Question about Apple iPod nano
Broken ipod My wife's ipod fell off our motorcycle and is badly damaged. It will not turn on and does nothing when plugged into the computer. Does anyone out there know if there is a way to retrieve the songs on it. My wife is heartbroken and I'd gladly buy her a new i-pod but lost the backup of the music.
  • Ed Biller
    Ed Biller Mar 02, 2009
    That's what I was afraid of!
  • 70 Answers
If it cant turn on then it is a waste of ur time to try to get the music i dont like saying it but its gone.
the only way to get music off of it is to plug it in the comp and transfer the music to ur desktop or a folder but it cant turn on and isnt recognised by the comp its gone. : \
srry
Posted on Mar 02, 2009
Seems like carbs are flooding lots of gas and wont run right
Hi, Anonymous and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition and leaking.
3. Spark plug gap too close or too wide.
4. Faulty ignition coil, module, and or sensor.
5. Battery nearly discharged.
6. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
7. Intermittent short circuit due to damaged wire insulation.
8. Intake air leak.
9. Water, dirt, or rust in the fuel system, fuel pump and/or filter.
10. Fuel tank vent system plugged.
11. Throttle body controls misadjusted.
12. Damaged throttle body or intake seals.
13. Loose, dirty, or corroded ignition module connector at crankcase.
14. Faulty MAP, CKP, O2, and/or CMP sensors.
15. Incorrect valve timing.
16. Weak or broken valve springs.
17. Damaged intake or exhaust valve.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day.
Hard start Backfires The FZR Forum
How to Clean Motorcycle Carburetor the RIGHT way Evan Fell Motorcycle Works
https://www.tradebit.com/filedetail.php/2864660-yamaha-fzr-600-service-repair-manual-pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Apr 08, 2012 | 1989 Yamaha FZR 600
My Ipod touch fell down my wooden stairs -only a few stairs- but it fell, nevertheless. It still seems to work perfectly. What a relief! However, I just tried to give it a little bit of a charge before the...
Your relief was short lived. Though the fall did not damage the player itself it appears to have damaged the power supply side of the unit. Perhaps the charging socket got a direct hit and has broken internally. I think you will have to take this to a repair shop as it could need some parts.
Jul 06, 2017 | Apple iPod touch
My Motorcycle fell over!
Chances are the forks are just a bit out of alignment from the fall. Put the bike on the center stand with the front wheel pointing perfectly straight ahead. Are the handlebars looking like they are turning a bit to the left or right? If so, just go to the front of the bike and straddle the front wheel while facing the rear of the bike. Hold the wheel firmly with your legs and firmly twist the bars back to a straight position. Re-check the alignment and re-adjust as needed. Now go ride and check it out.
Please rate this solution. Thanks!
Jun 09, 2009 | 2003 Suzuki VL 800 Volusia
My Computer and iTunes does not recognize my iPod
put your ipod in disk mode by following these steps.
press and hold the Menu and Center buttons on the clickwheel. when you see the apple appear, switch your fingers to the center and play/pause buttons.
whena check mark appears plug it into you computer and it should detect and mount.
add music and have fun.
May 24, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
IPod Troubles
You could try removing the hdd
But you would have to build a compatible cord to set the hdd up with your ide pc
I have no idea how, but i know that it will work theoretically
Unless your ipods hdd is damaged by water, which could be liekly.
Thanks
ben
Oct 07, 2008 | Apple iPod MA446LL/A MP3 Player
Install the drivers for your ipod specified. Try changing the USB cord as next solution.
Dont forgrt to rate this
Aug 20, 2008 | Apple iPod nano
Try this: turn off your ipod, hold the home button, and plug it into itunes while still holding the home button until a picture of the itunes symbol appears with a cable under it. itunes should say "ipod found in restore mode". This will completely reset your ipod, hopefully fixing any bugs or problems in it. also, you will lose all data saved on the ipod that isn't also backed up by itunes. Music, pictures, and video can be re-synced.
Aug 16, 2008 | Apple iPod touch
My ipod nano wont do anything
Did you try resetting the iPod? If the battery were dead then when you plugged it in, you'd still see something popping up on the screen. What's possible is that your screen got disconnected from the iPod logic board or otherwise got ruined. When you try turning the iPod on can you hear any noise inside? If you toggle the hold switch does it show the orange light? If you can't hear any noise and it doesn't show the orange light, your iPod's logic board probably died. You can get a new one off eBay and replace it if you're comfortable opening your iPod. Otherwise, you can sell the broken iPod on eBay for a decent amount.
Jan 06, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
56 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
