Question about Nintendo Wii Console
No power to wii everything else is fine on same surge protector
  • 3 more comments
  • Anonymous Feb 28, 2009
    Same thing, no power to the Wii Console but everything else is working in the same power bar.
  • mikasa1973 Feb 28, 2009
    ive unpluged my Wii and pluged it back in several times. nothings working. its not even a year old and I only use it for maybe a few hours a week. any ideas? also this just sits in one place and hasnt been moved since put it their.
  • joer54 Feb 28, 2009
    No power to WII console, but everything else on power bar works fine. WII console will not turn on.
  • Anonymous Mar 01, 2009
    we had the same problem and tried solution #2 and it worked!!!
  • Anonymous Mar 23, 2009
    I have this problem too, how do you fix i t?!
Well I unplugged the Wii for 2 hours and pugged it back into a wall out let not the power strip and now its working again. I first tried it for 20 mins and it didnt chang any thing so I let it set and came back to it. This is odd thing to happen! this must be a default all Wii's have. Way too many people are complaining about the same thing.
Posted on Mar 01, 2009
When I was browsing the internet on my Wii it just froze on me!!
I tried turning it of and on ,but... never had a chance...
SOLUTION!!!
I tried my mates lead in the Wii in the back off the console.... IT WORKED!!!
Try getting a new power supply... That will help BIG time!
Unplugging the power code to the power strip worked!
Posted on Feb 28, 2009
Try unplugging the power adapter from the wall and from the back of the Wii and waiting 5 minutes.
  • 28 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
136
Posted on Mar 22, 2009
I had a power surge about a month ago and now my wii will not turn on. My wii is pluged into a surge protector.
I posted this elsewhere on here too, but I'll post it here too so it helps you.
This is a common problem with the Wii. You wouldn't believe how often I read about this. I'm very surpised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 09, 2009 | Nintendo Wii Console
Wii will not turn on even though it has power and everything is connected. Help?
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
My wii will not turn on, I have never had a problem with it before. I checked all of the plugs and everything seems great except it will not turn on.
It seems every 5th problem I see is this issue. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii or in the Owner's Manual.
This is a common problem with the Wii. It happens almost every time there is a power surge or the power goes out, etc. Even if it's hooked up to a surge protector, this happens.
Power will come back on, or you'll go to turn the Wii on one day, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Nov 29, 2009 | Nintendo Wii Console
Everything is plugged in, and it wont turn on
It seems even 5th or 6th problem is this. The AC adapter needs to be reset. Unplug it from the wall outlet for 5 to 10 minutes (NOT from the Wii, it HAS to be from the wall outlet).
Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
Nov 22, 2009 | Nintendo Wii Console
Want to play again and turn on wii Console no picture, why
You need to unplug the AC adapter from the wall outlet for 5 or 10 minutes (NOT from the Wii, you have to unplug it from the wall outlet). Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
Nov 15, 2009 | Nintendo Wii Console
Wii worked fine yesterday. Will not power up
This is a common problem with the Wii. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii. It happens almost every time there is a power surge or the power goes out, etc.
Nov 14, 2009 | Nintendo Wii Console
Wii won't power up
Leave the wii power brick unplugged from the wall socket for 15 min then try to plug it back in. This worked for me.
Jun 11, 2009 | Nintendo Wii Console
Storm last night, now Wii won't power up
Unplug everything! There is a "breaker" in the power supply and it may need to be reset. Just unplug all cables from the TV and outlets. Let it sit for a couple hours then plug everything back in and it should work fine. If not then the power supply has shorted out due to a strong power surge. You can claim it under your home owners insurance or call Nintendo and try to get it replaced. Thanks! Good luck and happy gaming!!
Aug 31, 2008 | Nintendo Wii Console
My wii won't turn on
You likely had a power failure. You need to reset your AC adapter. Here's how:
  1. unplug the power cord from the wii. Unplug the adapter from your surge protector or the power outlet.
  2. wait 90 to 120 seconds. (Some people say to wait 30 seconds. Wrong! At least 90 secs is required for the AC adapter to rest.
  3. plug stuff back in and you're good to go.
NOTE: electronics like your wii, ps3, etc should be protected from power surges and power failures! Plug them into a good surge protector. Always!
Jun 27, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
154 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
