Question about Canon PowerShot S2 IS Digital Camera
All picture taken found with 1 white dot at the location
All picture taken found with 1 white dot at the same location. How to solve this problem?
The problem you are encountering is called a "dead pixel". Every ccd has several dead pixel, so it is quite normal. But I agree that it can be annoying.
The solution is to map the bad pixel and to substract them afterhands.
Go to http://chdk.wikia.com/wiki/Main_Page and download the latest firmware for you camera here http://mighty-hoernsche.de/.
It is a supplement to your camera that will open hundreds of possibilities, like making time-lapse recordings, doing your own scripts, shooting RAW,...as well as a feature for removing bad pixels.
All you have to do is to read! Yeah, I know, there are lots of things written :p
More specifically, here is the "how to use badpixel removal" explanation.
http://chdk.wikia.com/wiki/Badpixel_removal
Posted on Mar 15, 2009
My daughter has a Galaxy S4 mini and there are these purple dots that are invading the pictures she is taking - they only show up when using the camera mode and show up in the pictures taken - is ther
Although the camera is very tiny, if there is a very small opening, it could be some moist came in. The moist can leave very small crystals on the sensor, causing dots in the picture. On a normal camera, you could test this, by choosing a large aperture number (f number of 22 or more) focus on infinite and take a picture of a bright white paper with lots of light on the paper. If you then see spots you know they are on the sensor. I'm not sure the Galaxy can be set to manual, to take a spot retention picture.
If the camera is important, you could go to a repair shop to have it replaced.
Jul 08, 2014 | Samsung Galaxy S4 Zoom Android Camera...
White dots on screen
Most likely T-Con PCB. Part Number varies (See Below)
http://www.shopjimmy.com/tvs/tv-t-con-boards?restrictBy[known+models]=VIZIO+E550VL
Nov 25, 2013 | Vizio E550VL 55 in. LCD HDTV
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
I have small whitr dots on my picture screen
I went through the same problem with mine started out as one ended with many Its the optical lamp board cost is $600 and some dollars for a model 73-733
Dec 06, 2011 | Mitsubishi WD-73733 73" HDTV
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
WHITE DOTS ON SCREEN NEED DIAGRAM LOCATION AND REPLACEMENT HLT 56765X/XAA
White dots that increase in number as time goes by indicates that the DLP chip needs to be replaced. Samsung use to cover this problem under their "white dot" warranty. You can call 1-800-samsung to see if they will repair it. If not, they can give you the closest service center. I would not attempt this repair unless you are a trained tech.
Apr 05, 2011 | Samsung Televison & Video
I need help I don't know what color wires go to what wires on my sterio deck
I have a radio wire connector on a 1994 Toyota Camary and the color don' match your list, here is my list.
2 reds, one silver dot, one double silver dot.
2 blacks, same as above,
2 greens, same as above.
2 whites, same as above.
2 browns, same as above,
1 white w/green stripe, two silver dots
1 black w/red stripe, one silver dot.
1 yellow, two silver dots.
1 blue, two silver dots.
the numbers on the connector are A02 16 14 11264 9 8.
I'm clueless which wire are which.
Oct 30, 2009 | 1994 Toyota Camry
DSC-T70
No setting can cause white spots on the picture, this is a fault.
By the way you can reset settings on this camera to initial state by simply removing and putting back camera batteries.
Alternatively you should have a reset command on camera settings menu.
My opinion is that this is a fault and not a settings problem.
Typically there are three kind of faults that can cause this problem:
1 - Dirty lens or water inside the lens:
The lens may be dirty inside, for example because of water condensation on internal surfaces, this will cause blurred dots or black dots. The lens must be taken apart and cleaned in this case.
2 - Defective CCD sensor.
The CCD sensor is the chip that detects the picture, if you get well defined white or colored spots on picture that is probably a defective CCD. I think this is the more likely in your case. To fix this the sensor must be replaced.
3 - Defective video chip on internal board.
This can cause any kind of problems, however it is quite unlikely.
It is an expensive repair.
Feb 09, 2009 | Sony DSC-T70 Digital Camera
White spots on photos
RED DOT
If the dot is not visible in print, but only on the camera's screen, the its only the LCD that is faulty.
If the dot is visible on screens and in print, then yes, it could be the sensor. Try taking pictures without the digital zoom. Chances are the dot is only visible with the digital zoom because the picture is interpolated.
If all else fails, you can try cloning out the spot in an image editor on the computer.
Dec 01, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
471 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
