Question about Compaq Presario 5240 (353200-003) PC Desktop
Used Compaq Presario 5240
I need an owners manual to cross check all the hookups and settings. The CD-ROM will not open, the Floppy disc drive (A) does not respond. I think they were all unhooked before it came to me. How can I find a guide to check all the connections?
Seriously, Stephen Beale
    President:
  • 2,653 Answers
They're all here:
HP Manuals
Posted on Feb 27, 2009
  • Compaq Master
  • 19,396 Answers
Yo will probably need to download and install the drivers.
Check that cable for floppy and CD rom are not connected in upside down.
You find some documentation and all the downloads on compaq support page for this desktop:
Compaq Presario 5240 Desktop PC
NTLDR compressed on a Compaq Presario SR105CL cant enter bios to set to boot
Step 1:
Which operating system ?
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT.32 New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. b> Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer. If you are attempting to BOOT from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt. If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive. Second, when the computer is booting you should receive the below prompt. Press any key to boot from the CD
Mar 10, 2013 | Compaq Presario sr1055cl PC Desktop
I have a presario 5240 when I try to use the restore disk it loads until the end then I get a ERROR # 108 Partition doesn't end at end of cylinder What does this mean?????
Event ID 108
Failed to apply changes to software installation settings. Software changes could not be applied. A previous log entry with details should exist. The error was The installation source for this product is not available. Verify that the source exists and that you can access it. Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps you
Nov 03, 2011 | Compaq Presario 5240 (353200-003) PC...
Compaq presario cd-rw/dvd-rom combo drive does not recognize dvds. the driver is installed but dvds do not play.
you may check youe BIOS settings by restarting the pc and repeatedly press F2. Then check your PC or system settings wherein there is a list of peripherals such as Floppy Disk, CD/DVD drive, Network Adapter etc. Those peripherals will tell you if they are enabled or not. use your arrow keys to select and check if the CD/DVD drive is enabled. Then press F10 to exit and hope that CD/DVD would work...
Nov 01, 2010 | HP Compaq Presario SR1610NX (ED865AA) PC...
CD drive refuses to open or run even when I press the button
Select a cd rom device,then add another boot up disc,then see if it opens.Will it take a cd rom better than a floppy? If so use the boot up disc,rather than an older and possibley more damaging floppy.
Feb 16, 2010 | E-Machines eOne 433 PC Desktop
Dvd will not burn to disc
replace the drive with a standby n see..
..contact ur System Admin/Vendor
Oct 27, 2009 | Compaq Presario 5000 PC Desktop
Compaq Presario 5200CL: CD Drive will not open when told to or when button is pressed on tower. Tried to burn data on a CD-R, but when completed, wouldn't open... Drive works, info on disc, just can't get...
There is a small hole on the CD-Rom you can straighten out a safety pin and push it in there. It will eject the CD. Hopefully it will then fix your problem.
Sep 20, 2008 | Computers & Internet
How can i get rid of the compaq logo even after i format my hard drive .
The screen that I think you're referring to is the OEM BIOS splash screen.
This particular logo / image has nothing to do with your hard drive... it is embedded on a physical chip (EEPROM or ROMBIOS) on your motherboard.
It is possible to make modifications to this particular splash screen (through a hardware hack), but I don't recommend doing it. The screen shouldn't be a problem; it sounds like you might be experiencing a "Boot Order" issue.
I'm assuming you might be having problems with the Boot Order if you're having issues with loading your OS from CD. When you have the Windows CD in the CD ROM and you reboot the system, you should see the following message flash up on the screen (immediately following your OEM BIOS Splash screen):
"Press any Key to Boot from CD..."
If you don't see this message and your CD ROM Doesn't spin up and begin to load windows...you might have a Bad CD ROM, bad CD "Disc" or...you might not have your BIOS Boot Order set up correctly.
HOW TO FIX IT:
To get into the BIOS Setup on a Compaq Presario system, do the following:
When the OEM Logo Splash screen appears, press F1 to enter the BIOS Setup.
Note: On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
To change the Boot order:
Here's the URL for Compaq's Online FAQ for Changing the Boot Order:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07110&lc=en&cc=us&lang=tr&man_lang=en&product=1843681&dlc=tr#N1310
Try changing the Boot Device Priority in the BIOS Setup: Make sure that the "CD ROM" entry is moved "Before" the entry for the Hard Drive and Network PXE:
Example Boot Order:
  1. CD ROM or Removable Media
  2. USB
  3. Floppy (if you have one)
  4. Hard Drive
  5. PXE (Network Boot)
This should help you load the OS successfully from CD (if you're not being presented with the "Press any Key to Boot from CD..." notification when rebooting with the Windows CD in the CD/ROM drive.
Please repost if this fixed your problem and rate my response!
Good Luck,
LounaTech
Apr 17, 2008 | Compaq Presario SR1800NX Desktop PC
COMPACT DISC,RECORDABLE DOOR KEEP POP UP BY ITS SELF.PLS HELP ME TO CLOSED IT SO THE DOOR DOESN'T POP UP BY ITSELF
you may need to replace your cd-rom drive, you can try buying a new cd-rom drive for around 30-40$ which also will mean you'll have a DVD-rom instead of cd-rom.
thanks
Thomas
Nov 11, 2007 | Compaq Presario 5000 PC Desktop
Removing the faceplate
Hi, I can help you with this. Are you trying to remove the cd-rom drive bay plate or the front panel of the tower?
Sep 16, 2007 | Compaq Presario 5000 PC Desktop
Compaq Presario 5360 Cd rom is Full
A CD-ROM drive is a read-only drive. It will always says there is 0 usable space, since you cannot write to it. You need to have a CD-Writer in order to add content to either a CD-R or CD-RW disc. You would get the "not accessible" error message if there is no media in the drive. If you place a disc in the drive, that message should go away.
Oct 20, 2006 | Compaq Presario 5360 (117744-004) PC...
Compaq Presario 5240 (353200-003) PC Desktop Logo
169 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
