Question about Deco Lav DECOLAV Decobronze Push Button Closing Umbrella Drain Without Overflow
Deco Lav 9298 Closing Umbrella drain will not close
When the center button is pushed, the drain stopper will not "catch" and close the drain.
  • 3 Answers
Sounds like you need a new stopper i had the same trouble bought a new stopper they don't cost that much
Posted on Apr 05, 2009
The drain will not drain
If its in the drain it could be hair caught up around the stopper or caught up in the trap. It could also be further down the line, such as if your in Michigan it could be a frozen pipe.
Mar 05, 2014 | RTO Decolav 9298-cp Push Button Closing...
I can not close my bath tub drain. the plunger is all internal and wont come out either. I tried a coat hanger to push it down. no go.
on most tubs the stopper is made to come out! does the stopper have 2 screws at the stopper lever. if it does just remove these screws and pull the stopper out slowly. when putting in a new one. have the same length as the old one, then slide it back in the drain fairly slow until it goes all the way in. replace screws and try it! good-day!
Aug 05, 2011 | Kohler Bath Drain KOH-K-7104
How does the lift and turn stopper come out so we can clean plugged drain?
  • Push the stopper down to fully seal the stopper against the tub drain.
  • 2
    Turn the knob on top of the stopper counterclockwise with your fingers. Do not lift the stopper while turning the knob. Remove the knob from the stopper.
  • 3
    Insert a large flathead screwdriver into the slot on the center shaft of the stopper. You will see the center shaft when you remove the knob. Turn the shaft counterclockwise to unthread it from the retaining hole in the bathtub drain basket.
  • 4
    Use a pair of vise-grip pliers to turn the shaft if the center hole has corrosion and will not accept a screwdriver. Lock the jaws of the pliers securely around the shaft, and turn the shaft counterclockwise.
  • 5
    Pull the stopper out of the tub by lifting it by the shaft.
  • Mar 12, 2011 | Maax Soprano II: One-Piece Shower Module...
    I can't remove the tub drain to unclog it. tried vinegar and baking soda but need to remove to unclog. How to do, can't see a set screw. the drain is a pull up and turn to open/close. HELP! i'm showering...
    I will do my best to explain this ---- the little button on top of the drain cap unscrews counter-clockwise,, I have found it best to push down the drain cap with one one hand ( very hard down )and with your other hand turn the button counter-clockwise. if it still will not budge then you might need to get a pair of channel locks and a pair of pliers and get it that way. now as soon as you get the button off -- the center spindle unscrews using a large flatblade screwdriver,, unscrew it and it will all come off. if you have anymore troubles - please feel free to write back and I will do my best to walk you through any steps.
    c...
    Feb 03, 2011 | Moen Tub Drain Assembly, Lift-N-Drain -...
    I stopper on a garden tub with a delta faucet. The stopper pushes down and locks to stop water. It takes a few tries pushing it down to get it to stop and hold water. What is the best way to fix it or...
    In my part of the country, the type of drain you refer to is commonly called a tip-toe drain because you can use your toes to open and close the drain. Their locking ability diminishes over time and use, and eventually won't lock at all. They cannot be repaired, and must be replaced. You must remove the one you have to get the correct replacement because there are variations in the thread diameter at the bottom of the stopper.
    You will need to use pliers large enough to grab around the white plastic underneath the top of the stopper that appears to disappear into the drain. Once you have the white plastic shaft secured with pliers, grab the very top (the chrome part) and twist it counterclockwise to remove it. Once that is off you will see a round piece of brass that looks like the top of a very large screw. IT IS! Using a stantard screw driver, again turn counterclockwise to finish removing the rest of the stopper.
    A good hardware store should have a replacement for you. Be sure to match up the thread diameter at the bottom of the stopper.
    To reinstall, you can reverse the steps or simply thread the complete assembly into place.
    Aug 07, 2010 | Home
    Hi I have a KOHLER Fairfax Chrome Double-Handle WaterSense® Bathroom Faucet and the drain stopper keeps popping out. My husband and I have tried numerous times to fix it and can't. I also cannot...
    Un screw the nut on the drain tail piece that attaches the rod to drain pipe .Pull the rod out just slightly.Hold the drain plug in the hole with the notch sitting side ways.Push the rod back in angled so that the tip inside drain is angled up.You should feel it go through the notch on the drain plug .If it has you should not be able to pull it out.Tighten the nut hand tight and work the plunger it should be attached .If not loosen the nut again pull back on the rod and shift it around until you feel it go through the notched hole on the plug bottom
    Jun 22, 2010 | Home
    I have akohler bath drain that seals/drains simply by pushing down on the gasketed spring-loaded chrome stopper. The drain is clogged with hair but I can not figure out how to remove it and snake the...
    Toe tap stoppers remove by just gripping the stopper and unscrewing it. Once the stopper has been removed the hair will be usually caught on the crossbar underneath the stopper where it can be removed with needlenose pliers.
    Spring type stoppers for drains are just about as notorious for being hair catchers. Once again there is nothing to stop the hair from leaving the tub.
    May 21, 2010 | Plumbing
    The bathroom drain stopper will not stay closed.
    there is a small compression nut on the drain, it needs to be tightened slightly. look under the sink when you pull the lever up close the stopper, you will see where it connects to the drain. tighten that nut slightly.
    do not over tighten or you won't be able to move the stopper at all, you just need enough pressure to hold the weight of the lifting rod and stopper in place.
    May 12, 2010 | Home
    Direct push-type Kohler bath drain won't drain.
    Spring loaded chrome stopper will not stay down to fill tub with water.
    Jan 12, 2010 | Kohler Plumbing
    Bathroom sink stopper came unhooked and out, not attached anymore
    You will need to get under there and unscrew the popup rod located on the back of the drain. pull out the rod, drop the stopper in there and push the rod through the hole in the bottom of the stopper. screw the nut back on.
    Mar 15, 2009 | Home
    Deco Lav DECOLAV Decobronze Push Button Closing Umbrella Drain Without Overflow Logo
    340 people viewed this question
    Top Deco Lav Plumbing Experts
    Andrew Bugbee
    Tom Chichester
    Gil Shultz
    Are you a Deco Lav Plumbing Expert? Answer questions, earn points and help others
