Question about Toshiba FT8930 Cordless Phone
Can't reprogram date and time in toshiba ft-8930 cordless phone
3 Suggested Answers
SOURCE: Reprogramming the date for daylights savings time.
From extension 10 or 11
feature 00
left intercom
left intercom
#126
press the 2 button
feature 00
That will disable it.
Posted on Jun 03, 2008
SOURCE: set time and date on bt synergy 3505
to set the time the instructions are on page 9 of the instruction manual in the getting started section.
in case you no longer have the manual....
1. press the tick/menu button twice.
2. press 0 and you hear 'to set the day and time press Star, to hear the day and time press Square.
3. press star. you hear 'please enter new day and time after the tone' enter the day (1=sun, 2=mon etc) enter the time using 24hr clock.
4. press the X/security button twice to exit.
hope this helps.
Posted on Oct 28, 2008
  • 1340 Answers
SOURCE: Toshiba FT-8809 cordless phone. It is stuck on
Here is a link to your manual.You do not have to sign up for anything and there is no junk after.Click download,then enter the 5 digit code and press download again.It will open a menu.If you want to save it permananetly click save.It will most likely save to your documents folder.For 1 time use click run.It may not be the exact model number as yours but this is common among manufacturers.They start with a manual for a model,then add model numbers as they progress.It starts with the same basic numbers though.It should at least look very similar.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Good luck,Greg
Your solution is on page 22.If this is not how your set is configured,let me know and it may need to be changed within the handset.I will let you know how to do that if this isn't it.If this is correct and it still doesn't work,you will need repair.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
.ExternalClass .ecxhmmessage P {padding:0px;} .ExternalClass body.ecxhmmessage {font-size:10pt;font-family:Tahoma;}
Posted on Dec 13, 2010
Can't set date & time for Panasonic cordless phone GX-2711SAM
Still error ,handset registration fails although keep on trying step 1&2 in my kx-tg2360jxs panasonic cordless phone , what shall i do ? Shall i change handset batteries ? Really i got bored , is their any one facing my problem ? Help me please
Jan 05, 2014 | British Telecom Synergy 2110 Cordless...
To set date and time on answering machine of a vtech cordless phone
Now that you've finally gotten around to specifying the model of your phone, follow the instruction on page 14 of the CS6429-3 manual.
Sep 14, 2012 | Vtech DECT 6.0 Cordless Phone with Digital...
I need to reprogram my 5655 so that the correct date and time is announced by the system
The time and date is set at the base unit.
Press the TIME/SET button
Press the TIME/SET button again
Press the CHANGE button until the correct day is announced
Press the CHANGE button until the correct hour is announced
Press the CHANGE button until the correct minute is announced
Press the CHANGE button until the correct year is announced
Press the TIME/SET button to finish and the current clock setting will be announced
You can hold the CHANGE button down when setting the minutes or year to increment in steps of 10. Following is a link where you can download the manual.
http://att.vtp-media.com/ecp/documents/product_Product/614/UserManual/2041/e5655_manual_bkm.pdf
Feb 25, 2011 | AT&T 5655 Cordless Phone
Blinking date and time on base of GE 27909EE1 Cordless Phone
Are you in a 'thick' building that may be preventing the phone from getting the date/time set signal? If so, try plugging the phone in as close to a window as possible to eliminate any possible interference.
Dec 03, 2008 | Uniden Cordless Phone
Answering machine is flashing CL after I lost power
set the CLock by holding down the buttons on the side of the answering machine - top button for day, middle button for hour, bottom button for minute
Sep 25, 2008 | GE 25932 Cordless Phone
feature 00
left intercom
left intercom
#126
press the 2 button
feature 00
Apr 09, 2008 | Avaya Eurostyle 18D Corded Phone
Lost pin
Try this: Press MENU 3 times The LCD should show the current code. I found the user guide for a close model number. It should be of use to you: http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/Telephone/Ft8981.pdf
Jan 19, 2007 | Toshiba FT 8989 Cordless Phone
Toshiba FT8930 Cordless Phone Logo
Top Toshiba Lands Phones Experts
george  peters
george peters
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
