Question about RCA Televison & Video
Know sound sents I did the change to didgel
I cange from a to d and now I have know sound and I can not go back I am on cable I have a L42WD22 RCA.
Thank you it is a new tv and I got a dealer to take it back thay say it just not wright .
Posted on Feb 28, 2009
SOUND BUT NO PICTURE
The two long LCD inverter boards are dead.Replaced the 2 long inverter boards will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy the 2 long board LCD inverter boards for the replacement.
Jun 07, 2010 | RCA L42WD22 42 in. LCD Television
L42wd22 "no signal" and no audio
Exactly one year ago our TV did that. Now our TV is in the service center cause it has no screen.....just a plain black screen. However last year when we had it in we had that "no signal" message. It was not the same problem. It had something to do with wiring on the master board...thank gosh for warr. Otherwise I was told it would have been a $300-$500 repair.
Best of luck!!
Apr 21, 2010 | RCA L42WD22 42 in. LCD Television
TV has no sound
First try resetting by unplugging totally from the AC, then reconnect and try again. if still no audio, check all inputs to make sure its not a bad cable/sat box , next check for a speaker switch either on the back of the Tv or in the menu. make sure the cable box and TV is not in SAP second audio program mode. if these all fail then you make need the audio IC replaced on the main board
Aug 12, 2009 | RCA L42WD22 42 in. LCD Television
RCA L42WD22
3 watts metal oxide resistor. Don't have to worry about volts. Just use a 3 watt
Apr 03, 2009 | RCA 20F511T TV
Sound keeps cutting out
Hello Shellyfoster:
The issue sounds like a firmware update is needed for the small signal board.
Aug 14, 2008 | RCA L42WD22 42 in. LCD Television
HDMI Cable - No Sound L42WD22 RCA Flat Panel TV
No sound and a digital picture. i will assume you have no signal on analog rf cable. Thomson(RCA) have been having problem with these sets. The trouble stems from the digital cuircit board. We see alot of these. You used to get the digital board.. they are not availble.. so rca found the component on these that fail.. A VERY SMALL surface mounted fuse. With a lighted magnifer and some fine tip twezzers. we replace these fuses on these boards. Do you have any soldering experence..
May 12, 2008 | RCA L46WD22 Television
Televison & Video Logo
21 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
