Question about Lexmark X1240 All-In-One InkJet Printer
How do i copy something - Lexmark X1240 All-In-One InkJet Printer
  • CuLeBrO
    CuLeBrO May 11, 2010
    What do you want to copy and where?
    ie. want to copy a textin word  and paste it in other place?
        want to copy the content of a CD into another?
All i want is a manual for this lexmarkx1240 so i can hook up the copier,fax,and see how to put the ink cartridge in.please eamail me back the the price of the manual and iwill pay for it.ermail address is alabrave at knology.net.
thanks
Posted on Mar 02, 2009
How do I restore the copy and paste function on my apple tablet?
you cant remove the function, its something apple automatically has, remember not all things can be copied tho and some may not be recognized for example if you copy something from fb it may not be supported in another app to paste
Aug 27, 2017 | Apple Tablets & eReaders
Sharp mx 3500 has no copy output when copy is made
There usually isn't anything on the screen when you are copying something. If you are scanning something, that is different. However, copying doesn't have an output usually. If you are referring to the copied piece, then you will need to check the ink and device itself.
Elisa Jed ' http://www.abcoe.com
May 20, 2014 | Office Equipment & Supplies
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
When making a copy on our Canon copier (super G3; image class MF4150) we are getting a vertical black line down the entire length of the paper. Is there something we can do to fix it? SG
You can fix this yourself by cleaning the scanner glass. When you insert a document to make a copy it is pulled in and travels over a thin strip of glass. When something gets stuck on this glass it is read or scanned as a solid line. What you need to do is make a copy. Then put that copy in the feeder the same way you put the original document in. Now the line on the copy will "line up" with the area of the glass that has something stuck to it. Use this as a guide to pop open the feeder cover, locate the glass and clean it with a cloth dampened with a bit of glass cleaner. Once you have it cleaned just run a copy again and the line should be gone. Sometimes a small flashlight helps to locate the glass.
Good Luck and Thank You for using Fixya.
Sep 02, 2010 | Office Equipment & Supplies
Where do i put the paper for it to copy something
You print from the internet or you copy it to your computer then print.
Nov 19, 2009 | HP DeskJet F380 All-In-One Printer
Machine over heated now the copies are black
Do the copies come out totally black or just dark???? Does the copiers scanning lamp turn "ON" when you go to make a copy? If you smell something burning, you may have paper wrapped around the upper fixing roller...
Apr 28, 2009 | Sharp AL 800 Copier
How do i copy something?
PLACE THE PAGE TO BE COPY DOWN THE SHOOT ON THE MACHINE AND PRESS COPY. THEN YOU WILL BE DONE GOOD LUCK
Feb 02, 2009 | Brother IntelliFAX 2800 Laser Fax
Customers get my faxes with a line and when I print a copy, I as well get a thick line and 2 thin lines on my copies. I have an HP officejet 6210 All in one. R0037 Service ID # 17039 Serial #...
hello
try and put a clean sheet of paper on the scanner glass and make a copy of it.
if the copy has lines on it and the copy glass is perfectly clean, no streaks or scratches on the glass where the lines appear on the copy.
check on the internal optics and sensor for something on them. if they are perfectly clean then the sensor or the internal logics have a failure and need replacement or repair.
i truely hope there is a piece of lint or paper or something somewhere in the light path so all you have to do is clean it up.
norm
Nov 06, 2008 | HP Office Equipment & Supplies
Black dusty line on my copies
You mentioned when you copy.
If you just have it print with out doig a copy (like have it print an internal report or what ever) does it do the same thing?
If it does (and I'm assuming that this is a laser printer) change the toner cartridge.
If it doesn't, then there is something on the glass area that is causing the streak. Clean the glass with vinegar and water solution (not sopping wet, just damp on the rag) and dry. Test again.
Sep 26, 2008 | Ricoh Office Equipment & Supplies
Pasteing and how it works
If you mean pasting in relation to cut / copy & pasting
How it works
When you cut or copy something, for example text, it is saved into the clipboard. Then when you paste, the text that is in the clipboard gets pasted. You can paste that same text more than once, it stays in the clipboard until it is over written (by cutting ot copying something else) or you restart your PC.
How to use it
There is a couple of ways to cut / copy & paste
1. Use right clicking menu
you can select something, some text for example, then right click on it with your mouse and select Cut or Copy. To paste right click where you want the text to be pasted and select Paste
2. Use application's Edit drop down menu
you can select something, some text for example, then select the application's Edit drop down menu and select Cut or Copy. To paste click where you want the text to be pasted select the application's Edit drop down menu and select Paste
3. Use keyboard shortcuts
you can select something, some text for example, then press Ctrl + X to Cut or Ctrl + C to Copy. To paste click where you want the text to be pasted then press Ctrl + V to Paste
Hope this helps
-Magnon
May 10, 2008 | Computers & Internet
Lexmark X1240 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
