32" flat screen Proton just died. We checked all the usual suspects. Nothing wrong.
  • 10,594 Answers
Does TV standby light blinks?
If not, then check power supply fuse and.
If yes then TV has problem in other circuits.
Posted on Feb 27, 2009
  • 19,396 Answers
Test accurately the power board, check also that there is continuity on power cable.
  • Ginko
    Ginko Feb 27, 2009
    If the TV is not starting at all, with no power, then start testing it on a different power outlet, after leaving the TV unplugged for twenty minutes or so.
    If still no joy, then there is a fault.
    The technician will start testing the power cable, and then the power board inside the TV that are the common cause for no power on TV.
    If instad the TV stays in standby, leave it unplugged for one hour. If it still stays on standby afterward, then the TV is on protection mode because an internal fault had been detected.
    In that case you will need a technician to fix the problem.
    The only distrutor for Protron replacements in US is Vance Baldwin (Encompass Parts Distribution), call them if you need replacements parts o want to know cost of a spare.
Sound works < but no picture
Proton LCD TV, Hi, most LCD's and Plasma's have a cold/ hot circuit and the board for video and audio are the same usually it's a main board but before going through all that check to be sure that it's not a setting or volume adjustment. older model proton TV's exchange the main board these usually go bad IU would search any auction sites for a similar model with a broken screen and take out the needed parts for this fix, otherwise your better of getting a more updated LCD TV good thing is that they are way cheaper now
Feb 26, 2014 | Protron PLTV-32 Television
Our proton 32 in flat screen has sound but no picture it is out of warranty
Check the backlight inverter the is the part that turns on the TV light so that you can see the picture. If there is power going into it usually 24v DC and the backlight is not turning on then it's provably your backlight inverter that is bad. If you look at it it has a part number on it that you cna use to order anotherone. You can order it from www.interliquidparts.com
Jun 03, 2011 | Protron PLTV-32 Television
I cant turn on the tv
Any LED lights, if none or comes on then go off suspect Power supply board
Dec 24, 2010 | Proton MS-32 TV
My proton LCD 32'' has sound but no pictures.
If you need a board write the board number down. Try LCDparts.net and see if you can match board with what they have.
Apr 26, 2010 | Protron PLTV-32 Television
MY 32 PROTON TV DONT WORK I NEED THE POWER SUPPLY
You can probably fix this. Ask someone who can unsolder and solder. You have three bad capacitors in the power supply!
Feb 26, 2010 | Protron PLTV3250 32 in. LCD Television
Protron lcd tv getting no power
I have the same problem. I am told that I need a new power supply (adaptor) but from what I am reading on the Net, they are very rare and TV repairman told me he cannot find the part. I heard that Protron is out of business.
Jun 03, 2009 | Protron PLTV-32 Television
Can you help me find a pwer cord for my 32''flat screen (Proton)
Unless this set is really oddball, it probably has the same type power cord connector used on computers and so many other electronic appliances. If this is the case, you can use a standard computer power cord as a replacement. The computer cord is a three-wire plug with a ground pin and the TV probably only had a two-prong plug, but the cord will still fit. Your electric outlet should be the three-prong type (if it's not, get it replaced!) so the plug will fit.
If the connector in the set is really different, you can check online by doing a Google search for replacement parts for you TV.
Nov 21, 2008 | Proton MM2701VT 27" TV
Proton pltv 32 no signal
I have the same problem. It seems the tv is switching from composite1 to composite 2 source.
Jul 09, 2008 | Protron PLTV-32 Television
Proton TV
make sure cables connected correctly and source switched to proper input.
Mar 28, 2008 | Protron PLTV-32 Television
PLTV-32
Have you asked proton about the bulb or inverter or power supply. Proton is going to be the only place to get them. Soory to have to tell you but proton doesnt have good customer service.
Aug 11, 2006 | Protron PLTV-32 Television
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
