Question about Dell Dimension 8400 PC Desktop
How can I fix a bad system config info err
Comes up with blue scrren and unable to get into safe mode or the basic prompt mode
  • 5 more comments
  • burkejt Feb 28, 2009
    Yes, I have the xp card that came from Dell with the machine. But I am not able to boot from it.
    Even though I have two optical drives, the optical cd drive does not read a dvd. When I bought the pc I asked for a drive that read both cd''s and dvd's, but this isn't the case. The computer only boots from the cd drive and the operating system dvd is a dvd read. Is there a way to get around this?
    I did change this in the boot menu. Is this the same as the bios screen?. Thanks alot for your patience.
  • burkejt Mar 01, 2009
    I am going to install another dvd optical drive and hopefully I will be able to boot the operating system off of that. Then I will get back to you. Thanks again.
  • burkejt Mar 03, 2009
    Hello, I managed to boot from the win xp reinstallation disk and got to a windows c: prompt. I would appreciate you telling me where i go from here, for i did not want to reinstall the operating system and lose all my data.
    After doing the chkdsk /r, it did not come back with a chance to enter a Y. After rebooting it came back with blue screen with errs.
    0x00000074,0x00000003,0x00000002,0x80088000,0xc000014c.
    IIs there anything else I can try? Thank you for your time.
  • burkejt Mar 04, 2009
    I removed the ram memory and reinstalled several times and rebooting, but it didn't help. I am just going to reinstall the operating system and accept my losses. Than you for all you help.
I seem to be a little late, as you've indicated you're going to re-install, but I just had this problem with a Dell Dimension machine. Microsoft says it's probably a RAM issue, but it wasn't in my case. The problem was that the system hive was corrupt. Using a BartPE disk I was able to log in and replace the system hive with one from a few days earlier.
For those who don't know how to do this, but do have access to another computer or a BartPE CD or a UBCD CD, here's the steps:
Once you are able to access the hard drive, using another system and slaving it, or by using a BartPE CD or UBCD, navigate to C:\Windows\System32\config. Rename the SYSTEM file there to SYSTEM.old.
Next, navigate to the C:\System Volume Information folder then to the _restore{blah, blah, bunch of numbers} folder. If there's more than one, use the Date Modified information to pick the most recent one. Next, pick an RPxxx folder, where xxx is a number, that is a couple of days older than when the error occurred (check the Date Modified of the folders), then open the snapshot folder. Copy the file _REGISTRY_MACHINE_SYSTEM. Go back to the C:\Windows\System32\Config folder and paste _REGISTRY_MACHINE_SYSTEM into that folder. Now rename the _REGISTRY_MACHINE_SYSTEM file to just SYSTEM (no extension).
Reboot the system normally - hopefully the error is gone.
Posted on Apr 30, 2009
    President:
  • 2,653 Answers
You're going to need an XP cd, NOT a restore cd.
When / If you get one, let us know and we'll go from there.
Posted on Feb 27, 2009
  • 3 more comments
  • RescueTechLA
    RescueTechLA Feb 28, 2009
    You've got to change the boot order in the bios screen.
    Usually if you press the DEL key or the F10 key when you startup the computer it will take you into the bios.
    If you look at the bottom of the screen you should see a message that tells you which key to push.
    Once inside you've got to change the boot order so that the CD / DVD drive is the first boot up device.
    Let me know if you have any trouble doing this.
  • RescueTechLA
    RescueTechLA Mar 01, 2009
    Yes, it's the same thing.
    Don't worry about my patience. I'm here to help :)
    Have you had any problems with the cd / dvd drive in the past?
    Can you describe exactly what the CD you're trying to boot up has written on the cd?
  • RescueTechLA
    RescueTechLA Mar 03, 2009
    OK once you're there type:
    chkdsk /r
    press enter
    Message will come up (most of the time) saying disk is locked, blah, blah, blah.
    Press the "Y" key.
    Press enter.
    type: exit
    press enter
    press Ctrl + Alt + Del
    Choose the Shutdown Tab
    Shutdown or restart the computer.
    Let the Disk Check do it's thing.
    Hopefully you'll be able to get back into Windows.
    If you are successful backup your data immediately.
    Let me know what happens.
  • RescueTechLA
    RescueTechLA Mar 04, 2009
    That message usually indicates a problem with memory. Try puling out the memory and then reseat it.
    Boot the computer with just one module. If you get the same message, try the other module.
    Hopefully it's just some bad memory.
  • RescueTechLA
    Ahh man that stinks. Try installing Windows over itself when you do the install. That way you'll keep any files you previously had. If it doesn't work a format / re-install might be in order.
    Let me know if you have any other questions or problems.
