Question about Philips 51PP9910 51" Rear Projection HDTV
PIP does not work
Is there any way to split the cable signal without a cable box so that the PIP will work on a Phillips 51" model 51PP9100D/37?
    Sergeant:
  • 319 Answers
The PIP can only use one tuner at a time, if one is on CATV, the other has to be on an AV input. you would need a catv box for the AV input for this to properly function.
Posted on Feb 27, 2009
PHILIPS 51pp9100d/37, picture is warped ? where do I get the parts i need to fix it ?
If it looks like attached photos it needs both of the convergence IC chips replaced. They should be stk=392=120 OR a few models used the -110 chip.
below is what the parts look like
Jun 15, 2012 | Philips 51PP9100D 51 in. Television
My 51pp9100d/37 philips TV doesn't have any sound.
This set has a "small signal board" The board is about 3x5 inches and plugs into board on far left as seen from back of set.
A lot of these fail:
low sound
no sound
intermittant sound
no remote functions
no channel up or down
etc etc
Last time I looked board was around 100 exchange rebuilt
Mar 13, 2012 | Philips Televison & Video
I have an 51pp9100d/37 Phillips Tv, and i the red and green colors on the picture are skewed to a weird, almost sideways, S shape. I was wondering if this is an easy fix and cheap, i don't really know...
From what you have said it seems that you need to replace the Convergence ICs, they are Big Black ICs and will have Part number on them ,example STK392-110
Mats Electronics has Parts $9.95 each IC. 1-800-628-1118
PTS rebuilts boards 1-800-844-7871
Jun 29, 2011 | Philips 51PP9100D 51 in. Television
Does the smt-h3270 cable box have pip
No it doesn't according to TWC. I have a 3270 and it doesn't support it. I got this info from the local TWC president. You can have PIP if your TV supports it by splitting the signal and watching it on another input.
Sep 26, 2009 | Samsung Televison & Video
How does PIP work ? where does the signal come from for the second picture ?
PIP uses the signal from a second tuner to insert a small or split-screen image on the main image. Some TVs have two tuners but most PIP applications need a signal from a VCR tape or tuner (tuner must be digital since 6/12), a DTV box, or a cable box for TV programs. A DVD player can also provide a signal for PIP if a DVD is playing. However some TVs will not allow PIP if the signal inputs are through the HDMI ports.
Sep 22, 2009 | Televison & Video
I need the service mode sequence for my philips 51pp9100d/37 so I can manually change the resolution on my tv. The resolution somehow was changed and when I HDMI my laptop to the tv it wont display t
I suspect that you may be using a cable or sat box rather than that set's internal atsc tuner.
Sometimes these boxes are not set up properly or reset themselves to a lower resolution.
Go into your box's settings menu nd look for the resolution settings. Verify that all of the modes or at least the maximum resolution for your set is enabled.
May 02, 2009 | Televison & Video
Tv turning on and off itself
Try "hiding" the remote from the set so that the TV cannot "see" it. Hope this little trick helps...accordianman
Jan 22, 2008 | Philips 43PP9202 43" Rear Projection...
PIP
PIP active requires two seperate signal sources delivered to the tv.... set-top box is ok, split signal---give half to box,then to set via A / V cables, the other half directly to set......Did you consult
owners manual?.........T.
Nov 02, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Tuner problem? (hope not!)
check if you put the cable in tuner A OR B CHANGE WITH REMOTE MAY BE NEED GOOD CONETION OR PUT ONE SPLIT T CABLE AND RUN ONE CABLE TO TV IN A AND OTHER B CHECK THIS NOT TRAY SPEAK SPANOL THANK YOU
Sep 27, 2007 | Philips 51PW9303 51" Rear Projection...
Philips 51PP9910 51" Rear Projection HDTV Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
