Question about Sony Cyber-Shot DSC-F55 Digital Camera
PC won't recpgnize my Sony Cybershot DSC F828
Worked fine last week, now computer won't recognise the USB device ( my camera)
  • lpf1 Feb 27, 2009
    Cybershot DSC F828
    cable is fine
    I looked in menu ( and in thevmanual) there is no initialize?
    forgot to mention I ck the usb able and recharged my camera too
  • Sony Master
  • 6,487 Answers
Remove the battery for the camera for about 5 minutes and then after that connect it to a different USB port and see if your computer will recognize it once its connected to the USB port if still not detected restart the computer, If still not detected better if you try to use a different USB cable and also to try connecting that camera to a different computer....
Posted on Feb 27, 2009
  • 10,594 Answers
Please RESET camera by going into Menu -> Internalize -> OK
Also replace USB cable and check USB port in camera that might have broken contacts.
  • Shahid Electronics
    Shahid Electronics Feb 28, 2009
    Please confirm computer USB port by hooking any other USB device and check does Windows recognize it? That will confirm that Windows itself is fine.
    Regarding RESET of camera, please see below image that showing RESET switch in DSC-F828,you need to press it.
  • Sony Master
  • 19,396 Answers
Start unplugging computer power cable for ten minutes.
Try also a different usb port on computer.
  • Ginko
    Ginko Feb 27, 2009
    This camera should be recognised by the computer even without the camera software installed.
    Start testing the camera on a different USB port, straight on the computer (no USB hub).
    Test also a different USB cable.
    If still no luck do an hard reset, do the following:
    Unplug camera from computer.
    Remove camera battery.
    Unplug computer power cord.
    If computer is a laptop , also remove battery.
    Reassemble everything together.
    If that does not work, test the camera on a different computer, probably the problem is Windows.
    To fix Windows problem do a system restore to a date before the problem started.
    You find system restore on
    Start Button>>Programs>>Accessories>>System Tools>>System Restore in windows.
    If still no joy try installing camera software from camera cd, but usually you need to reinstall defective Windows on computer.
I have an Kodak M1033 that I use all the time and until last week I was connecting via USB to my laptop running xp. I went to download pictures this week and I keep getting the "USB device not...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jul 20, 2011 | Kodak EasyShare M1033 - black Digital...
My photos won't transfer to my computer. The the last time I loaded photos onto my computer which was last week, it worked fine. however today the same computer says it does not recognize the USB device,...
Change the USB port. If you are connecting it to front USB of your computer, try connecting it to USB port at back of computer..
The cable might be fauty.
Apr 11, 2011 | Kodak EasyShare C330 Digital Camera
My Olympus µ 1030SW Digital Camera used to work fine when i plugged it into my computer to download photos. But ever since two days ago my computer now "does not recognise the usb device". Two other...
Jul 10, 2010 | Olympus ? 1030SW Digital Camera
FujiFinpix A607. Getting device not recognised when USBconnecting
make sure the software is unstalled via control panel, ad and remove programs, make sure there no mention of finepix now load the software first, then plus in the camera check the usb cable as well
Jun 14, 2009 | Fuji FinePix A607 Digital Camera
Printer not working
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing the cannon drivers and software it will ask you to connect the printer.
  • then you can connect the printer and print a test page.
Hope this help. Please Rate My Response! Thanks!
Prem
Mar 02, 2009 | HP Color LaserJet 2600n Printer
Usb device not recognised HP 1005
Version of your OS, please... 1. replace USB cable 2. uninstall last updates for your OS
Oct 16, 2008 | HP LaserJet 1020 Printer
PC not recognising camera.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Sep 26, 2008 | Pentax Optio S6 Digital Camera
USB divice not recognized
I tried many ways to fix the problem. Someone suggesting unpluging it for 30 min. That didn't work. I downloaded the latest version of the camera driver. That didn't work. I downloaded the latest version of windows, and that didn't work.
I was running out of ideas. But I thought I might try restoring my computer to a prior date. This restore feature hasn't worked for me for 6 month. But, that day, luck was on my side.
Since I restored my computer to two weeks ago. My problem, is fixed!
Jul 03, 2008 | Olympus Camedia D-390 Digital Camera
Unfortunately I don't have a solution for you, but know that you are not alone! I am having the same problem as of three days ago. I have tried multiple computers and even got a new USB cable but the problem continues. Frustrating! Please let me know if you find a solution.
Dec 24, 2006 | Canon PowerShot A75 Digital Camera
Sony Cyber-Shot DSC-F55 Digital Camera Logo
115 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
