loader, the soap drawer will deposit the entire soap load on one spot within the first few seconds of water fill. When the water starts running through the soap drawer, the brakes on the drum are released, so you can manually rotate the drum to disperse the soap over the load surface, thus eliminating the concentrated spots. Also, you may save the duvet, as the white marks are most probably dried soap powder which can be removed with a damp cloth wiped over the area.
Oct 19, 2010 | Samsung SW62ASP Top Load Washer
My Zanussi FJ 1254W has suddenly started leaving lots of undissolved powder in the clothes after washing. I've checked that the filter is clean, and used Calgon though a couple of washes, but it hasn't...
Try filling it up with HOT water and vinegar use about 2 cups for a full load. Also take the hot and cold water hoses off the washer and check the screens for little sand like rocks that can block the water flow. I always use liquid and not the powder. Another thing is not to put the clothes in first. After you try the other things first then try to add the water first with the powder and then put the clothes in. Don't over load the clothes. This can cause the powder not to dissolve either. Hope this helps.
Dec 06, 2009 | Zanussi FJ1254W Front Load Washer
Leak from lower door section and from powder door thing.
This could be a partially or completely seized/failed pump.
Before a machine goes in to a spin cycle, it runs the pump to empty all the water out. It used to be quite common that the machine does not check all the water has gone before spinning, it just runs the pump for a set time which if the pump is okay, is long enough to empty it.
If a spin is then started with quite a lot of water left in the drum, it gets thrown everywhere including back out of the powder/conditioner draw. Also the sheer strain of spinning a large amount of water can force water through an otherwise okay door seal.
Unless you are comfortable working on the machine yourself, call an engineer.
Sep 07, 2009 | Hotpoint WF430 Front Load Washer
Cant connect the water hoses the machine
Cold fill only , designed to run efficiently on lower temperatures and with cold water powders
Blank off the hot supply line at the back of your washer before you fit it back to the wall.
Only two pipes on the machine Cold In, Waste out
Apr 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Hotpoint washing machine model WMA10
the filter is on the front bottom left or right. if this helps please rate joe
Nov 21, 2008 | Hotpoint First Edition WMA12 Front Load...
Whirlpool front loader WF665/1 spilling water during cycle. Water is leaking from where the powder is deposited into the machine during the filling stage of the washing cycle. The machine will continue its...
that means that the water is leaking from the hows at the back of the detergent drawer.
This is not a difficult fix, however the washing machine must be taken apart to access the detergent hose and find the leak.
Always better to call a technician.
Nov 16, 2008 | LG WM2487H Front Load Washer
Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Nov 10, 2008 | Samsung WF337AA Front Load Washer
SOAP DISPENSING
The soap dispenser is intended for both liquid and powder detergents. If you have a problem with mildew, then you may need to clean it occasionally with bleach water.
Aug 07, 2008 | Hotpoint WMA50 Front Load Washer
Washing machine wm1814cw
Check the wire ring that goes around the rubber seal located just inside the door - we had to call a repair person out one day because our door was leaking, and he told us it's important that the spring be at the top of the door opening to prevent leaks from happening. He had a hard time moving the spring to the top but that seemed to help.
A few months later we found a water leak from our soap tray, so we had the tray replaced under warranty, although I'm not sure that helped because the replacement looked identical to the old one. It only leaked when we used powdered Oxyclean and liquid soap in the tray at the same time; the leaking water ran behind the front cover and dripped out onto the floor all along the front of the machine, mostly near the left corner, but we stopped putting Oxyclean into the tray & the problem stopped. Hope that helps.
Feb 05, 2008 | LG WM1814CW Front Load Washer
Washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
May 11, 2007 | Kenmore 44042 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
