Question about Thermador Cooktops
Eye won't light - clicks when turned on but no gas is coming out on one of the five eyes.
  • msemmes Feb 27, 2009
    I guess it would be a valve problem, because the eye won't light with a match and there is no gas odor. The four other eyes work fine.
    What do you do for a valve problem?
    Thanks, Margaret
  • Thermador Master
  • 3,361 Answers
Hold a match to the burner in question and see if it lights.
That will verify if it is a valve problem or a ignitor problem.
If it lites with a match the burner electrode needs cleaning or repair or adjustment.
Posted on Feb 27, 2009
  • steve
    steve Feb 27, 2009
    You will have to replace the gas valve for that burner.
Flame flares up sporadically while cooking
Due this test, turn on all burners on high, as you turn them on, does the problem burner change in volume or size of flame? If all burners are on and you only have issues with that single burner you need to replace that burner valve only. If you have issues with all burners when the all are on, replace the regulator.
I hope this helps and leads you in the right direction.
Mar 23, 2014 | Jenn-Air 36 in. CCG2523 Gas Cooktop
The cooktop just keeps clicking (trying to light) even when no eye is turned on.
My cooktop (GE)keeps clicking when it is plugged in.It did get some water splashed on it from a teapot.I have tried the hairdryer with no luck yet. Hopefully by tomorrow it may dry out. Any comment? robertgharris@comcast.net Thanks
Nov 09, 2010 | GE 36 in. Profile JGP963 Stainless Steel...
Igniter will not turn off. Makes a clicking sound
Hi, normally what causes the igniter to keep clicking is spilling water or something down into the knob area. The water is causing a short circuit in the switch which is mounted on each burner valve shaft. If unplugging the range for several days to allow drying doesn't fix the problem, then one of the switches will need to be replaced.
Jan 27, 2010 | Magic Chef Cooktops
Trouble with front burners: Right burner sparks but does not light Left burner does not apper to spark, but lights If you turn on both bruners they some times light???
The igniters for the burners are all on one circuit so when you turn the burner to light the switch inside the burner valve will cause all burner igniters to come on. As far as the left burner not sparking it could be due to a bad igniter switch in the valve and when you turn on the right burner you are causing all(including the left one) to spark. You will need to make sure that the burner eyes are clear and not plugged. You can use a sewing needle to clear out the eyes. The small eyes at the igniter electrodes are very important because if they are clogged the burner will not light.
Jan 15, 2010 | GE 30 in. JGP328 Gas Cooktop
Have Jenn-Air 36" gas cooktop w. 5 burners, black. Mdl JGC8536ADB. Plastic knobs keep splitting, even if we remember to push down before turning. Have replaced two sets and now we're down to two working...
Hi
Thanks for using FixYa. There are a few things to check for. Make sure the electrode (the small metal piece that the spark comes off from) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and not a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it.
The switches or the range control knobs may have got wet and are completing the circuit to the spark module thus causing it to continuously click or fire off sparks continuously. Use your hair/blow dryer and blow some hot air around the spark module area.
This is a typical spark module wire diagram--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 31, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Two of five cooktop burners fail to light
you can try to scratch the area where it grounds to with a wire brush or screw driver this will help sometimes. sometimes when it archs down try tighten the screws to lift up the ignitors into the hole better. or if this doesn't work replace the ignitors.
Jun 07, 2009 | Jenn-Air JGC8536 Gas Cooktop
Light sill not go off, and eye stays very hot. Must cut off at breaker
Hi, You will need to change the switch for that eye. If you give me the model#, I can help you with part#.
THanks
Vic
May 15, 2009 | Cooktops
Cooktops Logo
234 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
