Question about Viking VGRC485-6 Gas Kitchen Range
What to do when one of the burners on the ranges do not turn on
One of the burners on the ranges do not turn on
  • Viking Master
  • 2,892 Answers
HI the tap to the burner could be blocked might need greasing or the jets in the burner are blocked or the injector is blocked or the control switch is split and is turning on ths tap spindle
Posted on Jan 28, 2010
Gas range burners are sparking when one burner is turned on, how do I change the ignitors
It is common for all burners to spark when one burner is turned on. Of course only the burner you turned on will light.
Oct 01, 2014 | Kitchen Ranges
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
My whirlpool range ss630per-1 burners will ignite except of front right which give no ignitor sound at all, but the Rear Right works fine. any solutions?
Each burner control knob has a built-in switch that controls the igniter. It appears the front right burner switch in the knob is possibly defective. They are replaceable but it requires dis-assembly of the range front. Are all the igniters in a sequence? Have you tried turning the front right burner on while another burner has the igniter on. This may let you ignite the burner automatically. When you have another burner igniter clicking try turning on that burner. If the range has rectification igniters that will not work.
Sep 26, 2009 | Kitchen Ranges
Kenmore gas range
hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
Nov 06, 2008 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
Electric spark for gas range burner is non stop
Turning any knob starts the spark via a switch behind each which should disengage when the (any) knob is turn further.
One of your switches is stuck.
I think you should be able to remove the range-top for access and find the offending switch.
It is probably gummy from a spill and is no longer in solid contact with the cam that operates it.
A solvent/lubricant such as WD-40 sprayed on the plunger of the switch once you can see it and operating the knob back and forth should free it up.
It might be wise to turn off the gas supply while tinkering with the range - blow your house away and the range won't matter. :-(
Jun 19, 2008 | Viking VGSC306-4B Gas Kitchen Range
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Feb 05, 2008 | Kitchen Ranges
Viking VGRC485-6 Gas Kitchen Range Logo
172 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
