Question about Omega Paslode 901000 Impulse Cordless Finish Nailer
Paslode angle finish nailer the fan wont run nor will it shoot
  • gunz1f4 Mar 12, 2009
    i have the same problem, i shot about 200 nails through my 16 ga angled finish nailer (900600) and the led all of a sudden started blinking red and green. When i insert a new battery it blinks green at first then once i pull the trigger or press the gun into the wall it immediately starts blinking red and green again. I took the gun apart as the service person told me to do and checked the wires which appeared to be fine. I noticed that the fan would pulse and then turn off. Service is sending me two new black and red wires but i'm thinking that it's not going to help. THanks
  • Anonymous Mar 28, 2009
    I have the same problem with my 250a trim nailer
    Problem Solver:
  • 5 Answers
Have had the same problem! started with a noisy fan then a non responsive one. try taking out the fan assembly as per service and drop a couple of paslode lube drops along fan shaft and gently compress fan to lubricate bearing, may not be a lond term fix but hasnt stopped since and that was over 2000 2inch ago. good luck.
Posted on May 08, 2009
  • 2,176 Answers
Could be a couple things. After inserting a hot battery does the light flash green? If yes depress the trigger, does the fan come on? It could be a head switch if so equipped or the circuit or a broken lead at the battery. Give me the exact model of the tool and I will look at a breakdown and come up with something.
Posted on Feb 27, 2009
  • 3 Answers
Hi the noisy fan will be caused by a bent blade, this causes the fan to run out of balance, putting oil on it or just living with it will cause the motor to burn out. A new motor is about £65, what you need to do is find a paslode dealer and replace the blades on the fan, the blades cost about £6 so its worth while doing this before you damage the motor.
The blades get knocked when changing the o rings or servicing the kit without removing the fan correctly.
To see if the fan is bent hold it up to the wall and gently spin the fan and you will see 1 of the blades not making the same position as the other, if the shaft is bent then it will need looking at by a dealer.
When removing the fan heat it up with a burner first then unscrew the locking pin on the side - makes it alot easier and wont cause damage to the shaft.
Hope this help, Jon G Wales
Posted on Jul 18, 2011
I have a paslode finishing nailer that is occasionally firing. If i jam it hard it will shoot. #902000
You can adjust the settings arm on it to make it shoot out easier look on YouTube it may be there
Jan 22, 2015 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode finish nailer fan has problems starting and the light goes from green to red then it wont do anything?
It will probably be the head switch assembly. Top Gun still sell the parts or you could try ebay which would be the cheaper option.
Jul 08, 2014 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode 350 nailer wont work , push to fire fan works for 2 seconds then light flashes from green to red
Sounds like a battery contact problem or a bad battery..
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Feb 17, 2011 | Dewalt D55141FNBN HeavyDuty 16Gauge Finish...
I have a paslode 900600 . It cycles but it won't shoot nails.
heatman101
Jan 18, 2011 | BreatheAudio Paslode 900600 Impulse 16...
Paslode im250 fan running slow. light goes solid green when pushed to shoot, or pull trigger like it wants to fire. But fan runs slow and it wont fire! hot wired fan and it's fine . Changed the fan wire...
heatman101
Jan 03, 2011 | RTO Paslode 902000 IM250 Ii Cordless 16...
My paslode angled finishing gun keeps jamming leaving the firing pin in the out position
heatman101
Dec 24, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Fan goes on,only fires at a certain angle.
heatman101
Sep 20, 2010 | BreatheAudio Paslode 900600 Impulse 16...
My paslode straight brad nailer wont fire.. if you push the gas into the reciever and blow a burst into it and close the hatch it will fire.. but next shot, gas and battery fine.. no shot. fan going.. all...
heatman101
0-0-
Apr 30, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Omega Paslode 901000 Impulse Cordless Finish Nailer Logo
940 people viewed this question
Top Omega Tools & Hardware - Others Experts
yoopertech
Terry Hair
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
