Question about Comdial 8324S-PT Corded Phone
Can not turn off fluttering intercom light. tried
Can not turn off fluttering intercom light. tried all codes...
    New Friend:
From extension 10 or 12, you press "ITCM", then press *#03.
Posted on Feb 05, 2015
  • Comdial Master
  • 2,460 Answers
You didn't try them all or it would have gone out :-)
IIRC correctly it's Inercom # from the operator extension (10).
If that doesn't work, post back and I'll actually read the manual.
Carl
Posted on Feb 27, 2009
Car flutters at an idle but does not die
My 96 Nissan maxima flutters when idling and also lights dim same time, it doesn't flutter when u first turn it on, but it eventually will
Nov 01, 2013 | 1994 Nissan Maxima
How do I turn the intercom off at an individual handset?
Do you mean intercom or paging? You can turn off paging by setting the Paging Deny code. From the intercom dial *7211 with 10 being the allow code. As far as the intercom, onlly Do Not Disturb (*7121) will fix that (as always change the 1 to 0 to allow). The DND light will light solid and when you press the button, the display will give you information as to what is set.
Carl
Jun 16, 2011 | Panasonic KX-T7630 Corded Phone
When i push the intercom then message button to retrieve messages it tells me invalid across the screen
while the handset is hung up (without pressing the intercom button) press the "MESSAGE" button, on the display it should show ~why~ the message light is on (cause it is possible someone tried to intercom you, then hit the wrong button) after that you can turn off your light by pressing:
1) INTERCOM
2) 700
3) *your extension #*
it is possible that the extension that turned on your message light is no longer in service, making it an invalid extension
Jan 06, 2011 | Panasonic KX-T7431 Corded Phone
Hello.. We have the parter-18D phone system. one of the phone rings when there is an incoming call, but it shouldn't, since this is not the main phone Ext 10. How can I program this phone to ring only...
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
May 06, 2010 | Lucent PARTNER18 Corded Phone
Car wont start
It is the battery - you must not have the cables securely placed on the terminals. The same thing happened to me a few months ago.
May 02, 2010 | 2006 Honda Pilot
Message and Intercom wont turn off!
Unfortunately, you cannot turn off the intercom or message waiting features. When trying to turn off the message waiting light, are you pressing the intercom key and entering # then 6?
Dec 22, 2009 | AT&T Spirit 6-Button Stard Misty Phone
How do you turn the ringers off on the phone?
Do Not Disturb (Feature 01) will turn the ringing off of a phone, but it will also send any lines assigned to ring on that phone to voicemail (if applicable).
OR, to turn ringing off in system programming:
From ext. 10 or 11, press Feature button, 00, left intercom button twice, right intercom button once. Enter extension number of phone you wish to remove the ringing line from. Light indicators next to line keys show ringing status. Press line keys to desired ringing preference for each line-
steady green light- immediate ring
green fast flutter- no ring
green slow flash- delayed ring
Press "feature" 00 to exit
Mar 06, 2009 | AT&T Lucent MLS-12D Phone
Can you tell me how to get out of SP-PHONE which has a red light
Under my Intercom light I have a green light (7731,7735). I'm not sure why yours is red, but here are a couple of things to try.
Press "1" on the keypad without picking up the handset. That turns off Background music and the display will say BGM On or Off.
Press Intercom or pick up the handset and dial 790. That's the extension reset code.
If neither one of these work, post back with the model number of the phone system cabinet the phones are plugged into. It's probably a Panasonic TA-624/824 but there's a chance yours is different.
Carl
Mar 02, 2009 | Panasonic KX-T7730 Corded Phone
I need to silence an extension on the lucent 18d telephone
From ext. 10 or 11, press Feature 00, left intercom (twice), right intercom (once), Dial ext. number of boss' phone. Lights on the line button will indicate ringing state for that line:
Green light - Immediate ring
Fast Flutter Green light - No ring
Slow Flashing Green light - Delayed ring
Press each line key until Fast Flutter Green light appears.
Press Feature 00 to exit programming.
Jan 05, 2009 | Lucent PARTNER18 Corded Phone
Comdial 8324S-PT Corded Phone Logo
198 people viewed this question
Top Comdial Lands Phones Experts
Starnley Johnwells
Starnley Johnwells
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