    Best of luck!
BIOHD-s no drives detected
Error Code Biohd-2 No Drives Detected errors are caused by missing system files or broken system registry structures. This is a critical sign of an unstable system that is typically caused by improper maintenance of the computer.
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
If you are unable to get a connection with your hatd drive
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
You should have no input while chkdsk utility is in progress any input might further damage your computer also
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
You might have to use safe mode with Networking to download
Select safe mode with Networking to download
Oct 07, 2013 | HP Computers & Internet
Windows won't start with safe mode (windows7 i meant)
Do you have the Restoration/Restore Disk?
If so pop it in the optical drive (CD/DVD drive), and when asked choose Repair.
(Non-Destructive Installation)
Post back in a Comment.
Regards,
joecoolvette
Apr 13, 2013 | Dell Latitude D520 Battery PC Notebook
Sony VAIO VGN-FE570G PC Notebook bsod
Remove ALL media, DVD,CD,USB, Unplug, remove battery, plug in, reboot, Can you boot to Safe Mode? Try this in Safe Mode, or boot to Command Prompt: http://support.microsoft.com/kb/929833 Have you done ANY updates recently? Do you have a aggressive Registry Cleaner? take a look at this forum: http://answers.yahoo.com/question/index?qid=20090816162923AAJ3zvP OR this: http://answers.yahoo.com/question/index?qid=20060925192656AAl2M7O
Mar 08, 2013 | Sony VAIO VGN-FE570G Notebook
\Windows\System32\Config\
Is there anything else on the error message ?
Which operating system ?
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow
Jan 28, 2013 | HP Computers & Internet
My friends Dell Precision T3400 has a death Blue Screen how can i fix this it won't go in safe mode or anything
Are you absolutely sure you can't get into safe mode?
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Jun 25, 2012 | Computers & Internet
When I am starting my Lenovo G550,Model Name-20023 it restart with blue scrren. I am trying to start it in safe mode but same problems appears. Then I am trying to format the system with windows XP-2 but...
If you get a blue screen then you have a piece of hardware loose inside your lappy or could be a loose cable on the hard drive or cd/dvd rom, since lappy's are very hard to take apart it's best to take it to a shop to get fixed sorry.
Jul 08, 2011 | Computers & Internet
My desktop keeps restarting and shows windows update 3 of 3. it does it over and over.
If you have a Windows Vista operating system, try this:
Try a system restore from safe mode or from the repair option VistaDVD. Other then that only solution I have is a workaround. See if youcan access safe mode F8 at the boot screen, select "safe mode withcommand prompt" at the prompt type:- Code: C:windowswinsxspending.xml C:windowswinsxspending.old.xml
C:windowswinsxscleanup.xml -> C:windowswinsxscleanup.old.xmlPress enter after each command, reboot you will still see the config updates however it will quickly dissapear and Windowswill boot normally. I would contact MS about this, for a permanent fix.If no safe mode boot with your vista dvd go past the language setup andselect the repair option Now select command prompt (BTW at the "xsources prompt type C: press enter brings you to C:/>) now run thetwo above commands.
If you find this works you may be able to permanently remove the"Update" go to C:windows software distribution and right click select"delete" windows will recreate a fresh folder at boot.
Jul 19, 2009 | Dell Inspiron 530 Desktop Computer
My HP TC 1100 tablet PC comes up to a black screen offering me choices of "Safe Mode", "Safe Mode with Networking", Safe Mode with Command Prompt, "Last known Good Config" and "Start Windows Normally". Any...
There is a problem with the OS.
Try re-installing it.
If it still doeasnt solve the problem, then there is a problem with your hard drive.
Thank You
Please rate my solution
Jan 14, 2009 | Microsoft Windows XP Professional With...
Unable to open windows
try booting into safe mode (hit F8 repeatedly when you reboot until a safe mode option comes up) then if you are able to log in, go to the windows run prompt, type "msconfig" go to startup, disable all, services, disable all. reboot. see if it still does the same, if it doesn't one of those services are causing blue screen. Also try reverting to previous drivers if you did any driver updates, remove any new cards/hardware you might of installed recently.
If you can't get into safe mode, at a copy of any xp disk. boot up from it. (make sure your boot devices are set that cd rom is before hdd in cmos setup) then go to the recovery console "you press 'r' when ou have various option" type 1 for the windows, enter. enter for password unless you previously set an admin password.
Then type "chkdsk /p", let it run also type fixboot, and say yes. reboot and see if this solves your problem.
Jan 05, 2009 | Toshiba Satellite A135 Notebook
Dell Dimension 8400 PC Desktop Logo
13,745 people viewed this question
Alun Cox
