Question about Nikon FG 35mm SLR Camera
Film speed dial is stuck. Won't turn How do I fix this
    Problem Solver:
  • 17 Answers
You should have a small chrome button near the film speed dial. Press & hold it down while turning the film speed dial.
Posted on Mar 07, 2009
How to change the shutter speed on my nikon n65 film 35mm slr camera
In the manual and shutter-priority modes (set the dial to "M" or "S"), turn the command dial to change the shutter speed. In the aperture-priority mode (set the dial to "A"), turning the command dial changes the aperture and the camera will set the shutter speed appropriately.
If you need a manual, you may download a copy from here.
Oct 13, 2012 | Nikon N65 35mm SLR Camera
How do you adjust the ASA film speed dial on Pentax ME?
Lift up the dial and then turn it. Refer to page 11 of the manual.
Jul 03, 2012 | Photography
My 645 1000s shutter buttons wont pop back up.this is my 1st mamiya
You might want to check and make sure the battery is still good. If you purchased the camera used and didn't change the battery then this might be the case.
But in the mean time this is what you need to do:
1st-make sure that the shutter speed dial is set to any shutter speed other than the red circle w/red ring. If your camera is set to that it will drain your battery when not in use since it is designed to be an automatic setting. I set mine to 1/125th to do this push in the circular dial on the side and at the same time turn the knob.
2nd- locate the 2 levers on the opposite side of the shutter speed dial. Once you found them then position the back lever all the way forward towards the setting for "MULTI" and position the lever towards the front straight up.
3rd- then wind the film crank till it won't wind anymore and depress the shutter, if it is wound and the shutter release is still stuck then skip to the fourth step, if something happened and you heard a click then still proceed to the next step because no the shutter release will be temporarily stuck.
4th-Once both of these levers are in this position there should be a red button just behind the shutter release button on the top right side of the camera.... drum roll please...."Push the red button" what you should hear is a rather loud click, this click is the mirror releasing allowing you to: 1 wind the film crank and take another picture and 2 this also now allows you to see through the lens again (assuming that you have a lens on the camera).
In Conclusion: without a battery that is fully functional in the camera this is how the camera will operate once you get a battery for your camera then reposition the levers on the side of the camera opposite of what I suggested (this will be the normal operating mode for the camera with a battery) then when you wind the film crank and depress the shutter everything will function normally.
Jul 12, 2011 | Mamiya Photography
Ok, so I got the instructions on using my Polaroid 340 camera. I understand all the instructions, have loaded the film correctly but am uncertain on settings for the film speed. I am using 100 speed film ...
Try replacing the battery. It sounds like the shutter is not opening at all. Setting the speed to 150 will not make it better, rather the reverse, but you still should get an image.
Nov 29, 2010 | Cameras
Ive just loaded a film, following the instructions, shut the back and wanted to advance the film, but the lever wouldnt extend the full way, it only goes to the on position
I have the same problem with a Nikon F2, got it off my grandfather and its been in his attic for at least the last 10 years. I don't know if parts have seized up or if im doing something wrong. have put in new batteries, but film advance lever won't go past "on" position. have tried pressing shutter but it doesn't help. Also film winding knob will not lift up enough to load in a film! any solutions!?
Aug 21, 2010 | Nikon FE 35mm SLR Camera
My Nikon FE film advance lever is stuck. It does not move at all, there is no film in the camera. The repair shop wants $100 to fix it which is more than the camera is worth I think. I would like to do...
Have you tried fresh batteries and setting the shutter speed dial to M90 or m250 whichever you have? If this does'nt work you can remove the camera bottom plate and gently pull a lever away from the advance cog. Some times things get out of sync in there. Sorry I can't be more specific but I did this many years ago. Good Luck.
Dec 12, 2009 | Nikon Photography
Dials not working
You may want to try resetting your Cricut to see if that fixes the problem. To reset the Cricut machine, turn the unit off for five minutes. Roll all the dials all the way up and all the way down five times each. Turn the Cricut back on. This is the manufacturer's reset process. Good luck!
Mar 13, 2009 | Provo Craft Cricut Disney Font Cartridge
Instruction manual for settings on a Nikon F2?
Set the film speed with the dial on top of the Photomic unit. Lift the chrome ring and turn so that the film speed is next to the little red arrow.
Yes, the aperture is set by the lens ring. And if you have one of the older finders which uses the prong meter connection, whenever you mount a lens you must turn the aperture ring all the way to the highest number, then back to the lowest number. For old-timers, this is known as the "Nikon twist". It tells the meter system what the widest aperture of the lens is so that it can measure light properly at full aperture.
Yes, the shutter speed is set by the dial on top. The Photomic meter sits on top of it, so you read the shutter speed from the scale on the side of the Photomic dial by the mark on the back.
The other buttons on the front are the lens release button (left side as you hold the camera), DOF preview (button just under shutter release), mirror lock-up (lever ring around DOF button) and self-timer (long lever at bottom).
The T-L ring serves to protect the shutter release from accidental push. If you lift the ring and turn the mark to L, the shutter release is Locked. If you lift and turn to T, it prepares the shutter for Time operation, where the shutter remains open when released without holding the button down as you do at the B speed setting.
Finally, the most help: you can download the manual for free (donation requested, and worth it) at http://www.butkus.org/chinon/nikon/nikon_f2_photomic/nikon_f2_photomic.htm
Feb 08, 2009 | Nikon Photography
Exposure button stuck and will not work
Depress & hold the button near the film speed dial and set the dial to 60 or 90 which ever speed it shows in a different color than the others as seen. This make unlock the shutter
Dec 22, 2008 | Nikon EM 35mm SLR Camera
Film speed selector stuck
Try to rotate the lock body anti-clockwise. Do not use muscle power, just try to rotate softly the locking body.
Oct 10, 2008 | Nikon FE 35mm SLR Camera
Nikon FG 35mm SLR Camera Logo
164 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
