Question about Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black
BUNN CWTF 15
Our coffe is luke warm right after brewing. It only gets hot after sitting on the warmers for awhile. Would this be a thermostat problem or a tank heater issue. What parts would I need to fix it? Is this a fix we could do ourselves?
Please advise.
Thanks!
    Novelist:
  • 125 Answers
Hello. Most likely the heating element for the tank has failed. This unit has a warmer that has the wattage of a 100w lamp, wrapped in foil on the outside of the tank, and just helps keep the water in the tank more stable at the normal brewing temp, that is why it is warm to start, but then is cool, or cold when you brew. The main heater in the tank, goes in from the top. Could you do this? well, there are 2 other items, a thermostat, and a hi limit that can cause this same problem, if you can test them, they should read zero resistance, like a closed switch. The element should read 10 to 20 ohms resistance, depending on the wattage, and voltage. It should be relatively easy to replace, just take your time, get the manual here :
http://bunnomatic.com/pages/techdocs/manuals/pourbrew_warm.html
Hope this helps, and thank you.
Posted on Mar 23, 2009
I have a bunn cwtf twin,I put new ready lights on both side work for about a week and the they wont light up. and the side the the faucet only brews warm coffee. but the other side does find. HELP
The green ready lights do not last that long. We never replace them on units we service. They are cheaply made. Each side of this coffee maker has its own thermostat. Check to make sure the thermostat is on all the way. If it is check the voltage on the warm side. Make sure it is in the 208v area. This warm problem is 85% the thermostat not set right and or needs replacing.
Apr 28, 2014 | Bunn CWTF Twin TC Coffee Maker
Brew water does not get hot
Check heater switch is on in rear of unit.Could also be a the thermal fuse is bad.You can locate fuse by taking top of brewer off.Fuse is in-line going to one side of element and resembles a resistor.Can use a volt meter to ohm for resistance.
Dec 24, 2010 | Bunn CWTF 15-2 (1 Top Warmer) Coffee Maker
My bunn cwtf 15 wont put out hot water and the ready light wont turn off dustain
If your ready light is on and your water is not warm... sounds like the thermostat is too low. Inside the front panel (behind the brew basket) there is a thermostat adjustment on the left-hand side. If you turn that up your ready light should shut off. You can then adjust the temp to your desired level. (194-200 degrees depending on roast, grind, etc...)
Jun 14, 2010 | Bunn CWTF15-TC
Installation of grommet on model cwtf 15 ( 1 lwr/2 upr pf
Which grommet, there are several on the bunn models, but the most commonly replaced one is the one for the P. stat. Remove the top panel there are 2 screws one in front and one in back, then lift the top 2 burners off machine that will give you access to the tank.
Apr 30, 2010 | Bunn CWTF 15-2 (1 Top Warmer) Coffee Maker
Water not hot on Bunn coffee maker
Check the Hi-limit thermostat on top of the tank, then the pressure stat setting and then the inline fuse and then elements.
Mar 03, 2010 | Bunn CWTF20-3 Automatic Coffee Brewer -...
When i make coffee sometimes the water that comes out is cold or luke warm
The brewer has not had enough time to reach its operating temp (usually 7 mins after a brew cycle). If that is not hte case then the machine needs to be descaled.
Feb 18, 2010 | Bunn VPR Coffee Maker
Bunn cwtf15 coffee isn't hot enough the coffee brews @115 degrees
Adjust the thermostat, located behind the front panel, there will be a knob, turn all the way on then back about 1/4 turn.
Dec 07, 2009 | Bunn CWTF 15-TS Coffee Maker
Adjusting the temperature
Our Bunn VPR was delivering luke warm coffee. The problem was lime scale buildup on the heating element. I recommend using a cleaner such as Brew Rite or a vinegar solution. If it still does not heat properly, unplug and remove the heating element for cleaning. This corrected our problem.
Jun 17, 2009 | Bunn VPR Coffee Maker
Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black Logo
187 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
