Question about Intel S5000XVN Motherboard
Reset button want stop bebbing
My pc has a reset button on it . I added some ram to the pc and I replaced a broken cd rom. and now the reset button bebs and want stop. I have a pionex pc window98. you have any Idea? what I might have down to cause this to happen?.
  • jojemes Feb 27, 2009
    thank you for the right solution;
    President:
  • Intel Master
  • 1,314 Answers
The memory you added is either bad or not compatible with your pc. Remove the ram you added and see if that takes care of the problem. Thanks and please take a moment to rate as fixya.
Posted on Feb 27, 2009
I am trying to reinstall windows xp prof but i keep getting the blue screen and the system keeps shutting down, i have tried a different hard drive but get the same error.
unplug all devices except the hard drive and 1 cd/dvd rom drive. disable the audio device and any other unnecessary devices within the BIOS and remove all pci cards. remove all but 1 ram stick, and try using different ram sticks, one at a time, while trying to boot. if it boots, with 1 ram stick, 1 hard drive and 1 dvd/cd drive then try adding/reenabling the other devices one at a time, until you find the device that keeps it from booting.
if your pc wont load with just a hard drive, cd rom and 1 stick of ram, then it is prolly trashed. if removing/disabling one of the other devices (such as the sound card or the modem card) allows it to boot, then you have found what needs replaced.
Nov 06, 2010 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
The cd-rom drive in my computer has stopped working all of a sudden. The cables inside the tower are all connected however it does not recognize a disc being in the cd-rom drive! I also get a warning that...
Replace the Cd-rom drive, sounds like you may have a bad spindle motor and or Laser assembly. Cd-roms are very cheap these days, and you might consider replacing it with a DVD drive instead, which is downward compatiable.
Sep 28, 2009 | Gateway GM5084 PC Desktop
DVD/CD -ROM DRIVER
the same problem of mine is my drive cannot able to read DVD then i make the solution
if you have CD RAM/ROM + DVD ROM then change it to CD/DVD RAM because in case of CD RAM and DVD ROM it may read CD but not DVD but sometimes it can read DVD also but when we copy data to computer it may freeze or give us error so i give you one suggest to buy a new CD/DVD RAM
Jun 09, 2009 | Toshiba Satellite A205-S5804 Notebook
Windows won't start after adding ram
Sometimes, when you add RAM, you need to tell the computer that you have, do that by going into the BIOS when you start up your computer. Or it could be a wrong ytpe of RAM! Hope one of these idias has helped you.
DigicalJAI
May 19, 2009 | Compaq Presario 900 /1500 Series EVO...
My dvd-rom won't play or read. it spin once and stop
You Know i had also this type of problem but i solve it i buy a new CD/DVD RAM
if you have CD RAM and DVD ROM then change it to CD/DVD ram because in case of CD RAM and
Apr 26, 2009 | Computers & Internet
Have a Dell 667Mhz 64mbit ram pc w/windows 98 on
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Mar 29, 2009 | Samsung SC-148 CD-ROM Drive
I need to reset the ram on a hp pavillion slimline but the cd tra
Just unscrew, remove the entire CD ROM, fix the RAM properly and while connecting the CD ROM ensure that all connections are snug tight...sodeep
Mar 19, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
When I insert a cd in my cd-rom my PC switches off
Ok. My first option would be to change the power supply. That might be causing your problems. I have had one strange case where the pc would reboot when pressing the eject button, and it turned out to be the RAM... weird, but replacing the RAM solved it.
Try it with a bigger power supply, also perhaps with another CD-rom. If that doesn't work, try another CD, another HDD. If none of these things work, ask me again, and we'll take it from there! :)
(Make sure your boot priority is right, so that CD-Rom is above HDD, you can change this in the CMOS settings)
Jan 07, 2009 | MSI : PT880 NEO-FSR...
Presario 2175 us does not recognize cd-rom in bios
this is the connector problem, the point where rom attaches with the motherboard , take it to the technician
Nov 12, 2008 | Compaq Presario 2100U Notebook
Intel S5000XVN Motherboard Logo
62 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
