Mitsubishi AM2770 factory reset
I bought this tv from a hotel and it is set up for it. Is there anyway to reset the tv back to a regular programing, so I can use a universal remote? Right now there are no remotes at all.
Unforunately you need the master remote to change the tv to consumer in order to try to use a universal. Mitsubishi is no longer making the master remote for this model.
Posted on Jul 17, 2009
I think it woud be better to look for a remote first.
Posted on Mar 11, 2009
How do I do a factory reset and master reset
Try finding a U tube video on how to get it out of hotel mode or go the the TV manufacturers website to get the operators manual for your model of TV. You may see a section on the setup menu to turn hotel mode off.
Dec 21, 2015 | Televison & Video
I have a Philips television, Model # 32HFL56624/F7. How do I change it from a hotel mode to regular televison. I have the remote but it will not give me the menu section to change it back?
Usually hotel models are rewired so they will only show basic or pay channels. If you can get into main settings and you can do factory reset(which I doubt) that may work. I assume you bout this cheap or free, Old saying states "Buy cheap But twice".
Jul 21, 2014 | Philips Televison & Video
My Panasonic CT 2521 HDB needs to be reprogramed
Reset it to its factory default, and then reune it. Refer its user manual for details.
May 07, 2012 | Panasonic CT-34WX54 34" TV
I have a Phillips Tv That I have bought off of my employer (Hotel Industry) with the Model # 32HF7544D/27 and I'm unable to get it programmed to channel 73 which is what my Satalite company uses (
Hotel sets use a special remote with specific instructions--you need to get that remote and the instructions---hotel knows that..........
Apr 08, 2012 | Televison & Video
Toshiba hotel mode
"Hotel mode" is usually an option for commercial TVs. In order to get rid of that, you might need "service remote control". Similar used in commercial "Philips" LCD panel sets. I do have the one. But it won't work with Toshiba. check help line and ask to obtain the one. It might cost a bit more, than consumer one, but? that might be your only option. consumer sets have "store" mode, but it defeats easy from regular setup menu. Do you have original remote for TV? Inspect it, if you do. It might be the service one, anyway. Those have "guest", "administrator", "service" modes.
Good luck,
Alex.
Dec 04, 2011 | Toshiba Televison & Video
We bought a magnavox tv from a hotel and some channels are blocked and we can't get all of our cable channels. Is there a way to reprogram the tv? It is a 25' and it's about 10 years old and in good shape....
the eprom that holds the stored codes needs to be wiped clean or re-set...unfortunately, unless the original remote is available to get into the menu...it will have to be done manually by a technician. the set needs to be opened, the eprom located, the proper pin-outs located and then proceed with resetting. if the eprom is an older type, then the codes were usually held there by a back up battery or super cap...in which case, you just need to remove the battery or super cap for a couple minutes.
silvio
Jun 30, 2009 | Philips Magnavox 27MS343S 27" TV
32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
Jan 17, 2009 | Philips RC2573 Remote Control
I cannot reset the channels on my TV. It is the Concierge TV from a hotel. Will I need to buy a Zenith Remote from the store to do the channel programming. It says it is locked
You have a hotel/motel model that cannot be programmed or any of the settings changed without a special Master remote. Sorry, doubt that you can buy one from the store, they are not sold to the public. Contact the hotel where you bought the set and try to get the model number for the remote from them. This is a different number than the model number of your tv.
Dec 13, 2008 | Zenith C27A24T 27" TV
Trying to get channels above 42 to 99
I had the same problem the solution is you have to get institutional remote and reset the tv from commercial mode to consumer mode and then you will have access to the full menu. go to www.phillipsitv.com to get the directions. I actually asked a Hotel could I borrow their master remote used it and took it back and my tv works fine. Hope this helps.
Dec 01, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
461 people viewed this question
Top Televison & Video Experts
Electro Med Services...
