Question about Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Advent tv LC15y26 wont connect with stalite box
My Advent tv won't connect with my satalite box. when I press input it saws no input for d sub, video, YPbPr. When unput is on TV it shows a blank screen. When I change channels it show static or lines. How can I get it to show the picture again. It was fine 1 week ago, but I must have hit the wrong button when I went to turn it on manually.
2 Suggested Answers
  • 8457 Answers
SOURCE: I have a 15 inch Advent LCD TV in my kitchen. I
U have vertical lines for a few second.That mean u tv have a dead board call the T-CON decoders is board.This T-CON decoders board sit at the bottom wright in the middle of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Posted on Dec 11, 2010
Disk remote control need code for Advent tv
1157 1027 1011
1298 1081 1080
Check these codes. If you wish to get more, check these sites. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 21, 2013 | Recoton Advent Advent Q2035A 20" TV
Advent tv displays green
If you are saying no red: The model indicated here Recoton Advent Advent Q1435A TV is a 14 inch set.
first it may be cheaper to replace than repair--That said if no red look to the small circuit board at end of picture tube (it plugs onto the tube).
It will have either individual output transistors or a single IC.
What (if only one color missing) I would look at is the bottom side which faces to the rear---a circle of solder connections--possible one is broken--there will be one for each red, green, and blue--not always easy to see but if any of the solder connections look cracked or even broken loose-----
Mar 28, 2012 | Recoton Advent Advent Q1435A TV
Hello, i have a sanyo lcd tv & i want too connect my Advent Laptop to it, but i dont know what cable to use because my laptop doesnt not have the HDMI port or the VGA port.... help?
Does your TV have an S-VIdeo input? Does your TV have a DVI input?
What model of Advent laptop?
Does your laptop have a S-Video output socket (looks quite similar to a PS/2 mouse-socket) ?
Does your laptop have DVI-output?
Aug 03, 2011 | Computers & Internet
I can only get channels 600 through 900 which I have never see before.I cannot get regular channels or cable channels.It is not a flat panel t.v.Q1435A is the model number
Hi -
If you have a cable TV line connected directly to the TV, an antenna or a cable box connected by coaxial cable, I would suggest running the automatic channel scan (AUTO-PROGRAM) again:
1. Press the AV key on the Advent remote control repeatedly until TV is displayed in one corner of the TV screen. If you don't have the Advent remote, use the TV/AV button on the front of the TV.
2. Press the MENU key on the advent remote or the front of the TV to open the on-screen menus.
3. Use the CH+/- keys on the remote or on the front of the TV to highlight PRESET then press VOL+ to select.
4. Use the CH+/- keys on the remote or on the front of the TV to highlight ANTENNA then use the VOL+ key to select either AIR (for antenna) or CABLE.
5. Use the CH+/- keys on the remote or on the front of the TV to highlight AUTO-PROGRAM then press the VOL+ key to start the automatic channel scan.
Once the channel scan is complete, the TV should automatically return to viewing the first channel found during the scan. Do not press the MENU key during the scan or the scan will not complete.
If you are using a cable/satellite receiver and it is connected to the TV by any means other than a coaxial cable, you do not need to run the channel scan. You should simply select the correct AV input using the AV key on the remote or the TV/AV key on the front of the TV (see step 1 above).
If you have done all of the above and you are still unable to get the channels on your TV, please post back for further assistance. You can reply to me by clicking on "Add a Comment" below your question. Please let me know whether you are using a direct cable line, antenna or cable box, etc.
Regards,
BElectric
Mar 26, 2011 | Televison & Video
I have an Advent Television Model Q2035A and would like to know if I am going to need a converter box for it? I have an old timey antenna that rises above my house' roof. The wiring on it is spliced for...
Yes you will most certainly need a converter box. At Radioshack you should still be able to get the piece that you would attach the spliced wiring to.One side of the piece I'm talking about has a screw for each one of the Y shaped spliced ends to attach to. Sometimes there are two places to attach things and sometimes there are four so buy the one that best fits your needs. Then the other side of the piece has the male part that will attach to the female antenna in part on the converter box. Then a cable goes from one of the outs on the converter box to one of the ins on the television.
Jan 25, 2011 | Recoton Advent Advent Q2035A 20" TV
Hi i bought a advent surround sound and it only works on the television it dose not seem to work on my playstation 3 i woul be very greatfully if you could help me. thank you
have you connected the advent surround system to the tv so it plays what the tv is displaying or do you have the advent connect to the tv reciver (sky, tevo, whatever)
Dec 19, 2009 | Sony Playstation 3 (PS3) Console
Connecting to tv
Use the TV's remote-control to select "input" from the S-Video port, rather than from the TV's own tuner (or from your cable-box).
May 31, 2009 | Advent Netbook
TV shuts off after i press input button
Hi
you have defective power oscillation in Hot area, and you have defective vertical output change the vertical output...
Thanks!
Dec 13, 2008 | Recoton Advent Advent Q2035A 20" TV
Advent universal remote
You can also search for codes with out list.
switch on the power button manualy.
Press the program button on the remote press tv button and then channel up or down button. then the led on your remote will start blinkoing. when it reaches the correct code your tv will be switch off .then press program button once more or your remote.
Please try this option....
Feb 17, 2008 | Recoton Advent Advent ADR-560 Remote...
Connection
hi, you can now buy a box that can take upto 5 hdmi inputs to plug into your tv, i'm sure your local game shop will supplie them, if not search on ebay. hope this helps
Feb 09, 2008 | Sony Playstation 3 (PS3) Console
Advent LC-20H15A 20 in. EDTV-Ready LCD TV Logo
268 people viewed this question
Top Advent Televison & Video Experts
Are you an Advent Televison and Video Expert? Answer questions, earn points and help others
