Question about LG Dishwashers
WE WASH THE DISHES AND THEY COME OUT WITH LOTS OF LITTLE PEICES OF DIRT DRYED TO THEM I bought a brand new LG dishwasher 2 months ago. It has never cleaned the dishes adequately. Dishes come out as if they have never been washed. LG has been out 4 times and they claim nothing is wrong.
  • jimbarnes Feb 27, 2009
    My water temp is right at 140. I need to tie up the drain hose.
  • LG Master
  • 3,361 Answers
Your incoming water temp should be about 140 degrees. If not boost your water heater temp.
Check the dishwasher drain line. It should be tied up under the bottom of the sink to prevent sink water from backing down the drain into the DW.
Posted on Feb 27, 2009
Bottom water sprayer not spining
If the dishwasher won't clean dishes, check the lower wash arm assembly. If the lower wash arm isn't getting water, all of the dishes in the lower rack will come out dirty. Check to be sure the lower wash arm assembly spins freely. Also check to be sure the little holes in the lower wash arm aren't clogged or blocked.
Aug 28, 2014 | LG LDF6810ST Stainless Steel Built-in...
Brand new LG LDF6920 makes a whistling/high pitch squealing noise even during 1st test run, no dishes no contaminants added. It is during the wash motor cycle once the wash pump gets up to speed *screech*....
I had a brand new Dishwasher do that, it wasn't an LG it was a Frigidaire i think, turned out to be some bits of plastic from the manufacturing process that were in the pump. I had another one that made thumping noises and turned out to be a little piece of the tape, you know all that blue or green tape they hold everything in place with when its new. Did you run it through a few cycles and see if the noise quit? Believe it or not when i called about the one that was squealing their customer service said to run a couple cycles to remove anything that might be in the pump from manufacturing, sure enough midway through the second wash cycle it just went quiet and never made another noise again after two years.
Jan 11, 2018 | LG Dishwashers
Lots of Dishwasher Issues- I have a Bosch dishwasher that is approximately 1 year old. For the first 6-9 months it cleaned perfect. It would wash everything off the dishes and leave them sparkling clean...
Do you have hard water? Many states have passed laws that outlawed phosphate as an ingredient in dishwasher detergent. If you have hard water, the detergents don't work very well anymore. The residue is probably hard water deposits (calcium and magnesium). Not harmful but it looks awful on your dishes. There are some new products that were designed to solve this exact problem. They are inexpensive and effective. Can't say the name or I'll get banned (again). Internet search will uncover it.
May 07, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Hi, I have an LG LDS4821 dishwasher and it appears to stop working properly. The dishes don't seem to be cleaned at all. It seems like the spray arms are not spraying the dishes as the dishes are still...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 16, 2011 | LG LDS4821 24 in. Built-in Dishwasher
I've just bought the new LG Direct Drive, the problem is when I put it on ECO cycle it takes 3hrs 28 min to complete a cycle. Is this normal, I was under the impression a cycle should be about 30 min
Make sure that the water inlet pressure is good and there is no restriction ,
Now it is normal that the wash cycle is long as the dishes are put into and set to be done overnight.
But it will be good to clarify if the ECO wash takes so long as 31/2 hours, which could be fine with a high level wash.
Call LG Dealer to confirm as the set is new.
Sep 27, 2010 | LG Dishwashers
Have a brand new LG dishwasher, food residue still left on dishes after cycle. I am not talking about unusually dirty dishes here, just normal tiny bits of food. This is why we bought a new one, old one...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
Aug 06, 2010 | LG LDF6920ST Stainless Steel 24 in....
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Smell in LG LDF8812ST
First, scrape your dishes clear of food before putting them in.  Rotten food makes smells.  Second, use a good brand of detergent in the recommended amount and use the heating cycle to heat the water up.
Most dish washers have a dryer heat cycle but this one apparently does not.  This may cause mold in the machine.
How to get rid of the smell:  With no dishes in the machine, add half a cup of bleach in the bottom of the unit and do a full wash cycle.  If the unit still has an odor, get some baking soda...about a half cup and put that in the bottom of the machine.  Close the door and leave overnight.  Then, run the machine through one wet cycle...say a wash cycle and then it should stop smelling.
Hint:  When leaving dishes in the machine between uses, leave the door not close tightly.
Nov 13, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Dishwashers Logo
139 people viewed this question
Top LG Dishwashers Experts
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
