Question about 2wire (1000-000005-002) 802.11g/b Wireless Adapter
Can't connect to internet with my 2wire,
I completed a winipcfg and it shows no ip address
  • 36 Answers
By typing winipcfg im assuming your using Win98 or ME.
Make sure that your adapter is bound to tcp/ip
if you right click network you will see the adapter there.
Posted on Jul 24, 2009
Http://192.168.1.254/ has been put into my home page browser but nothing happens
IP ADDRESS 192.168.1.254 is the default gateway of an AT&T modem router (RESIDENTIAL GATEWAY) (2WIRE). for this ip address should be able to view the main screen of your 2wire modem and if not your computer is connected to a different network.
1) try connecting the computer to the 2wire RG using a ETHERNET cable (if your connected via wireless)
2) make sure that the DSL light is solid and not blinking.
3) if your computer already connected by a ETHERNET cable, try accessing the same ip address if your able to view the main screen of your 2wire modem it means that your computer will be able to connect to the internet.
4) try this also:
this for internet explorer:
click tools - connections - LAN settings
( if there's a tick mark on PROXY SERVER remove it )
if you do have tick mark on PROXY SERVER then your computer have a virus, because virus can put a tick on PROXY SERVER without you noticing it.
after removing the tick you will be able to connect to the internet again.
Apr 10, 2011 | Computers & Internet
Having problems obtaining addresses from dhcp. Can I use static addresses instead?
This link shows how to set static IPs on the 2Wire:
http://www.server-servers.com/att-static-ip-2wire-setup/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 18, 2011 | 2wire 2700HG-B Router (2700HGB)
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.Comments: Dec 30, 2009- Netbook sees the network, has excellent...
Replace the Cable and Check.
If the problem still persists then
Give the same network setting to the wireless network adapter as you assigned to your local area connection.
Note: Before doing that remove the IP address of that Local area connection or change it's IP address to some other number.
This will most probably solve your problem.
Otherwise, Used an external USB Wireless Adapter.
Jan 01, 2010 | Acer Aspire One PC Notebook
2 wire gateway..trying to go wireless....shows excellent signal but limited or no connectivity.
1. Try to determine whether you can connect to the Internet
Start -> Control Panel -> Network and Internet Connection
-> Network Connections -> Right Click Local Area Connection
-> Properties -> Internet Protocol (TCP/IP) ->
Use the following IP Address,
IP Address: 192.168.0.2,
Subnet Mask:255.255.255.0,
Gateway: 192.168.0.1
2. Reset modem and rebooted the computer
3. Check cables if they are properly installed unplug and replug
4. If issue where not resolve contact your ISP service to check if it's the connection or hardware issue " ISP service has a tool that can run a line test determining where the broken connection is."
Nov 15, 2009 | 2wire (1000-000057-000) Modem
Can connect to 2wire, but can't browse
What is the ip address you got from the 2wire router. ??
Try release and renew for new ip. Clear the cache and temporary internet files, and then try pinging the router's gateway ip and check . If pinging. then ping any website's ip address. if successful then try going online. Else you need to power off and power on your router and then try again.
Sep 06, 2009 | 2wire (1000-400108-001) Router
I dont know crouter configuration
Hai,
Look at your computer's IP configuration. Go to Network and Dial-up Connections, RIGHT CLICK on your network and pick PROPERTIES. Click on the Internet TCP/IP protocol, then click on the PROPERTIES button. Make sure that your settings are OBTAIN IP ADDRESS AUTOMATICALLY.
Then get into your status screen and look at the GATEWAY address. Is that 192.168.0.1 ?
(If you are using Windows 95/98/ME, then go to RUN and go to WINIPCFG)
You can also use the COMMAND PROMPT and type IPCONFIG and it will show the Gateway address. If the Gateway address is slightly different, then try to get into it at that address.
Also from the COMMAND PROMPT, (or MS-DOS window) you can use the PING command. Just type PING 192.168.0.1. If your router responds, you might be OK.
Look at the lights on your ethernet card. Is it GREEN, or does it show YELLOW.
Try rebooting your computer and using PING again.
Then the problem presist it's possible that this Router is NO GOOD.
Hope this Helped!
Aug 27, 2009 | Computers & Internet
RE: My posted. Connecting DSL/Router to DIR-628 internet router
Installing a router to work as the second one on a home networkrequires special configuration. Do the following on the second routerto ensure it (and the devices attached) function properly:1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode.Note that some home wireless routers do not support client mode; thesemust be connected by cable. Check your router documentation for detailson its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP addresssetting. Often, these default IP addresses will not work in a tworouter environment. Check the second router's IP address value andreset it if necessary to work within the valid address range of thefirst router (and to not conflict with any other device on the network).
3. Disable DHCP- To avoid IP address conflicts between all of the devices on the homenetwork, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
(My netgear router supports client mode. The 2wire supports bridged and router mode. My 2wire is the main router. I set up my netgear using my laptop. Once you change the address on the router.. You will only be able to directly access through the main router to the 2701.)
Configure your 2701 IP address to a static address in the 192.168.2.1 range and diable DHCP. Only 1 router can run the DHCP service. To disable Dhcp on the 2701.... log on to 2701> click on home network>advanced settings>uncheck enable DHCP>Next section is Public routed subinterface...Check enable and Aout Firewall Open>Input your main router address and mask>save config..
This worked with the Netgear router.. May not with your router. Good Luck! Hope this helps!
Jan 16, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire 1800hg random no internet/random access, repair/wait fixes
It seems that you said your computer gets the ip address from your router,, which means thru DHCP of the router but if you look at the DHCP settings of your wireless card inside your computer ---the DHCP is OFF -- check your ipconfig/all command as shown in your problem too,,, your wless card does not accept the new IP which comes from your router --as DHCP is OFF on your wless card and sticks with the old ip address whereas the router maintains a new ip for your computer in its table and a mismatch occurs and you loose the internet connection ,,,,thats why repair works and then again the IP changes in the router for your computer and your computer's wless card lags behind and use the old ip adress ..... DHCP--- IS DYNAMIC , WHICH MEANS IT RENEWS THE IP address after some time and you computer gets stuck to the old one ,,, hence mismatch. "you make the DHCP -ON on your wless card too. it will be fine."
Mar 06, 2008 | 2wire 1800HG Router (RG1800HG00)
Wireless internet
You could try to manually set your IP address in the TCP/IP, the gateway and your ISP DNS
Feb 09, 2008 | 2wire (1000-400108-001) Router
Wireless Internet
I am guessing you are connecting that netgear card wirelessly? Does it get an IP address? Have you tried pinging the router from the laptop once the connection has been made? Try this. Go to the start menu, click the run button and in there type cmd and press enter. Once the black command prompt is open try ping yahoo.com See if that comes up with anything. Also try typing ipconfig and press enter. It will show 3 things.
IP address
subnet
gateway.
The gateway should be your 2wire modem.
Try ping gateway ip and see if that works.
Let me know! thank you.
Jan 27, 2008 | 2wire (1000-400108-001) Router
2wire (1000-000005-002) 802.11g/b Wireless Adapter Logo
244 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
