Question about Fisher and Paykel DEGX1 Electric Dryer
Fisher & Paykel ED56 Dryer alarm on. Nothing else works
Power is on. High pitch alarm sounds, but nothing works despite uplugging and pushing all buttons etc.
  • Anonymous Mar 15, 2014
    Inglis dryer w auto cycle alarm
    Alarm does not sound when cycle complete
Replaced electric control panel. Looks like power spike fried the works
Posted on Mar 02, 2009
Fisher paykel dryer ed56
Could be the door switch or temp sensor. To check the door switch put pressure against the door and see if it stops. Check the slot the door hits to see if there is anything loose in there.
Jul 20, 2013 | Dryers
FPaykel Dryer model # DE05US2 is making a screeching LOUD sound ... still turns and dries just VERY VERY LOUD and high pitched squeeling
It could be bearing or guides in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 27, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Squeal when dryer turning
The problem is that your dryer needs a new drum bearing.
Jul 25, 2010 | Fisher and Paykel DEGX2 Dryer
Fisher & Paykel ED56 Dryer Motor Problem.
sounds like the motor is burned or the wiring!
Jan 01, 2010 | Dryers
Fisher ED56 dryer wont turn off!
HI, this will occur if the timer control module or control board has failed. replacing the timer or control will fix this issue.
thank you,
vijay (vote for me)
Sep 24, 2009 | Fisher and Paykel Dryers
Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Sep 08, 2009 | Dryers
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
High pitched noise
The inlet valve is faulty and needs to be replaced.
Nov 03, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel clothes dryer ED 54 -U
go back to the last thing that changed..."as soon as I put the unit back together"...what item may have pinched a wire during re-assembly....not saying it wasn't pinched before you started. I am saying there is a possibility of a wire pinched to chassis...an electrical short.
Jun 05, 2007 | Fisher and Paykel DG05 Gas Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
1,270 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
