Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Temp my fridge is freezing everything. i cannot tell which way to turn it. one side says cold with minus the other says coldest with pluses. which way will warm things up? please help!! thx
  • 63 Answers
SET BOTH CONTROLS HALF WAY IN THE MIDDLE SEE IF THAT WORKS FIRST
Posted on Aug 30, 2007
SOURCE:
Hi, my refrigerator Panasonic NR-B320T non stop running, both vegetable and freezer sections are GETTING FREEZED even though the temperature are set at 1 (cold not at 3, the coldest).
check your user hand book as most fridge settings work the lower the number the colder the setting
so 1 is around 1-3 degrees , 3 is 4-6 degrees, 4 is 7-10 degrees
it is the freezer that works 1 is minus 5 and 5 is minus 20 degrees
it would explain why everything is freezing up
it would also explain the non stop running as the fridge is battling to keep the low setting
Nov 23, 2016 | Panasonic Refrigerators
All cans in the bottom drawer freeze in a couple of days
What temp do you have the fridge set on? The bottom is always the coldest part maybe dont run the fridge as cold or put the cans in the door or at a higher part of the fridge.
May 22, 2014 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
We have a side by side and the refrigerator side is freezing everything. we have the settings on 2 and D
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Nov 16, 2009 | GE GSS20DBT 19.9 Cu. Ft. Side-By-Side...
Unit ED2FTGXKQ04, side-by-side fridge not cooling
hello my is leroy, have u check the freon levels for the unit.
Mar 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator side is freezing contents
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
If your settings are right then the cold control switch is the problem
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
No cold air coming into the fridg
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
You can melt this ice manually for a temp fix but the defrost system needs to be checked. Turn it off, take everything out of the freezer, use a hair dryer to warm the back wall. Do this for as long as you can without anything thawing then put it back in, turn it on and you will be good for a couple of days.
Nov 21, 2008 | Jenn-Air JCD2389G Side by Side...
Frigerator is freezing.
Now, why is too much cold air getting over to the Ref side?
1. The little door is open too much.
2. The cold control is bad causing the compressor to run too much.
Nov 13, 2008 | Frigidaire FRS26R4A Side by Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
97 people viewed this question
Top Admiral Refrigerators Experts
Ekse
jasbo
jasbo
john h
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
