Question about Samsung LN-S4692D 46 in. LCD HDTV
Got a new T-con but no luck
I got a new T-con from...
http://www.discount-merchant.com/We-provide-factory-original-parts-worldwide-p/1057264-samsung.htm
It did not fix :(
Problem.. No picture but sound,, back light kicks in and blinks when switching channels.
I think i got a bad board.
I lookd for that fuse at CP1 but cant find it, is it on the T-con board?
Should i get a new main board?
  • 4 more comments
  • Matthew Albert
    Matthew Albert Feb 28, 2009
    Thank you for replying.
    Yes the back light is constantly on, blinks when switching chanels, sounds works, power button works,, No on screen displays show,
    Everyone else on here with the same TV same problem, fixed it by switching out the t-con, this is why I am worried that I was sent a defective part.
    First thing that came to mind was the main board,
    but i found out that on this tv the logic board or t-con board have components on it that are normally on the main board. And seems to be a known issue with this tv.
  • Anonymous Mar 08, 2009
    I also replaced the T con board to fix this issue and it didn't fix it. I was also able to return the board purchased from Samsungparts.com for credit which is unusual. If this is their practice, it makes me wonder about the integrity of the board they sent me. Other web retailers do not allow return if the board was installed so I have been hesitant to purchase another one to try.
    From what I've researched, if it's not the T con then it's the LCD panel itself which is cost prohibitive to replace.
    Tonydes
  • Matthew Albert
    Matthew Albert Apr 23, 2009
    The New Main board did not fix the problem.
    If i power the tv with the T-Con unpluged, its the same as if it was pluged in. just a blank screen
    I think im going to try a 2nd T-con board.
    Any other ideas?
  • Matthew Albert
    Matthew Albert Apr 24, 2009
    I was able to fix the old T-Con board and got the tv working with all the old parts,, I was sent a bad T-Con from the start,
  • Rick Putman
    Rick Putman Nov 01, 2012
    Sounds like the main board is bad.
  • Rick Putman
  • 54 Answers
Is your back light constantly on when you are not changing channels.if so replace the main board. can you see a menu if you hit the menu button ? that is generated by your main board..... replacing the t-con will only correct vertical lines in the pic.
Posted on Feb 28, 2009
Why is the t-con board in my Toshiba Reza 42HL67 LCD TV repeatedly dying?
Could be just bad luck! It seems unlikely to me that the power supply would take nearly a year to destroy the T-con board!
You could get in touch with Toshiba to see if there is some kind of problem that is cropping up on this model that might cause failure in on the T-con.
May 19, 2016 | Toshiba Regza 42hl67 42-inch 720p Lcd Hdtv
Tv screen fades to black when you turn it on or is black when turned on
most likely is your t-con board. and good luck on finding it.
Nov 24, 2012 | Philips 52PFL5704D 52 in. HDTV
Tv gets red vertical line when on for a few minutes
if the vertical line goes out after warm up, it was an indication of t-con board malfunction. but before you come up with replacement with a new t-con board you must check first a loose connection. usually at the LVDS cable going to the t-con board. tried to re seat those cable connectors. turn off then unplug the tv while doing this to avoid damage with other parts and for safety reason. the t-con board is mounted under cover with metal shield. hope this can help good luck.
Nov 04, 2012 | Televison & Video
Toyota tercel 1988, engine knock. Replaced pistons rings and con rod brgs. Engine still has knock but not as survier. Has anybody changed main bearings with engine installed?
You will have to remove crank to replace and removing motor would be my suggestion...Would also suggest having the crank turned.......hope this info helps and good luck......please rate my post....
Aug 09, 2012 | 1988 Toyota Tercel 2 Door
Black and white display no sounds
Your T-Con board has failed.
You can search shopjimmy, ebay and encompass parts for a new one.
Just search "T-con board THL32C10S "
The replacement is easy, just take out the old one and install the new
Thank you and best of luck!
May 16, 2011 | Panasonic THL32C10S 32" Viera MultiSystem...
I have sound but no picture>
The t-con board of your television is bad, that is why your television is having sound but no picture.
The t-con board is by the upper middle of the main panel of the television, Have it replaced and your television will be in good condition once again.
Hope this was helpful to you.
Take care and good luck.
Jan 02, 2011 | Toshiba 43HX70 43" Rear Projection...
No picture but do have sound
The problem with this television is that the t-con board of the television is bad. Replacing the t-con board will do the job.
As soon as you take off the back cover, the t-con board is located at the top middle of the set under some shielding. Take it out and replace it with a new one, and the television will bring up its normal display.
NB: Also check your lamp too.
Dec 15, 2010 | Philips Televison & Video
Fuse box panel diagram 2005 new beetle con
2005 beetle trunk and gas remotes do not work in side car.
were is the fuse?
Feb 07, 2010 | 2005 Volkswagen New Beetle
My onix air con is only new and is blowing out hot air how can I fix this
If it is new and won't cool with all settings proper, Retyrn it. It may be short on the refrigerant and that requires tech nical servicing. Good Luck -Ned-
Oct 31, 2009 | Whirlwind FH-778 Air Conditioner
My blower only works on setting 123 + air con not that cold
You have a resistor array assembly going out. What you described is typical of the first resistor going out and over loading the second, which goes out and overloads the third. Replace the HVAC resistor array. Don't buy a used one. Spend the extra money on the new OEM dealer item. Good luck to you.
Apr 20, 2009 | 2000 Jeep Cherokee
Samsung LN-S4692D 46 in. LCD HDTV Logo
351 people viewed this question
Henry  Thomas
Henry Thomas
