I have the URC-8910 and URC-6131 One-For-All remote controls and we just got DirecTV service in our home. I am looking for the 4-digit code for the DirecTV HD/DVR box for the URC-8910 remote. I am also looking for the 4-digit code for the DirecTV HD-only box for the URC-6131. Do you have a phone number to call too because I think these codes need to be downloaded into my remote control. Thank you.
SOURCE: universal remote code needed for motorola cable box (for comcast)
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC8800
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you
have one the "magic" button for three seconds, a light should then
flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
SOURCE: universal remote control rf20 code for directv hd-dvr
you will have to buy the logtec harmony 520 remote it programs on internet and works great
SOURCE: Need Scientific Atlanta 8300HD DVR code
You can follow the two methods I have explained below:
AUTO SEARCH FOR CODE
To program your remote in Auto Search Mode, first turn on the device you wish to program and point the remote toward it.
Then press and hold the SET and POWER buttons until the LED turns on.
Then press the device key ( CATV or RCVR) .
The LED will flash once.
Then press the CH+ button.
Then hold the POWER button for about two seconds until the LED turns on.
Release the POWER button and the LED will flash slowly. Your remote is searching through all of the codes. Continue to point the remote at the device until your device responds.
If your device turns off, turn it back on and press the CH+ button on your remote. Then press the POWER button and CH+ button alternately until the device turns off and the code is correct. Press the ENTER button to confirm and store the code. The LED will flash three times and then turn off.
If the above is not helpful then try manually searching for code:
First, press the device button on your remote.
Then press and hold the SET button. While holding the SET button, press 1 to find the first digit, 2 to find the second digit or 3 to find the third digit.
The LED flashing time will stand for each code number. If it doesn’t flash, it will stand for zero.
For example, the TV code you are trying to find is 102.
Press the SET button and 1. The LED will flash one time.
Press the SET button and 2. The LED will not flash.
Press the SET button and 3. The LED will flash two times.
Hope it helps to find your code. Thank you for using fixya!
SOURCE: Need 4 digit code for One for all remote
Try
0154 0156 0060 1256
You can get a manual from
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/one_for_all/urc4330-manual.zip&area=other
