Question about Equator EZ 3600 CEE Front Load Washer / Dryer
Hi i ahve an equator ez3600 washer dryer unit
Hi i ahve an equator ez3600 washer dryer unit that leaks water under the right front side and i need to find out what it is from or have someone come out and check it for me
it is not the lint trap , and it leaks more on a cold wash cold rinse cylcle..less on a hot wash cold rinse
any ideas?
  • VBCAL May 03, 2009
    My floor is slanted, so my leak appears at the front right, but could be flowing from the back of the machine. The leak appears after the wash cycle, not during.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 37 Answers
It may have been leaking from the drain pump and you may want to check if it the drain pump by opening the back panel and checking if it leaks just when the drain pump starts to function.
Posted on Feb 26, 2010
My equator clothes processor ez2500 is leaking water from the bottom..where can i get parts to fix it?
Please contact Appliance Desk or Equator to get Tech Support & Parts for your machine. their contact no is 713 464 3422 or 713 464 3858 Ext 186 / 175
Sep 23, 2012 | Equator EZ 3600 CEE Front Load Washer /...
I need a drive belt for a Ez3600 C
You can get the belt from Appliance Desk, their number is 800-490-8018
Let me know if you are able to get the belt.
Mar 12, 2010 | Equator EZ 3600 CEE Front Load Washer /...
Someone know this item equator ez3600 all in one is washer & dryer in one
Yes, the equator EZ3600 is a combo washer dryer, which washes and dries in one unit.
Jan 05, 2010 | Roper RAB2121KW Top Load Washer
Problems Drying Clothes
That's the way it works, kinda stupid, it would be good if it did that at first to loosen up clothes in case they're stuck to the drum but then move like a traditional dryer but that's just the way it is. BTW, here's a website with parts for it in case you need them. I never used them but just found them, I was lucky I never had any problems with my equator until now but I kinda can live with it (during rinse cycles it pumps water out but then when it does the short spins it does not, so rinsing is not as effective sinse it leaves a lot of dirty water in and then puts fresh water in and does it again, it does pump the water out during the final spin cycle though). Anyways, good luck. I bought mine in 2001 or 2002 and never had any problems except for the one I mentioned.
Apr 25, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Cold water valve
Hi Yes I fixed it myself! lol I just tried every combo of wires that there was, and it is working gr8! Ty so much though, for having a site like this! I even called the Equator company and they could.n't tell me! Again it is fixed and thank so much! Rose
Apr 01, 2009 | Equator EZ 3600 CEE Front Load Washer /...
A lot of water remains in machine at end of wash cycle
The drain pump might have gone bad, check if the drain pump is making some kind of noise and also check if the drain pump is not obstructed.
You can open the coin trap on he right hand side bottom of the unit and clean the same for any blockage.
Nov 27, 2008 | Equator EZ 3600 CEE Front Load Washer /...
Washer is leaking
Hi just went through the same thing... so you can tell if it is the pump take off back support... run it through a cycle and when it drains you will notice the pump turn on and if the water is leaking from the middle of pump the housing is worn out. You can get the part from appliance desk. Equator sold all of the repair stuff to them . parts@appliancedesk.com ask for Garry don't be suprised if the part is backordered from Italy. It took me 6 weeks to get my part. Good luck happy new year
Nov 17, 2008 | Equator EZ 3600 CEE Front Load Washer /...
My washer some times its leaking water
Plug off the wall socket. Open up behind & top after taking off the plug from the mains wall socket. Check to see if there is hose loose or torn from where you think the leak is from. It is also possible that one of the hoses to your dispenser drawer has come loose, and the water trickles down to the left area, you should check this also. Tighten or replace as necessary.
Apr 08, 2008 | Equator EZ 3612 CEE Front Load...
How do you unclog the drain hose on the Equator EZ3600?
you need to open the back and unscrew the clamp to take the drain hose off. if you are lucky, that is the problem. there is another hose that could be clogged between the filter and the pump which is more difficult to get to. or it may be that the pump needs to be disassembled and cleaned to get rid of any obstructions. or you may need to replace the pump entirely. service for these appliances is rather expensive...at least in ny. good luck.
Dec 09, 2007 | Equator EZ 3600 CEE Front Load Washer /...
Equator EZ 3600 CEE Front Load Washer / Dryer Logo
192 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
