Question about Dell E228WFP LCD Monitor
The power buttom on my Dell E228WFP 22 not working
The power buttom on my Dell E228WFP 22" monitor wont work. I push it and nothing, I did all the trouble shooting and the power cord is fine and I tested another monitor on the computer, all checks out. I think the switch is bad so I called Dell and of course the warranty ran out 6 days ago. So they connected me to the out of Warranty dept, who told me you can't get replacement parts for the monitor power switch. Any suggestions on how to fix it or where to get the part I need and info on how to get inside of the monitor to replace or fix the problem
  • Alan McCormick
    Alan McCormick Feb 25, 2012
    My E228 also had a power button problem. If you open the monitor and carefully remove the four screws holding the control pcb to the plastic frame, you can probably press the switch to turn on the monitor. The problem is that the part of the button that presses on the switch is poorly made and cracks. You best bet will be to salvage the part from a similar Dell monitor or wire up an external switch.
MY MONITOR JUST WENT OUT AND I GOT 2 RED LINES ON EACH SIDE OF SCREEN SO I UNPLUGGED IT NOW IT WONT POWERUP AND LIGHT IN BUTTON WONT GO ON
Posted on Mar 11, 2009
Monitor will not turn on. Power to the unit OK. Press power button nothing happens. Button does not light up. Connect another monitor to computer and that works. Unit is plugged into an...
It can be the power switch actuator is broken, it is badly designed for expensive monitor. Do you feel any clicking when you push on the power button?
See my pictures here and post back what you find.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E228WFPc/
If it is OK, then you will need to dig deeper into troubleshooting it.
Oct 26, 2010 | Dell E228WFP LCD Monitor
E228WFP display disappears Posted by
disconnect all the cable from the monitor except the power cable .
see if you see any test screen and keep it on ,if the test screen blacks out you monitor is bad ,better buy a new one as usually repairs cud be expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
Dell E228WFP keeps entering powersave mode
disconnect all the cables from the back of the monitor except the power
you would see a test screen
if it still go to power safe while you are in the test page you monitor cud be bad better buy a new one as usually repairs are expensive
I have a dell E228WFP 22 in monitor.The power button does not work therefore I have to leave monitor on at all times.Cam i get this repaired?
These monitors are switched by a signal from your computer. When this signal is present, the monitor turns on, when you shut your computer down, the monitor turns off. In the meantime it remains in "stand by" mode. The main moitor switch should turn if off alltogether. If it doesn't, the swich can be replaced, but cecause these are "momentary" switches it's not an easy thing to do.It won't matter a lot if you don't replace it.
Mar 29, 2010 | Dell E228WFP LCD Monitor
Stuck in power save mode
stlmeuzyk, Internal "switch-mode-power-supply"/"ccfl-inverter-supply" will probably need to be refurbished (repaired). Use Dell warranty first if valid option! Try monitor on different pc or verify your pc is working properly with old, but known-good monitor. If your E228WFP unit is still not working then you or qualified electronics technician will need to tear-down monitor to evaluate and repair the ac to dc power supply printed circuit board. Before you do anything read my fixya profile to learn flashlight test that every ccfl back-lit lcd monitor owner should know how to do and interpret the results of test. The basic design and operation of your E228WFP isn't any different than any other brand!!! Read the older solutions in my profile and follow the links you find there. Then do additional comment if need more info. Good luck with the repair. 12fixlouie
Mar 25, 2010 | Dell E228WFP LCD Monitor
Distorted images
try to change resolution settings.
right click on your desktop and click properties.. >> go to settings tab and change the resolution and colour quality and see if it works.
Good Luck!
Feb 26, 2010 | Dell E228WFP LCD Monitor
Dell e228wfp monitor
in control panel,, go to power option,, go to advanced,, on the option of turn off my monitor,, make it never
Jan 08, 2010 | Dell E228WFP LCD Monitor
SELECT BUTTONS ARE LOCKED NEED TO UNLOCK
You can lock or unlock the OSD by pushing and holding the Menu button for 15 seconds. (@nd button from the left)
http://support.dell.com/support/edocs/monitors/E228WFP/En/ug/setup.htm#Using%20the%20OSD
Sep 15, 2009 | Dell E228WFP LCD Monitor
Monitor blacks out...
You could connect it to a different PC to determine whether it's the monitor or video card, corrupted driver, etc....
Let us know how it goes, and we'll try to help.
Feb 08, 2009 | Dell E228WFP LCD Monitor
Dell E228WFP LCD Monitor Logo
458 people viewed this question
Alun Cox
