Question about Gateway FPD1760 Monitor
Gateway Monitor keeps going black
Monitor has been fine until yesterday. Today, when I turn on the monitor, it comes on for a second or two, I can see the Windows desktop clearly with Signal:Analog and then it goes black. Cycling through with the Input button on the side shows the 3 color no signal screen momentarily before going black and then returns to the desktop, going black almost immediately. I've checked the connection to the CPU and it's ok. I've swapped cables with a working monitor and this one still doesn't work. Ideas?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Alicia, Your monitor digital board is OK. The problem is with the power supply/ Inverter board(s) in back of the LCD/LPD Panel that you look at. You will need to question Gateway to see if they have a swapout program where you send them $30-$60 and your old monitor, and they will send you a refurbished (new cold cathode fluorescent tubes w/inverter board installed ) complete monitor. I'll tell you one thing though. Alicia, Don't feel bad abt this monitor of your's failing. You have joined the club with over 2000 others whose CCF tubes and INVERTER boards have with time now fail to light-up their LCD panels. Yes, there are some companys that do repair of these monitors. Try surfing under CCF tubes or FPD repair, or LCD repair. Yes Alicia, you are dealing with a technology similar to the new type of screw-in light bulbs, only the tubes are thinner and laid flat horizontally across the rear of your LCD panel with a reflecting mirror in back of them. Good luck girl in getting it repaired. I'm louie12fix on fixya or lmistyrel @aol .com North of Chicago 40 miles
Posted on Feb 27, 2009
I figure I need a replacement graphics card. The PC worked fine yesterday. Turned it on today and no signal to monitor. Tried both DVI and HDMI with the same result. Monitor is Gateway LP2417.
try pulling the power cord out of the monitor and then wait 30 seconds and pull it back in to monitor . Are you dealing with a graphics card or a motherboard video chip. May have DVI and HDMI plugged into motherboard rather than PCI video card. Check Bios to see if conflict exists between motherboard video chip and PCI video card.
Dec 31, 2015 | Gateway GM5632E 2.4ghz Core 2 Quad 3GB Ram...
My monitor keeps blacking out. When I turn it on the picture is fine for a few seconds to a few minutes and then it blacks out again. I can still see that there is a very faint picture there but...
This can be related to a thermal runaway of a component ,more likely to be in the signal processing section.If you are able to use a FREEZE-IT spray on the heated component- likey an IC- this can be confirmed as the ccooling must bring back the picture. Also simulation with a heater can make the fault appear and so you can pinpoint to the fault.
Oct 02, 2011 | Gateway HD1900 19" Monitor
Working fine till yesterday. When shutdown
Open up the set and look for bad caps, see some failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | Gateway FPD1760 Monitor
Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Dec 30, 2009 | Gateway Computers & Internet
My screen goes black after a few seconds
Sounds like a bad solder joint on the printed circuit board. Once it heats up then it no longer makes good contact and the monitor goes black until it cools down and makes contact again. You could resolder it if you knew where it was but monitors are dangerous to go playing around with as they can hold very high charges of electricity in their capacitors that are very dangerous. It's a throw away world. Go buy a new one.
Jun 02, 2009 | Gateway FPD 1750 17" Flat Panel LCD...
Monitor went black
This is a very common problem,
Most monitors go due to the connection, for example when you open and close the lid this loosens the connection so this is your problem.
You may be able to find and download the service manual on google, and take it step by step from there or take it in for a service.
hope this helps
alex
Apr 06, 2009 | Toshiba Satellite L305D-S5904 Laptop
19 "lcd gateway monitor will not power on.
Have you tried your monitor on somebody else computer?
Jun 14, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Computers & Internet Logo
820 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
