Question about Intel Motherboard
Bios goes down 15 seconds
No keyboard and usb device over current status detected and it went down with 15 seconds.thanks,henry
  • jpe1002000 Feb 28, 2009
    the bios says(keyboard/interfence detected)also(usb device over current status detected)It last 15 seconds.I have asus p5q pro lga 775 intel p45 atx intel motherboard.Intel pentium e5200 wolfdale 2.5 ghz lga 775 65w dual-core processor model.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand with no keyboard and USB devices installed, I am tempted to think that it is a motherboard issue. Since the USB and keyboard both uses +5VDC and the ports are close to one another, you may want to check within that area. With no power and using a continuity tester, check the +5 pin of the USB port. The USB has only 4 pins; +5, Data -, Data + and GND. Likewise, the PS/2 port for the keyboard has pin 5 for the +5 and pin 4 for the GND. Both + 5 pins should read between 5 & 10 ohms. Anything lower is questionable and maybe cause by a partially shorted capacitor of a leaky/fault reverse protection diode. This of course if you are considering a DIY (do-it-yourself) repair. Of course, the simplest/easiest would be to replace the motherboard.
Good luck and thank you for using FixYa.
Posted on Feb 28, 2009
  • Louie  Role
    Louie Role Feb 28, 2009
    errata:
    on the PS/2 keyboard port, pin x is + 5 and pin x is GND as shown below.
    Additionally, this might help for the USB.
  • 679 Answers
It appears that you USB ports are not turned to the on or auto position. This can be corrected by using a plug in type keyboard adapter, "either from an old keyboard, or from a local computer shop", this will get your keyboard working. I would bet that once you get into the bios ,your usb device setting is set to disable or off. Just use the arrows and escapr key to navigate, hitting enter will give you the different options, and f10 to get out followed by enter. There also will be a menu at the bottom of the Bios screen, good luck
    Brigadier General:
  • 5,158 Answers
Have you tried it with a ps/2 mouse and keyboard ?
    Scholar:
  • 85 Answers
try clearing the BIOS/CMOS battery. Sometimes, and very rarely, the default shutdown tempeature is set to low, thus making your system think it is overheating when it actually is not.
The problem may also lie in the power supply.
Make sure the fan on your cpu is working properly,
also remove the video card and check out.as video card sucks up too much power from the power supply, or it's just faulty and is somehow screwing the computer up.
Posted on Feb 27, 2009
  • 4,472 Answers
What is your exact problem in more detail? Also what is the make and model of the motherboard. Once I have more information I can assist you further. Also please take a moment to rate my solution accordingly, or wait til I have assisted you further before requesting more assistance.
Thank you,
Lee
    Scholar:
  • 165 Answers
Let your machine rest for a while.remove all connections and unplug from min power outlet for a while,then reconnect everything and try.
    President:
  • Intel Master
  • 1,314 Answers
Could you describe the issue a bit further? What do you have hooked up to it? How long has this been happening?
When i start my pc i get the error "please enter
One or more of your USB devices connected to your PC are malfunctioned, remove any usb connection exept keyboard and mouse. Boot the PC , if the error still exists then reboot after removing your Mouse first and keyboard at second. Tell me what happens after these.
Sep 14, 2011 | ASUS P5KPL-AM SE Motherboard
USB Over Current Status Detected, Computer will shut down in 15 seconds
this message popped up because one of the device which you connected to the usb of the pc was overdrawing current i.e more than 5V DC. Hence, the built in system security gave this message and will shut down your computer in 15 seconds. In order to avoid this message first remove all the usb items connected to it and then connect one by one and detect the faulty one and replace.
Jan 29, 2011 | ASUS P5PE-VM Motherboard
Acer P5Q-EM mobo. When trying to boot i get this message USB DEVICE OVER CURRENT STATUS DETECTED WILL SWHUT DOWN IN 15 sec. which it does, I am also unable to get into the bios, even before I get the...
Ive seen this a few times. Its either a usb device plugged into the board shorting a usb port out, or whoever put it together wired the usb ports wrong on the board. FYI its an Asus mb not an Acer.
Sep 07, 2010 | Acer Computers & Internet
System shutdown in 15 seconds
Shut the power down to the computer all the power and pull the power cord out, remove all usb devices except the mouse and keyboard, Turn the unit back on and see if this fixes the problem, if it doesn't then you will have to go into the computer and clear the c-mos this will allow you to get into the bios screen from there you can set up the computer again. Check you manual for the instructions on bios reset, most times it is just pins 2+3 that need to have a jumper installed to reset it. READ THE MANUAL PINS 2+3 APPEAR ON MANY THINGS ON THE CIRCUIT BOARD
May 31, 2010 | ASUS P5PE-VM Motherboard
Usb device over current status detected shotdown in 15 second. cant acces the bios
Pull the little battery on the motherboard, and unplug the PC, let it sit for a minute or so. Put the battery back in and turn it on, BIOS should be reset.
Oct 01, 2009 | ASUS P5PE-VM Motherboard
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
SYSTEM ERROR
1) if you have nothing in a USB port you will need to set bios
Try removing M/board battery for 2 to 3 hours some people say less then replace it most times it should set BIOS back to default
also check setup of hard disks master slave etc
Last resort with 15 seconds you should be able to see
press ?? key to access BIOS next boot keep pressing key see if that works
Aug 10, 2008 | ASUS M2N-MX Motherboard
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
May 11, 2008 | ASUS M2N-MX Motherboard
cheak bios settings diable serial port parrel and any onbord stuff u wont use ok
Feb 01, 2008 | ASUS P5LD2 Motherboard
Intel Motherboard Logo
44 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
