Question about Sony VAIO VGN-FS980 Notebook
Some green color effects are there on desktop & also on images displayed on desktop
Yes
Posted on Feb 27, 2009
My webcam iball c8.0 is showing blurr images and is fully blurrr
Webcams are useful in both personal and business functions, from video chatting to video conference calls. When your webcam displays strange colors, it is usually due to a problem that is easily fixed even without advanced technical abilities. By trying at-home solutions before sending the computer or camera in for service, you can save time and money.
Lighting
Lighting is a common cause of strange webcam colors. When your webcam does not have enough light, it compensates by adjusting settings internally. The adjustments can result in color shifts that are not true to life. Bright, diffuse lighting reduces the workload on your webcam and allows it to display colors as they are. The light source should be behind the computer and pointed at your face to reduce shadowing and provide an even light. Avoid light sources behind you, as they can cause extreme contrast between your face and the light. b> Webcam Settings b> Most webcams come equipped with customization settings that allow you to adjust the display. Changing the settings while watching a preview webcam image can help you fix odd colors on the display. The location of the video settings varies, but is often located in the Preferences, Settings, Configure or Video menus. Adjust the tint, contrast and brightness settings until the image shifts to a normal color scheme. Webcam Drivers b> Webcam drivers allow the camera to function properly. When your drivers are corrupt or out of date, they can affect even the most basic display abilities. Webcam manufacturers publish the most recent driver downloads on their websites, usually on the individual product page, along with instructions for installation. To allow your computer to communicate with the webcam and use the drivers, run a software update to install any recent versions. b> Special Effects b> Some webcams come with built-in special effects that allow you to customize the appearance of the video stream. If an effect was enabled during the last session, it may stay on when the camera is turned on again. Turning the effects off will usually resolve the problem. The location of video effect settings varies by webcam model and manufacturer. Logitech Video Effects are located using the mask button in the QuickCam menu. On a Mac, effects for the built-in iSight webcam can be changed in the Effects 1 and 2 menus in the Photo Booth application. Hope this helps.
Jan 16, 2013 | Computers & Internet
Screen suddenly does not display image just
There are two places to look for the problems, the backlight inverter board and the power supply, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 19, 2009 | ViewSonic VA912BWB 19" LCD monitor
Some green color effects are there on desktop & also on images displayed on desktop i have that same problem
I would try adjusting the screen resolution and the color quality. To adjust these properties:
Right mouse Click anywhere on the desktop--->Properties-->Settings
Feb 27, 2009 | Dell Vostro 1400 Intel Core 2 Duo T5270...
Emachines T6524 has lost green color in monitor
this is a internal problem with the display. you need repair
Feb 05, 2009 | eMachines T6524 PC Desktop
Displays green color image/screen
When did you get this message? It seems like you have set the White Balance of the camera wrong. Set it to Auto White Balance to eliminate this problem. Use Daylight White Balance when shooting in bright daylight so as to eliminate any color cast in the image.
Feb 04, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
NEC LT35 color problem
If you're trying to project video, then the unit needs professional service. If you're trying to project from a computer, you may have a loose display cable, broken pins in one or both ends of the display cable, or broken conductors (wires) within the display cable. The computer sends its image information as a template of RED image components, GREEN image components and BLUE image components with the projector overlays to create the complete image with blended color values. (The computer also sends HORIZONTAL and VERTICAL synchronization signals, but those don'e affect the color content of the projected image.) That's why I'm suspicious of the display cable, conductors or pins.
Jul 02, 2008 | NEC LT35 Multimedia Projector
Green line on each side of the plasma display.
Anybody knows how to reapair about vertical color- stripped lines appeared on screens and some trace of greenish images exist after each images changing, my TV is Toshiba Plasma Color 42HP83, I appreciate , thanks
Jun 05, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Distorted color on image
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says. "You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
Mar 20, 2007 | Pentax Optio 555 Digital Camera
Redeye
Red-eye is actually caused by the light from the flash bouncing off the back of the retina and picking up the color red from the blood vessels. To correct this effect, follow these steps: Turn the mode dial to PlayBack Mode (green arrow) and display the image with redeye. Press OK\Menu button. Using the arrow pad, navigate to MODE MENU>EDIT>REDEYE FIX. Press the right arrow key, START will display. Press OK\Menu After {BUSY} bar displays, a screen will display with an option to cancel or save the image. ? If the option [Go] is displayed, press the OK\Menu button. This saves a corrected version of the image. ? If the option CANCEL is displayed, than the camera was unable to correct the image. Press the left arrow key to exit. This correction may not work on all pictures. If you import the original image into Olympus Master software you can also apply the Red-Eye fix located in the Edit menu. This lets you precisely pinpoint the eye area and remove the red. It even lets you remove green or blue, which can occur with animals.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Redeye
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Sony VAIO VGN-FS980 Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
