Question about InFocus IN72 Multimedia Projector
Powers on, but automatically goes to default screen only
Everything was working fine, then 10 min before superbowl it switched to the default screen. Now every time I turn on, regardless if it's set to the t.v., dvd, wii it just sits on the default........It appears as well some of the menu options are no longer available. I've upgrade the firmware to the 3.0 and still doesn't work.
  • 3 more comments
  • chrisharden3 Feb 27, 2009
    Sorry......it's for the IN72
    not that I know of........It powers on normally just not catching the composite feed and staying on the default
    Do you have a ballpark as to how much to replace as it's not under warranty?
    That ****'s! Thanks for your info.
  • Patrick Cowan
    Patrick Cowan May 11, 2010
    is there a master reset switch anywhere on the device?
    Sergeant:
  • 319 Answers
The input board may be kaput, sounds like its not recognizing the ports. If its still under warranty, i would be in touch with infocus immediately. this def. sounds like hardware failure. Sorry if this doesnt help much!
Posted on Feb 27, 2009
  • Patrick Cowan
    Patrick Cowan Feb 27, 2009
    I'd imagine replacing the entire unit would be cheaper, but a good place to check would be partsstore.com
Power supply
monitor needs to be service issue might be with the motherboard pls take the monitor to service center
Dec 05, 2013 | Sampo Computers & Internet
Asus laptop won't turn on beyond windows start up screen
alright you r fine...
do u have data on ur C drive?
Dec 03, 2012 | Computers & Internet
Pitcure fine at first when i turn on my t.v then the screen goes blury or even looks like a 3 d untill i dhut it off then its fine sgsin for 10 mins it s gr 47 in or something
Sounds like a convergence problem--no clear here what brand and model number actually are--need that to advise you.
see attached typical photos of what this problem looks like
No two sets will look exactly the same but you should know if this is the problem you have.
Mar 28, 2012 | Televison & Video
Unit powers up for 5- 10 min good picture....then it goes black power light goes from green to red and flashes once and solid and repeats pattern .........if i go up to unit and push power off and back on...
There is circuit problem inside. For safety reasons power might get shut down! Unless the fault is rectified, this problem will continue. Do not attempt switching ON again & again. Get authorised service center assistance.
Apr 20, 2010 | Televison & Video
Screen goes black after 30 mins of working.
There are a few things you need to check here.
1. It could be that your computer power management is set to turn your monitor and harddrive off after 30 to 45 min.
If the computer is however working for 30 to 45 min while you doing stuff and it shuts off, the there is an internal problem "Hardware"
I would suggest you check to see if the power management is set to turn off monitor 30 min and harddrive after 45 min. IF that is not so, then we go on to the next test.
It could possibly be your processor fan is not working so once your processor gets over heated it shuts off the computer.
Turn off the computer, remove the case "this is only if you know what you are doing" with the case off, power on the computer and see if the processor fan is working.
You can get back to me and I can walk you through it.
Hope thiss help.
Aug 23, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
InFocus IN72 Multimedia Projector Logo
134 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
