Question about Toshiba MW27F51 27 in. TV/VCR/DVD Combo
I have a Toshiba TV/DVD/VCR combo model # MW27F51-had it for a couple of years. Turned it on, have sound but no picture. I have the cover off the back of it now.
  • fixedopsm355 Mar 05, 2009
    vcr and dvd will play but picture is black audio is good. also tv scree black when using tv function. this tv had been used very little when this just happened, no warning or noises were made.
    i'm techno dummy by i checked only fuse i could find inside back cover and it look good to me. Can anybody offer me any help here?
  • 167 Answers
Sound like a defective part inside the set. i could tell you what one went bad, this is not user servicable, and could shock you bad. i would take it for service or get a new one. due to the cost of these against the cost of repair.rule of electronics-if the cost of repair is 60% of a new one you should not repair it. good luck! hope this helps!
Posted on Mar 09, 2009
  • glenn hoffman
    glenn hoffman Mar 09, 2009
    other thoughts check the input, source selector, and try and set it up, good luck!
THE DVD WON'T OPEN OR PLAY ON MY TOSHIBA TV/VCR/DVD COMBO MW27FN1
check either the front or back of television for a small pinhole, that should be the emergency eject hole, place unwound paper clip in hole to eject disk, however, this will probably be re-occuring and dvd player will need to be replaced.
Oct 17, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
MY toshiba tv MW27F11C only shows a white line when turned on
Hello uuka,
You have vertical collapse. This is most often caused by a defective vertical output integrated circuit, an open dropping resistor which feeds the supply voltage to the I.C., one or more defective electrolytic capacitors in the vertical circuit or something as simple as bad solder connections. The latter will usually manifest itself as an intermittent failure. Less likely, but stilla possibility is a defective yoke, but this a rare.
Unless you are handy with a soldering iron and have some experience this is definitely something I suggest that you refer to a qualified technician. Depending on the actual cure for the problem, this would typically be under $100 in my shop, but we are in a small town and prices are cheap. I would definitely recommend a repair on this since it can not be replaced. They don't make a TV/DVD/VCR combination any longer and the picture quality on these Toshiba/Orion combos has been very good over time.
Hope this helped and don't forget to rate...
Thanks!
The Wing Guy
Apr 29, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Bottom left corner, red part of the picture is making an arch
11 years old, you may need a new one, as service can be costly. if the cost of repair is more tha 60% of a new one, get the new one. the fact it is 11years old, makes this an easy choice. good luck.hope this helps..
Feb 22, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Is my Toshiba MW27F51 TV Digital?
pretty much if the television is older than a year-it probably has analog tuner. you can buy digital box (add-on) i have one and it does make picture nice. about 40.00 bucks. i'm ot sure if they still offer the card that gives you a 40.00 dollar off. look up digital converter box. good-luck, hope this helps!
Feb 21, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba MW27F51
There could be a number of reasons for that. The High Voltage (Flyback) could be loose or going bad. only and experienced tech wouls wanna go in there because of the high voltage that needs to be discharged. Or a cracked circuit board or cold solder connection could cause this.
Aug 25, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Straight line
You need to replace the vertical output transistor. part are available online at www.digikey.com
Aug 24, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba Remote
you can buy a universal remote if the cost of a replacement is too high. hope this helps, good luck.
Apr 15, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba MW27F51
It is not clear whether one DVD or all DVDs play in black and white. If it is only one make sure that the format of the DVD is correct. If it is all DVDs, given that the VHS tape and cable play with color, there could be a problem with the chroma circuit in the unit. This is probably something that a technician would need to diagnose. Good luck.
Jun 30, 2006 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba MW27F51 27 in. TV/VCR/DVD Combo Logo
258 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
