Question about Microsoft Windows XP Professional for PC
Svchost.exe boot up problem
Ok guys , when i start the windows and log in this comes up
http://img23.imageshack.us/img23/5340/probx.jpg
i`m using windows xp, sp3
absolutely no idea how to fix this
  • 54 Answers
Virus worm...get a good antivirus not a trial version
Try this
Your files must be un-hidden (Files option)
Here is the site that will help you
http://www.plumchoice.com/tempfiles5.html
Posted on Feb 27, 2009
Hi guys, I have strange problems with my Lenovo 3000 N200 (0769) laptop. I wasn't able to find similar problems on the net and I hoped that you could help me to diagnose them. The problems are as...
Sounds like the video driver is corrupt and needs reinstalled. Stop 0x050 with NV4_mini usually is driver problems. First, boot hitting FF8 several times a second Choose VGA mode on the black and white screen System should come up although the video will be poor. Go to Lenvo and download the drivers for your video card (http://support.lenovo.com/en_US/downloads/default.page?) Install the drivers Restart All should be well
I do this for fun & 4 thumbs not $$$$
Jim
PS The pictures where a GREAT help. Rarely see that
Oct 12, 2011 | Lenovo 3000 N200 Notebook
I just installed ASUS EAH 4870 DK 1GB and when I boot the pc there are white lines all over the screen and after the OS load up then there will be two vertical white line(the two vertical lines comes when...
If you have a second rig then test that card in that pc.So that you can be 100% sure.And donot waste your time reinstalling driver becoz that issue is hardware related not software.
Oct 19, 2010 | ASUS Computers & Internet
Windows 2003 SBS Standard Edition ? IP Address: 192.168.1.5 Linksys WRV210 ? 192.168.1.1 Screenshot Router setup page: http://img205.imageshack.us/img205/3889/capture1w.jpg I have setup a preferred...
Use static IP addresses. Do not DHCP from the router. Still use the same DNS and gateway. Just specify an IP address for each one, preferably not in the DHCP range used on the router.
Dec 07, 2009 | Microsoft Windows Server Standard 2003 for...
Laptop won't boot - gray screen
Dear user,
Your it seems that the LCD panel of your laptop is not working. and the sign of clouds is the sign of broken or screen pressed LCD. thats why the LCD did not work properly.
Please consult with qualified technician and tell him to check its LCD.
I am hopeful that you will understand my solution well.
Thanks
Sep 28, 2009 | Computers & Internet
The calendar and weather gadgets don't work properly
Try to restore your system to an earlier restore point, and if it wont work try re installing your operating system.
Apr 23, 2009 | Microsoft Computers & Internet
I have deleted svchost.exe accidently from windows xp and cannot now log onto windows. I have tried expanding the file from dos however still cannot log on
this is going to be a tough one to fix. since I don't know which svchost you have deleted from the system.
usually when that happen the only solution is to reinstall the OS. even try to fix it from the registry key, the key and the pointer will be there, but not the excution file, and there is not way which svchost control what services.
The Svchost.exe file is located in the %SystemRoot%\System32 folder. At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services allows for better control and easier debugging.
Svchost.exe groups are identified in the following registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\CurrentVersion\SvchostEach value under this key represents a separate Svchost group and appears as a separate instance when you are viewing active processes. Each value is a REG_MULTI_SZ value and contains the services that run under that Svchost group. Each Svchost group can contain one or more service names that are extracted from the registry key.
Dec 02, 2008 | Microsoft Windows XP Home Edition
I have deleted svchost.exe from windows xp
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Windows Freezing
Boot the system in safe mode
1.) restart the system
2.) pump the F8 Key until a screen comes up with different options
3.) select safe mode,
Try right clicking there and see what happens,, I,m guessing here this is a result of damages done by a previoulsy removed virus (GUESSING) it is possible that the same one could have been shard by all 3,,
I'd advise you'd uninstall norton and use the new avg free
www.free.grisoft.com
Let me know what hgappens and we can tgake this a bit further
Jul 14, 2008 | Microsoft Windows XP Home Edition
Svchost.exe
Go to start>all programmes>accesories>system tools>system restore and restore the pc to a date before you deleted the file
Nov 01, 2007 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
