Question about Progressive Computer JSI 6 spkr. Home Theater System with Scan DVD Player, 300W System
JSI MODEL # JS5010 sound cuts in and out when using .
The sound works good for just a little bit, but then it starts to cut in and out. Won't even work right with the radio.Would also like a tech support number to call. The one in the phamplet I have just rings busy.
    Champion:
    New Friend:
  • 206 Answers
Make sure it's not overheating. I have this model and know that it just has a heatsink and no fan for cooling. Make sure nothing is on top of the unit, especially blocking the vent on the right...that's the cooling vent.
Also, check your cable connections to make sure they are all connected properly.
Posted on Mar 22, 2011
  • Campbell's Custom Computers
    Oh, and also...JSI is out of business, so they have no support number to call anymore.
No cutting action
The DW331 sounds very smooth , but it was not so that Dewalt saw BUT the to thinny wormgear on the anchor and the drive gear that are in most cases the 2 parts to change sometimes also a bearing but i have the experience more then ones with this model type.
It has normally a very nice sound but because of the very fine drive toothing part 1 and part 55 but realize that this machine is not made for heavy work , and the parts are a little bit too expensive for the life under heavy load for this kind of powertool.
Its one of the tools that its not made for professional use only for little wood ,
There are better models of Dewalt
DeWALT DW331 Type 1 Jig Saw Parts
Jan 22, 2014 | Dewalt Jigsaw Model Dw331
I have a 2001 dodge stratus it won't start it cut
sounds like the timing may be a bit off, then the heat near the siloniod is causing it to crank over
Apr 07, 2013 | Cars & Trucks
F1 message on display of Kenmore Range/Oven Model #79092413202
sounds like a defective oven control board. Sometimes you can cut the power off for a little bit and reapply power and it will work, however, if you have to keep cutting power off and on to make it work, you will have to replace the Electronic Oven Control.
Jan 27, 2013 | Kenmore Kitchen Ranges
I have a Bolens BL110 Trimmer - it starts just fine, but won't rev up completely. Suggesstions?
Could be blocked spark arrestor or carboned up in the exhaust port.
May 06, 2012 | Garden
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
I bought a Poulan Pro 42cc chainsaw July 3rd. It will crank/fire but cuts out and cuts off even when I try to play with the gas. it is new and prob had thrown away stuff to where the store won't take...
This sounds more like basic carb settings, you will probably need the special tool to adjust thge jet screws if that do not have a slot in them Part no. 530035560, the carb is set up in the factory for the best emmissions, not the best running, you need to richen the mixture up on the L screw by unscrewing it a little bit at a time until it picks up clean, you may then have to increase the idle on the T screw.
Jul 08, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
F1 light comes on bike cuts off of my 2008 gsx . i change oil -gas- and bought it to the shop and the same problem. when i turn the bike on i runs for a little while then turns off
F-I is fuel injection system telling you to clean air-filter,fuel-filter and clean the fuel injector system. This is a good start.
Apr 11, 2010 | 2007 Suzuki GSX-R 750
I took it apart to clean, and now I barely cuts
Make sure the blades are even. It sometimes is hard to match when you take them apart. If they are even off a little bit they don't work. good luck
Oct 11, 2009 | Vidal Sassoon VSCL828 Hair Trimmer
Jsi model js5010
test test 18:30 dfbg
test test test 18:31
Jun 27, 2009 | Progressive Computer JSI 6 spkr. Home...
171 people viewed this question
Top Progressive Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Progressive Audio Player and Recorder Expert? Answer questions, earn points and help others
