Back to:
Tags:
PreSonus Inspire 1394 Sound Card
Intel Core2 Duo and 1394 (by 2 users)
By herself - usenet poster
Has anybody else had problems with Intel Core 2 Duo systems and using
Presonus 1394 interfaces?
I've got a problem I'm trying to narrow down, and I think it is
specifically related to whatever 1394 drivers/interface is part of the
Intel Core 2 Duo systems. It seems like a timing or throughput
problem.
If anybody else has seen issues, please let me know...
Jonas
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by kakudmi, posted on Nov 14, 2007
I'm having a problem on my core2duo, all of a sudden, the sound coming from my computer going into the firewire port of the card, starts being choppy, like it's trying to buffer or something.
It sound distorted as well and it seems like the card is "overwhelmed" with the data input coming from my pc, because I have my guitar plugged into the card through the rca input on the back of the card and the signal coming from that input is fine.
It helps if I unplug the card and then plug it back again. but then after a while the problem comes back.
I hope someone's got a clue.
Thanks.
Kristijan
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Hart
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Even USB chips are specified as known to operate with certain
operating systems (and versions) and with certain chip-sets, etc.
For example, see the compatibility list on page 34 of the TI PCM2704
spec sheet: #
But then, Firewire seems even less "universally-operable" than USB.
Although Wikipedia claims that the 1394/Firewire port is implemented
in the 945PM chipset...
I couldn't find any evidence that 1394/Firewire was part of the
chipset from Intel sources. You could likely pin it down with
additonal research.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Intel Core2 Duo and 1394:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Brad
Rating: 0%, 0 votes
The interface/chipset is not apparent. It shows up only as OHCI
complient and its built-in. I tried chasing down the vendor ID that
it reports, but was a dead-end.
It is based on the Intel 945PM Express chipset, its a Dell Latitude
D820. I'm assuming that the 1394 part is provided by the Intel
chipset and generic drivers.
Everything works fine even with the Presonus box if I use an add-on
1394 card. Its only a problem with the buil-in 1394 port.
I am using a very precise audio measurement/analasys software package,
and with the built-int 1394 port and the Presonus box, I get pops/
clicks and timing issues.
If I use the add-on 1394 PCCard, everything works fine.
I think that should prove that the problem isn't related to it being a
dual processor setup. I should have the same problem then even with
the add-on card. Personally, I think it is some sort of hardware
optimization made by Intel (or whoever) that Presonus's drivers can't
deal with. I mean, the built-in 1394 port is probably "tuned" for
stuff like external harddrives and video and all that burst-rate
stuff, but maybe sustained digital audio it just can't deal with.
(the combination of the Presonus drivers and the built-in hardware).
What I haven't tried yet and still intend to do is try another 1394
audio product and see how it handles things.
Jonas
Thank You!
Solution #3
Not Rated (0)
Phoebe
Rating: 0%, 0 votes
I too had a Presonus device (Inspire) and the drivers were very problematic.
Traded it back in for an M-Audio...now everything is grand.
Thank You!
Solution #4
Not Rated (0)
Cato
Rating: 0%, 0 votes
Yes. But multiprocessor systems do tend to break software that wasn't tested
on them. Practically all software has lightweight processes, ie., threads,
but that doesn't mean it was tested for race conditions on a particular
system.
Bob Morein
Dresher, PA
(215) 646-4894
Thank You!
Solution #5
Not Rated (0)
Cato
Rating: 0%, 0 votes
I don't think the problem is specific to Core 2 Duo machines. A friend
of mine bought a Presonus Firewire audio interface and had nothing but
problems. He narrowed it down to the Presonus drivers, and returned it
and bought a cheap USB Digidesign interface with Pro-Tools LE and then
an M-Audio Firewire interface with different audio software (I don't
remember which kind) and didn't have any of those problems.
Lots of phone calls to Presonus technical support and they couldn't get
the system to work flawlessly.
Thank You!
Solution #6
Not Rated (0)
Jimmy NY
Rating: 0%, 0 votes
On 15 Jan 2007 20:09:12 -0800, trained 100 monkeys
to jump on the keyboard and write:
Two Questions :
What interface are you trying to use with the Firewire?
What controller chip is in your Firewire setup?
There are several Firewire controller chips, some more highly
suggested than others (like the Texas Instruments, for instance).
jtougas
"listen- there's a hell of a good universe next door
let's go" - e.e. cummings
Thank You!
Can you Help with these Sound Cards problems?
Sound Cards
lan card driver sound driver
Sound Cards
i wish solve my problems.
Sound Cards
I have provided a new answer to your question Re: the...
Sound Cards
my computer is NEC LAVIE PC-LT700FD. I reinstall it but I...
I have 3 P S inspire 1394 and I have daisy chained them....
Loading problems.
Repair Service
Find Sound Card Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
