Problems changing rear turn signal. bulb broke in socket bottom still in socket. How do I remove the bottom of the bulb that is corroded in socket.
You'll be ok using needle nose pliers and a tin of wd 40 lube. but don't go too crazy with the stuff as it doesn't really like playing with terminals. but in this case use the straw attachment, for in between the outer casing of the bulb an the inner casing of the socket. leave for a couple of minutes then use the needle nose pliers, grip the casing of the bulb, inner and outer, push the bulb in with the pliers and then twist.
Goodluck
Jayce
Lens/Bulb, Turn Signal-Rear
Removal and Installation
To remove the plastic socket, turn the socket counterclockwise to the stop, and remove the socket. Remove miniature bulb from socket. Install miniature bulb in socket. Index the smallest tab for locating the three locking tabs, then press the socket into the rear lamp and rotate clockwise to the stop.
