Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch dishwasher SHU4326uc/u12 is leaking from the door. How to change low door sealer?
  • 3 Answers
I have had the same problem and finally stumbled upon the answer today!
If you are looking inside your dishwasher, look mid way up the right side wall and there is a valve/hole...if that hole is covered up (e.g. cutting board, ect) it will cause water leakage.
Weird huh? But that recommendation is coming straight from the Bosch headquarters in Canada. I would not have believed it otherwise, but I have read this solution twice, and now myself, have not had a leak since I stopped placing things over that hole! My model is SHU3326UC.
Posted on Apr 30, 2009
  • Sara Jul 16, 2013
    who woulda thunk... fixed it!
  • Bosch Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
atrgfa
Posted on Sep 29, 2010
Check and clean gaskets. Replace if torn or worn. Remove and clean strainer and clean area underneath strainer. I cleaned the strainer in the sink. I cleaned the area under the strainer with a knife to pry food, gently, and a wet vac to **** out. This solved the problem. The food probably caused a shut off float to stick allowing too much water to fill machine and water level rise too high.
Posted on Aug 27, 2009
How do I fix the heater in my Bosch shu5306uc / u12?
SHU5306UC-12 BOSCH DISHWASHER Manual - Sears ...
www.searspartsdirect.com > Kitchen Appliance Parts > Bosch Parts
Download Manual for Model SHU5306UC-12 BOSCH DISHWASHER.Sears PartsDirect has parts, manuals & part diagrams for all types of repair projects.
Aug 01, 2015 | Bosch Dishwashers
I have a Bosch shu9925uc/u12 dishwasher. It is leaking from the bottom. What could be the reason & how to resolve it?
Lay a thin piece of brown paper or a thin piece of cardboard and locate the exact location. Sounds like the drain hose may be damaged or improperly seated.
Dec 29, 2014 | Bosch Dishwashers
Water overflow then no water
It may be a sticking float switch. The float switch controls the level of water in the dishwasher and if it is sticking on or off it could cause them problems you have
part numbers 263834 and 263185.
Hope this helps
Jan 02, 2014 | Bosch 23 in. SHU3302UC Built-in Dishwasher
My bosch shu3326uc/u12 dishwasher is not getting my dishes as clean as it used to and it doesnt dry plastic at all.
you have changed you detergent?get a good one and you will see the differance.adrian,,,,,,,,,,,,,
Aug 16, 2010 | Bosch Dishwashers
The machine stopped with 33 minutes remaining on 96. There is a "pumping" sound but no water comes in. The dial says it is on rinse but it does not rinse. Bosch Dishwasher EN: SHU4326UC/U12 FD8007. 260415...
If you have water filling up in the sump, you will get that scenario. If water is out of the tub, pull unit out and tilt backwards about 45 degrees. If water comes out from the base(sump), then you know you have a leak and need to have it attended to. Note, if water does come out when tilting the machine backwards, you will find it will work again until base is full again.(Switch off before tilting the machine backwards just for safety.
Jul 21, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher is leaking fresh water from water inlet assembly
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 11, 2009 | Bosch Dishwashers
Water will not drain out of the tub all the way and behind the front door bottom in the insulation seems to be wet. and the cycle seems to take a long time to run...thanks
My dishwasher, Bosch Model No. SHU9922UC/U12, Serial No. 10 0202 80447 01 0040 goes through its wash, rinse and dry cycles but sometimes there is some water remaining on the items in the upper tray and one inch or so of water remaining in the bottom of the tub. Once water leaked out onto my kitchen floor. I found some broken glass and some plastic in the circular trap at the bottom and have removed the detritus.
Jul 29, 2008 | Dishwashers
...dead
CHECK DOOR SAFTEY SWITCH OR TIMER MOST LIKE SWITCH ASSOCIATED WHEN DOOR IS CLOSED
Jan 17, 2008 | Bosch 23 in. SHU303 Built-in Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
427 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
