Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Won,t print I just bought the Kidak ESP 3 all in one printer. I installed the ink cartridges but they won,t print.
    Problem Solver:
  • 19 Answers
Are all the drivers installed correctly? when you try printing off microsoft word (ctrl +p) try viewing the properties
good luck
Jayce
Posted on Feb 27, 2009
Kodak ESP-3 All-in-One-Printer still says black ink catridge is low after I replaced it
There is a sensor in the cartridge which contacts with the printer. See it is clean from dirt. Try reseating the cartridge. If you use cheap cartridge rather than genuine then this could happen.
Check for updates in the Kodak website appropriate for you.
http://support.kodak.com/app/intfSel/intf_redirect/L2FwcC9hbnN3ZXJzL2RldGFpbC9hX2lkLzE3MzAzL34va29kYWstZXNwLTMtYWxsLWluLW9uZS1wcmludGVyLWZpcm13YXJlLS0td2luZG93cy1vcGVyYXRpbmctc3lzdGVtcy9vcmlnX2ludGYva29kYWtfYjJjX2Vu
Dec 01, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have an all-in-one Kodak ESP 3250 printer. Bought it 4 months ago. I'm interested in printing only in black, but now the color cartridge has emptied and it won't let me print with the black cartridge...
The KODAK All-in-One Printer uses an advanced built-in printhead. The system is designed to provide excellent image and text quality, while eliminating the need to purchase new printheads every time you replace ink cartridges, and saving you money. The printing system requires that both the black and color ink cartridges be installed to print. If either cartridge is not installed or is out of ink, the printer or printhead will not print correctly.
Install the color a new cartridge, avoid damage to the print head.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 15, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Purchased Kodak ESP 3250 yesterday. Not printing photographs.
Yes sounds to me like one of your ink cartridge is empty. Replace and try again.
Jul 26, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
ESP 3 Multifunction Printer/ Copier/ Scanner: I have put new ink cartridges in but it is still p...
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
May 17, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3250 won't print black. Changed cartridge and still won't print black. Just installed new printer.
I fixed my ESP 3250 print problems by removing the cartridges and print head. Using a Q-tip and warm water, added drops of water to each of the print head ink wells until the water / ink from the wells bled thru onto a cleanex. Did this several times. Dryed the print head fairly well. Then added a drop of water to each cartridge for each color. Reasembled and ran an alignment and to my surprise, it works! I hadn't used my printer in a while, so the ink had dryed on the felt for both the print head and cartridges.......
May 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 doesn't print black ink!
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer not printing black installed new cartridges and ink pic on comp shows 3/4 full on each kodak esp 3 bought may 09
Try to do some cleaning cycles. It is normal that the printer will be using some ink starting up ang when you change inks because it is trying to maintain the density of the color on the print heads. Do 3 cleaning cycle. It should be on the maintenance menu of your printer or if it is installed on your computer, you can go to control panel>printers(printers and faxes)>right click on the printer icon then left click on properties. You can look for maintenance tab and use cleaning cycle. After the 3rd cleaning cycle and it still doesnt print black, the print head must be defective and needs service.
Sep 05, 2009 | Office Equipment & Supplies
Kodak ESP 3 Colors won't print
For that problem kindly try doing the ff:
  • Re-seat the inks both color and black then try printing
  • Re-seat the Printhead of the printer then print again
  • if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Aug 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I need to change the printer head on my Kodak 5100 all in one printer
To install the printhead and ink cartridges in the: Additional search terms: print head, tank, replace
Jan 22, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
165 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
