Question about Maytag Dryers
Dryer quit middle of drying
I have a maytag performa eletric dry and about 20 min into the drying cycle the dryer quit working. any suggestions?
  • 4 Answers
If proper voltage to appliance then faulty thermal cutout. Part number LA1053.
just to confirm remove the two white wires from thermal cutoff and jumper them together, be sure no wires are touching any part of base when doing this.. If fires up then install the LA1053.. check vent usually this causes this part to fail...
Posted on Oct 17, 2012
  • Maytag Master
  • 3,361 Answers
Verify 220 volts to the terminal block where the cord attaches.
Check the door switch for continuity.
Check the thermal fuse on the right hand side of the heating element just below where the heater wires connect.
You may need a flashlight to see this fuse.
It most likely is the thermal fuse.
If so correct any vent blockage or you will blow another fuse.
The fuse comes in a kit including the hi-limit switch.
Replace them both.
Posted on Feb 28, 2009
My Maytag Performa dryer is taking 2 and sometimes 3 cycles to dry clothes. Suggestions as to why?
Most of the time the dryer blower wheel part number 53-0106 gets loose and and cause this problem. I fixed one just the other day.
Feb 24, 2010 | Maytag Performa PAV2200
Machine works but does not dry cloth no hot air drum? maytag performa
Chek closely all the tube going from in to out of ur dryer clean all ur filter even the furnace oune! check ur wirring, if all faisl dry nothing in ur machingr for one cycle. they wil { i hpoe
Nov 19, 2009 | Maytag Performa PAV2200
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
Smells hot. does not dry. sticks on 20 min all cycles
just a quick suggestion
check your exhaust outside for proper airflow
Oct 11, 2009 | Maytag Neptune MDE7500AY Electric Dryer
My dryer will only work on the timed dry cycle only and still takes along time to dry did clean it out by lifting the top up can't get the back off because of the fake screws. the dryer is a performa model...
check to vent or remove the vent and see if it will work...if the vent is plugged it will take a long time to dry and sensor dry will not work...
Sep 19, 2009 | Maytag Dryers
Maytag performa gas dryer no longer produces heat.
needs a new timer switch sometimes cheaper to buy another dryer (used)
Dec 02, 2008 | Maytag Performa PAV2200
Maytag performa dryer vent got clogged and quit working
maytag performa dryer quit in middle of drying.
Dec 01, 2008 | Maytag Performa PAV2200
Dryer stopped working during cycle
is dryer drum turning u might be amotor are some other problem you may want to call a service tech to fix your dryer ok
Oct 21, 2017 | Maytag Performa PAV2200
Rumbling noise
Time to call GHOST BUSTERS!
Here is a good service!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 22, 2008 | Maytag Performa PAV2200
Quit working
This happened to me (as mentioned above) and I just need a new thermal switch. Easy to replace yourself.
Mar 23, 2008 | Maytag Performa PAV2200
Dryers Logo
139 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
