Question about Minolta DiALTA Di520 Laser Printer
Toner collection bottle
I REPLACED MY TONER COLLECTION BOTTLE ON MY DI520 COPIER. IS THERE A CODE TO RESET THE MACHINE SO IT WILL WORK
  • rconnell Feb 27, 2009
    I REPLACED MY TONER COLLECTION BOTTLE ON MY DI520 COPIER. IS THERE A CODE TO RESET THE MACHINE SO IT WILL WORK me tooooo
  • Minolta Master
  • 1,297 Answers
Please pres UTILITY key ,after touch Neter count to touch panel display,press in that order Stop - 0 -Stop -0 - 0 - 1; select COUNTER,select Consumables,select waste toner:
SET : 320000
Counter:press C to cleared the value.
After press exit etc.
Posted on Jul 31, 2009
Message the toner bottle is full please call the server machine printing rico 4500
The bottle full message indicates that the waste toner collection bottle is full. The full bottle needs to be removed and the toner disposed of properly. Then a replacement collection bottle needs to be installed and the waste toner counter reset. This site has the toner bottle: http://www.precisionroller.com/waste-toner-containers-for-ricoh-aficio-mp-c4500/details_47769.html . It is possible to reuse the bottles but most people will spill the toner when they try to empty a collection bottle. You do not want loose toner in your environment.
Turn off the printer (at the power switch) and wait for the lights to stop blinking before attempting the replacement. See page 62 of the network guide for the replacement procedure. See https://www.ricoh-usa.com/downloads/downloads.aspx to search for your printer and get the manuals.
I hope this helps
Jul 06, 2015 | Office Equipment & Supplies
Code C-0072
power off the machine. Then take the toner bottle out be careful hole in the bottle may be down so that yank it out. pull out slowly!!!!!!!!!!!!!!!! Then with no toner bottle in the machine turn it on let it goes thru its normal routine it may take a while you may even here the the toner bottle turning GOOD SIGN. When the the machine says replace toner re install the toner bottle PROPERLY if the nub (s) on the toner bottle are bent replace the bottle, MAKE SURE it is the right toner bottle for the machine be amazed how may people place and bottle that fits!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Apr 17, 2014 | Minolta DiALTA Di183 Copier
Di5510 service code sc 29-05
You need to have the developer and drum replaced. Make sure that the proper tests are run after the new develop is replaced. Also COUNTERS must be cleared the machine works off the counters if you reset counters without replacing the parts the machine will set certain voltages to those that you say are new when in reality they are old and you get bad images and codes. also check that when the drum is remove to clean the senor DO NOT USE A VACUUM CLEANER to clean the developer or toner The static electricity from the vacuum cleaner will destroy the sensors and circuit board. NEW TONER bottle will do nothing GET a qualified Konica Minolta Technician out to do this right to much to tell you to do via this web site. Have Complete PM none. That way you get the job done right, That will include the drum cleaning blade the Toner collection roller, Charge wires, etc.
Oct 26, 2012 | Minolta Office Equipment & Supplies
Error is E000019-0000
Let the front of the canon copier/image runner iR 3300 as a referrence, waste toner bottle is located under neath the small cover of size 15 cmsX 30 cms and this small cover is located at the extremely lower left corner of the copier/image runner iR3300.This small cover will fixed with one and only one screw at the upper/top right corner of the small cover. Un screw this small cover and remove the small cover along with the attached screw and kept aside. Under neath this small cover there will be a big plastic bottle which is called as the waste toner collection bottle. The capacity of this bottle may be 11/2 kgs to 2 kgs. When this waste toner bottle was filled up , a message will be appeared on the screen that ' replace the waste toner collection bottle'. Even after the this message the copier/image runner may work properly. If the message of error code E000019-0000 appeared on the screen this waste toner bottle may be filled completly. Then the coper will stops to work. Then gently remove this waste toner collection bottle slowly and empty the waste toner bottle which was filled up with waste toner within the plastic bag. Wash this waste toner bottle with soft water 2 or 3 times and there after with soft detergent washing powder , so that no stains of waste toner or any type of stains may be completly removed. Please don't try to remove the water particles with cloth or any thing Or don't try to remove the water particles with Hot hair dryer. After washing the waste toner bottle , dry this with the air coming from cealing fan or with cold hair dryer. After the waste toner bottle was completly dried withj the cold air replace the this bottle in the original place. Before replacing the waste toner bottle in its original position clean the place of waste toner base / holder -up , down, left & right with the clean and soft cloth which is under neath the small cover. Hurray ! your problem will be solved completly without any expenditure but you may expected to take time with patience.
Sep 22, 2010 | Canon (6981A002AA) for imagerunner 2200,...
How do i change the toner colection bottle for a Ricoh aficio 350 copier?
There is no toner collection bottle for the 350, used toner is stored in the transfer belt unit. It must be pulled from the machine disassembled then empty used toner reassemble and put back in machine, a counter must also be reset, cant remember which sp code this is though.
Sep 16, 2010 | Ricoh Aficio SP C410DN Laser Printer
How to replace savin c3030 waste toner bottle
The used toner collection bottle is located behind the cover, just left of tray 1. To empty/replace this bottle, follow these steps.
  1. Turn machine off with red rocker switch, this is located on the left side of the machine.
  2. Open front cover.
  3. remove screw on the bottom-left side that holds the toner collection cover closed.
  4. close the front cover
  5. pull out tray 1
  6. open toner collection bottle cover(swings to the left)
  7. pull out toner collection bottle
At this point you can empty it or replace it, and reassemble in the reverse order of removal.
Dec 05, 2009 | Office Equipment & Supplies
Savin 2070dp error code sc496
SC496: Toner collection bottle error
-Definition-
The toner collection bottle set switch remains off when the front door is closed.
- Possible causes -
• No toner collection bottle
• Poor connection on the switch connector
Aug 24, 2009 | Ricoh Aficio 450 Copier
I REPLACED MY TONER COLLECTION Minolta d520
Press Utility key and press in this order STOP-0-STOP-0-0-1,select COUNTER windows,select waste toner windows: for SET press C(cancel 10 keys pad) introduction 320000; for Counter press C.press Exit too quit,back the basic menu.
Feb 27, 2009 | Minolta DiALTA Di520 Laser Printer
Di520 black and white copier toner collection box
Enter the tech rep mode by pushing the utility button, pulling up the counter screen, and pushing Stop-0-0-Stop-0-1.
This will pull up the tech rep mode menu. Select "Counter" and then "Consumables."
Select the toner collection count and hit "Clear." Exit the mode and you should be good to go.
Dec 30, 2008 | Konica Minolta DiALTA Di200 Copier
Can't find toner collection box
So which is it, a Di200 or a Di520?
A Di200 has no toner collection box - the waste toner is recycled.
The toner collection box on a Di520 is located in the rear of the machine - just remove the main rear cover and it is obvious.
Nov 18, 2008 | Konica Minolta DiALTA Di200 Copier
133 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
