Question about Kodak i610 Scanner Bitonal Duplex Scanner
I need a part number for a power switch to the Kodak i610
This scanner only powers on when you play with the power switch
  • Andre Velez
    Andre Velez Mar 12, 2012
    We buy, sell and trade; new, used and refurbished scanners. Call me about the Kodak i610. Andre 855-420-8273 ThirdWindTechnologies.com
    Problem Solver:
  • 7 Answers
Call KODAK PART at 800 431 7278(PART) Customer service will look up part# and price for you.
Posted on May 14, 2009
  • 463 Answers
Does this thing have a conventional SPST power switch? If you know that is what is wrong, just open it up and mount whatever sort of power switch you want in there, so long as it meets nominal power requirements...
Posted on Feb 27, 2009
Why does the scanner keep turning off after 30 minutes with a red light? We have to keep manually turning it off and on.
Some kodak of the i2000 series abide by different energy conservation standards. You can increase both power off \ sleep settings to 240 (4 hours), maximum. Unfortunately when the newer energy conserv's go have to be power cycled to resurrect. I have a tiny text script I can send that will make the 2400 never turn off I'm just not around my PC right now. Stay tuned!
Oct 20, 2014 | Kodak i2400 - document scanner
My kodak hero 4.2 won't power up?
Hello, First check to see that the power plug has power. If it does then make sure the power cord and seated correctly into the back of the printer. Reseat the power cord and try the power switch. If that doesn't work, will have too replace the power cord. If that doesn't fix will have to take in for repair or call kodak tech support with model and serial number and walk thru trouble shooting.
May 17, 2014 | Kodak ESP 5 Printer
"cycle error" - scanner powers up ok but will not scan due to this error ID=055
Error 55: "Lamp I2C error reading from DAC". Operator log message: "Cycle power, if problem persists, call service.". This error is involves communication errors between the LED AY and the DAC. A couple things can be done to alleviate this issue but unfortunately, as a user, you can only perform the first step. The other steps require a Kodak Field Engineer to complete. First step, upgrade your Firmware. Firmware updates can be found at the following web page: http://graphics.kodak.com/DocImaging/US/en/Support_Center/Document_Scanners/Production/i5200_Scanner/Support/Drivers_And_Downloads/i5000_Series_Scanner_Firmware/index.htm. If you still experience issues following the firmware upgrade, call Kodak Service & Support to schedule a field engineer to be dispatched to your site.
Mar 03, 2014 | Kodak i5200 Document Scanner
Troubleshooting
It's not rollers. Try taking the glass guides out and cleaning them. Then calibrate. If that doesn't fix it then cleaning mirrors in cameras is next step.
Jan 31, 2014 | Kodak I610 Path-Through Scanner
Kodak i2400 scanner goes into sleep mode after 1 hour
Open the Scan Validation Tool. Select TWAIN / KODAK i2000 Scanner. Click the setup button (top left icon). Highlight Default. Click the settings button at the bottom after highlighting Default. Click Device. Power Saver / Power Off values are now shown. Maximum setting is 240 (4 hours).
Jan 27, 2014 | Kodak i2400 - document scanner
Printer error code 6202 when I start my printer
I unplugged the power supply several times. So far it seems to be working.
Jan 15, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Nov 07, 2009 | Kodak ESP 5 Printer
Error 5
I can't seem to find a error code 5. What software are you using to scan? Did the error start right after your first? Had the scanner been working?
Jul 12, 2007 | Kodak i40 Path-Through Scanner
89 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
